Old June 12th, 2013, 09:56 PM   #1
sLick415
Bent front lever
Don't ask me how it happened. But how would you bend it back? Need some ideas cause I'm cheap.
sLick415 is offline   Reply With Quote
Old June 12th, 2013, 10:06 PM   #2
Panda
not an actual panda
Put it in a vise, heat it, bend it back carefully.
Don't use your hands to bend it.
Old June 12th, 2013, 10:35 PM   #3
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
They're $10 on eBay...
CVMA #531
Old June 12th, 2013, 10:59 PM   #4
sLick415
Yeahhh.. Figured if there was a quick fix, I'd save 10 bucks and the wait. Oh well.
Anyway! New problem... How am I gonna get this off.
Old June 12th, 2013, 11:11 PM   #5
Trailerboy531
impact driver or a #3 phillips head and a mallet.
I had the same problem... just about sold the bike to not have to deal with it. Heat sometimes breaks up the red loctite on it. GOD SPEED.
CVMA #531
Old June 13th, 2013, 06:21 AM   #6
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Try the #3 and a mallet with some heat. If that doesn't work just do what I did and drill the mother F***ing head off then slid the bar end off. Next use the heat then grab the exposed threads of the bolt with and pair of vise grips and it should come out easy.
Old June 13th, 2013, 12:45 PM   #7
1LoneWolf
1LoneWolf's Avatar
Same **** happened to me the other day ... torch the center of the phillips head for a few minutes, then try to work the screw off.
1LoneWolf is offline   Reply With Quote
Old June 13th, 2013, 04:41 PM   #8
just take the bar off with the 4" angle grinder.
Old June 13th, 2013, 06:29 PM   #9
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Ok, bent lever is easy. Put it back on the bike, and either just bend it back by hand or use a short length of pipe to bend it back Wrap a little tape around the spot of actual bend, use the pipe, put the lip of the pipe at the bent spot, then bend. These lever are really soft. The last time I straightened one I just bent it by hand. Do not use heat! That will lead to a mess.
Bar end. Use a propane torch to heat the screw, move the tip of the flame around the screw head. This will soften the loctite that's holding the screw in place. After a minute or two, try with proper JIS screwdriver. If it doesn't budge, more heat. Once the loctite is melted the screw just comes out. Attempting removal without heat will lead to severe disappointment!
Front brake = left lever; Clutch = right lever cadd Riding Skills 27 October 7th, 2014 08:29 AM
Lowside- bent clutch thrust rod and possibly bent shift fork? Klondike1020 General Motorcycling Discussion 3 April 1st, 2014 02:29 AM
Bent Front Wheel =[ xsnugglebear 2008 - 2012 Ninja 250R Tech Talk 11 November 14th, 2013 04:25 PM
[roadracingworld.com] - Video: The OTT Crew Removes The Bent Front End From Their Pro Ninjette Newsbot Motorcycling News 0 October 26th, 2010 09:20 AM
[roadracingworld.com] - Video: OTT Removes The Bent Front End From Their Project Yama Ninjette Newsbot Motorcycling News 0 October 26th, 2010 08:10 AM
