June 16th, 2013, 08:30 PM | #1 |
Join Date: Jun 2013 Motorcycle(s): 2009 Ninja 250r Posts: 47
Finally! I got my ninja!!
Behold, my beautiful new (to me) Ninja 250r.
2011 white limited edition with 1,089 miles. A good deal, I think, at $2800. The only thing is that when idle, I've noticed it runs at about 3500 rpm. Does this mean I have to clean out the carbs or something? |
June 16th, 2013, 08:37 PM | #2 |
Fast-Guy wannabe
MOTM - Jan '13
Nice bike
You could try adjusting the idle first. |
June 16th, 2013, 09:13 PM | #3 | |
B-Town Ninja
Join Date: Feb 2011 Motorcycle(s): Black 2013 Ninja ZX6R ABS Posts: 609
As for idle, does it continuously run at 3.5k idle or just when warming up? Is that with choke or not? Adjusting the idle screw is your best bet if it's running like that 24/7 with the choke off.
Downgraded to a 2013 636. Previous owner of a 2010 250r --------------------------------- My moto-vlog YouTube channel http://www.youtube.com/bloomingtonninja |
June 16th, 2013, 09:31 PM | #4 |
Ok, I will try and see if it's high at all times, and adjust the idle screw tomorrow. I literally just rode it home!
June 16th, 2013, 10:12 PM | #5 |
Join Date: May 2013 Motorcycle(s): 08 Ninja 250 Posts: 121
Congrats! Looks good!
June 16th, 2013, 11:54 PM | #6 |
Join Date: Apr 2013 Motorcycle(s): 2011 Ninja 250r SE Posts: 61
Copy cat lol Just kidding congrats that is a good deal imo. Enjoy it!
June 17th, 2013, 07:11 AM | #7 |
Congratulations! She looks great.
June 17th, 2013, 07:33 AM | #8 |
Join Date: Nov 2011 Motorcycle(s): 2012 ninja 250 Posts: 296
my second fav color ninjette. nice bike
June 17th, 2013, 07:39 AM | #9 |
Join Date: Oct 2012 Motorcycle(s): 2002 Ninja 250 Posts: 213
Congrats!!! Is this the bike the MSF Instructor fixed up before selling?
June 17th, 2013, 08:45 AM | #10 | |
I saw this one, practically new, for the same price, so I went with it to keep the peace. |
June 17th, 2013, 08:51 AM | #11 |
gotcha, good deal. Did you get the idle adjusted?
June 17th, 2013, 09:20 AM | #12 |
June 17th, 2013, 09:22 AM | #13 | |
Edit: I can't hear what he's saying because I'm at the library... but here's a video that show's that knob you want to adjust. Looks the same as my pregen. If I remember correctly rolling it toward the handle bars will increase the idle, and the opposite way decreases the idle. If not it's the other way around, not complicated at all. Good Luck! http://www.youtube.com/watch?v=OH3jdojT8KE |
June 17th, 2013, 09:31 AM | #14 | |
Thanks again. |
June 17th, 2013, 12:28 PM | #15 |
King Hamfist
Join Date: Oct 2012 Motorcycle(s): 2007 Crf 150R, 2011 Hypermotard 796 Posts: 940
Are you sure you aren't riding with the choke on? Pretty sure choke on means the bike idles at 3500 rpms
June 17th, 2013, 12:40 PM | #16 | |
But truth be told, I've only ridden it twice. One test ride that lasted about 3 minutes and then a 25 minute ride home. |
June 17th, 2013, 12:44 PM | #17 |
Unless it's really cold outside, turn the choke off as soon as the bike starts moving
June 17th, 2013, 01:02 PM | #18 |
June 17th, 2013, 07:02 PM | #19 |
So I fooled with the bike a bit, and you're right, that idle screw is super easy!
I'm idling now at 1,500 rpm. Is that ok? |
June 17th, 2013, 07:07 PM | #20 | |
Fast-Guy wannabe
MOTM - Jan '13
I've tried 1300 a few times but it tends to bog off the line if you don't rise the R's prior to dropping the clutch, I always end up back at 1500. |
June 17th, 2013, 07:41 PM | #21 |
Thanks.
Also, one of the headlights is out unless I put it in high beam. Are those easy to replace? |
June 17th, 2013, 08:10 PM | #22 |
June 17th, 2013, 08:17 PM | #23 |
Join Date: Jun 2012 Motorcycle(s): 12' Ninja 250 Posts: 831
theres a little nob thats hanging down just inside the fairing that can be accessed through the little cutout i believe on the left side. Cant remember which way to turn it but adjust that a little bit, and turn on the bike till you find an idle that works for you.
for pure sexyness, id recommend getting a headlamp cover. http://sportisimotorsport.us/index.p...products_id=36 heres mine mmmmm |
June 17th, 2013, 08:39 PM | #24 |
June 17th, 2013, 08:45 PM | #25 | |
If you see any with both on chances are they're rockin the high beams or have done some sorta mods. |
June 18th, 2013, 06:37 AM | #26 |
Not sure if this is true, but I was told once they make it like that so someone doesn't mistake you as a car far off in the distance when in actuality you're not far away.
I think there's a mod you can do so they both stay on but you'll have to be handy with electrical things. I ride in the day with my high beams on,, you should too! Next time you pull up to something reflective ( a stopped car, a building with widows etc) toggle between high and low beam. You'll see what a difference it makes for visibility to others even in daylight. On my pregen it makes a huge visibility difference. |
June 18th, 2013, 06:57 AM | #27 |
Ugh, got a problem, folks.
I fired up the Ninja today for my commute to work, and the thing keeps shutting off when I try to take off in 1st gear! Even after warming it up for 20 minutes!! Not to mention it's not even cold outside. I'm in NM, and it was already a good 70 degrees at least. The seller says he will give me my money back if I want. I don't know what it could be. I played with the idle screw, got it revving up to 2k at idle, and still won't go. Such a hassle. And I did notice a crack around each turn signal on both sides' fairings. He says it was never dropped, but how else would they get there? |
June 18th, 2013, 07:00 AM | #28 |
Ugh. I'm just so ticked that I didn't get to ride it to work today. . . was really looking forward to it!
June 18th, 2013, 07:41 AM | #29 | |
The cracks could happen from things banging into the side of the bike. |
June 18th, 2013, 07:57 AM | #30 |
June 18th, 2013, 08:05 AM | #31 | |
Since you had it running for 20minutes, and as soon as you try to ride it it shuts off, I think it has to do with the kickstand switch. It's a little button that pushes in and out right at the kickstand.. The kickstand activates this, it's a safety switch that will shut the bike off if you try to take off and te kickstand is down. Sorry, that's my only idea. Hopefully it's just something simple and someone else here can chime in. |
June 18th, 2013, 08:09 AM | #32 |
Are you able to rev it when it's parked? Try this rev it to like 3 or 4k and SLOWLY let the clutch out. If you're able to rev it up I don't see why it would shut off web you try to leave...unless its that safety switch.
Try making a post in the "tech talk" section of these forums and I'm sure you'll get more responses and faster than here in this thread. |
June 18th, 2013, 08:35 AM | #33 | |
Fast-Guy wannabe
MOTM - Jan '13
June 18th, 2013, 09:39 AM | #34 |
Here, I took a pic of the switch on my bike with the kickstand up:
I suppose it's possible the switch might be bad or maybe it's really gunked up and the button won't pop back out. It is at the bottom of the bike so i suppose that's possible. The switch is there so this doesn't happen: http://www.youtube.com/watch?v=UN14nwPMmrM |
June 18th, 2013, 10:54 AM | #35 |
I don't think it's the switch. I put the kickstand up, shift into 1st, and it still runs. I let the clutch out a little and it starts winding down. If I give it some gas it just dies.
This also happens if I give it gas while in neutral with the kickstand either down or up. Without shifting, I will twist the throttle and it dies. A couple of times it will go fine for about 10 feet and then it dies! The guy said I'm going to get my money back of I bring it back today. I think I will just do that. Ugh. |
June 18th, 2013, 11:01 AM | #36 | |
That's exactly how the switch works on my bike. A few times i forgot to put the kickstand up, start bike, shift to first, and slowly let out clutch the bike dies. Don't have an answer to the other symptoms in your post....Wish you wouldn't have to return it but that's what you feel is best then do it. Nice of him to take it back. Maybe before you make the exchange he can try to diagnose it since he did own and ride it.. Maybe it's just something silly you're overlooking. |
June 18th, 2013, 11:13 AM | #37 | |
The only thing I can think of is maybe he let it sit for a long time and stuff got guncked up or something. But I will take a look at the switch as well when I get home. |
June 18th, 2013, 11:27 AM | #38 |
Fast-Guy wannabe
MOTM - Jan '13
You could try sea foaming it but you'll need to at least ride it a bit for that. It sounds like it need a carb cleaning to me.
June 18th, 2013, 07:45 PM | #39 |
Well I went ahead and returned it..... Got my money back, thank goodness! On to the hunt!
June 18th, 2013, 07:56 PM | #40 |
Nerd
Join Date: Mar 2012 Motorcycle(s): Ducati Hyperstrada Posts: 672
I've got a 2011 I'm trying to sell. Its got 26,000 miles though!
It doesn't LOOK that steep. But you can go first... |
I finally got a ninja | thewestinn | New Members | 18 | September 30th, 2014 01:51 PM |
Finally picking up my ninja!! | Zdolak90 | 2013 - 2017 Ninja 300 General Discussion | 26 | July 24th, 2014 02:46 PM |
well finally got my Ninja !!!! | contact148 | Pictures | 12 | March 30th, 2013 11:25 AM |
Finally took some pics of my 09 Ninja | caphilli | Pictures | 2 | November 27th, 2011 09:28 PM |
Ninja is PAID OFF, Finally!!! | ScorpionNinja | General Motorcycling Discussion | 14 | July 25th, 2010 05:50 PM |
