Old June 15th, 2013, 12:12 PM   #1
redrr308
Motorcycle(s): 06 cbr 600 pegram race bike/ 09 ninja 250r will be race bike
tweaked front end?
Bought a bike for a track build pulled fairings off necer noticed till today after gettin back fromgetting it tuned but the whole front end looks tweaked or am I seeing crap. Previous owner claimed the bike has never been down still had factory fairings and no visible scuffs or scratches or rash to the chassis anywhere.
redrr308 is offline   Reply With Quote
Old June 15th, 2013, 12:41 PM   #2
redrr308
tweaked front end?
Old June 15th, 2013, 12:44 PM   #3
lgk
is your stand tweaked?
Old June 15th, 2013, 12:59 PM   #4
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
somethings up but I just can't tell what
Old June 15th, 2013, 01:30 PM   #5
Use a plumb and verify that what the diagram shows is not happening.
Old June 15th, 2013, 03:30 PM   #6
redrr308
Verified that it is happening... now on to y?
Old June 15th, 2013, 03:36 PM   #7
redrr308
Everything looks fine from the stem back. The triples forks and front wheel look kicked tho.
Old June 15th, 2013, 03:37 PM   #8
cuong-nutz
cuong-nutz's Avatar
Make sure the forks are not twisted in the top and lower triples. With the top and lower not being aligned it could possible give that appearance.
edit: just saw your picture.
lower triple may be bent. Left fork (right in picture) did move as you can see from the rust. Are the top forks showing equal lengths exposed?
HalfFast Racing Team
Old June 15th, 2013, 03:43 PM   #9
redrr308
I broke the triples loose and u can see the rust line from before but I cant seem to get it straight. Bearings seem fine as well.
Old June 15th, 2013, 04:10 PM   #10
CycleCam303
King Hamfist
CycleCam303's Avatar
Motorcycle(s): 2007 Crf 150R, 2011 Hypermotard 796
Wait. Are you using a trackside rear stand? Because the angle of your bike is similar to mine on that cheapo stand. And my bike isn't tweaked.
CycleCam303 is offline   Reply With Quote
Old June 15th, 2013, 04:13 PM   #11
redrr308
Yep trackside on the rubber blocks, my stand sliders havent came in yet.
Old June 15th, 2013, 07:07 PM   #12
Dano
Dano's Avatar
Motorcycle(s): 09' Blue Ninja 250R and 07' Honda 919
Loosen all the bolts see if you can wiggle it back to normal then tighten
Dano is offline   Reply With Quote
Old June 15th, 2013, 08:36 PM   #13
redrr308
Found the problem. Apparently these little frames cant take a fall in the back of a truck.
Old June 15th, 2013, 08:43 PM   #14
Yes the steering head is twisted.
You can twist it back with enough leverage through the head and strong anchoring of the frame to the ground.
No heat; protect the bearings' seats from deformation.
http://www.dansmc.com/steering_tool1.gif
The bike must have fallen hard.
Old June 15th, 2013, 08:53 PM   #15
redrr308
Ya I noticed it flexed a little when I pried a little. It should take much. Ill keep yall posted thobitll be a few days im not hoing to put it back together tomorrow just rip it apart for the fork build this weekend.
Old June 19th, 2013, 10:39 AM   #16
redrr308
Cannot get this to straighten at all
Old June 19th, 2013, 10:41 AM   #17
redrr308
Old June 19th, 2013, 10:49 AM   #18
redrr308
And whats weird is nothing on the frame looks bent just looks like the stem is welded in all effed up.
Old June 19th, 2013, 10:51 AM   #19
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
You need to take it to a frame straightener like we do in SoCal. We use Mackie welding but I'm not sure what you have in your area. You really need to know what your doing to do this job right.
Old June 20th, 2013, 12:04 PM   #20
redrr308
After
Old June 20th, 2013, 12:19 PM   #21
Originally Posted by redrr308 View Post
After
Is it straight now?
If so, how did you fix it?
Old June 20th, 2013, 01:06 PM   #22
redrr308
Is it straight now?
Alot better I feel ok riding it now... and it was a pain in the ass. Anchored eye hooks in the floor strapped the bike down as tight as possible heated up everything thays blue (in the pic) til it was glowing. Made sure I wasnt heating up the stem it self. 5 foot 40lb 1.25" diameter steel bar and about 160 lbs of human hangin on it. Gonna weld some braces on it later.
Old June 20th, 2013, 01:15 PM   #23
Those are 800 ft-lb of twisting torque !!!
Read this article, if you have time:
http://www.tonyfoale.com/Articles/Fr...d/KawaMods.htm
Front End Wobbles kkim 2008 - 2012 Ninja 250R Tech Talk 318 May 25th, 2015 07:01 AM
Upgraded front suspension, front end tuck Ginganinja 1986 - 2007 Ninja 250R Tech Talk 12 October 30th, 2014 10:27 AM
WTB 08+ Front Brake lever/Bar End/ Front Turn Signal 1LoneWolf Items Wanted 3 July 8th, 2013 02:50 AM
[roadracingworld.com] - Thursday Video: How A Tweaked Front End Can Affect Handling Ninjette Newsbot Motorcycling News 0 March 25th, 2010 10:20 AM
[kropotkin thinks...] - MotoGP Tire Rules Tweaked - Front Tires Ninjette Newsbot Motorcycling News 0 May 21st, 2009 06:30 AM
