Old November 11th, 2013, 11:31 AM   #1
agentbad
agentbad's Avatar
May have lost my only key.
So I have somehow misplaced my ninja key after moving it late one night to avoid street cleaning. I am usually pretty methodical about putting the key on my dresser but I guess I forgot this time. I didn't have time for a thorough search since I was trying to get to work so I am hoping it will turn up when I get home. What are my options for getting a new key made? Where is the key code printed for the pregen and how do I get to it?
Old November 11th, 2013, 11:38 AM   #2
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
Key code is behind the helmet lock. You'll need to remove it to get to it. A competent locksmith can easily cut you a new key just based off your ignition if it comes to that though. I had to do that for my pregen because the key code on my helmet lock made a key that didn't work at all. Be sure to get a couple spares while you're at it.
Old November 11th, 2013, 11:49 AM   #3
agentbad
agentbad's Avatar
Yeah I'm really hoping I just missed it because I was in a hurry. Getting the helmet lock open without the key is going to be fun.
Old November 11th, 2013, 11:51 AM   #4
tfkrocks
tfkrocks's Avatar
You need to unbolt the lock to get to the key code. I actually just broke mine off to get to it because the bolt was so corroded and I never used the lock anyway. Hopefully you have an easier time taking off the lock.
Old November 11th, 2013, 11:57 AM   #5
agentbad
agentbad's Avatar
FOUND IT! Put it in the top drawer of my dresser for some reason. Can I just go to lowes to make copies or locksmith?
Last futzed with by agentbad; November 11th, 2013 at 02:10 PM.
Old November 11th, 2013, 02:55 PM   #6
tfkrocks
tfkrocks's Avatar
I think a locksmith would be more likely to have the appropriate key blank since hardware stores are usually more limited in their selection.
Old November 11th, 2013, 08:06 PM   #7
Insan3guy
Insan3guy's Avatar
Motorcycle(s): 2015 zx6r
I got some blanks off amazon for a couple bucks back when I had my ninja. Your local hardware store might not have the right blanks, but they can cut them for you
Insan3guy is offline   Reply With Quote
Old November 11th, 2013, 08:55 PM   #8
agentbad
agentbad's Avatar
Doesn't look like any of them are on amazon anymore but the Silca KW12BP key blanks look to be a good match.
http://faq.ninja250.org/wiki/EX250F_key_blanks
Old July 18th, 2014, 09:06 AM   #9
VinceNJules
Name: Vince (or Jules)
Motorcycle(s): 2005 Ninja EX250-F19
Hate to drag this thread from the grave, but I just had two keys made from the key code, and neither key worked. They don't even match up with the (crappy) key I was given with the bike. Anything I can do about this?
VinceNJules is offline   Reply With Quote
Old July 18th, 2014, 09:18 AM   #10
agentbad
agentbad's Avatar
An automotive locksmith can duplicate a key just from your ignition.
Old July 18th, 2014, 10:23 AM   #11
Interesting. Wonder if your ignition cylinder was swapped out at some point. I can see the tolerances being off so the keys might not work, but if they don't even look alike with the key you were using, it seems like a larger issue.
Old July 18th, 2014, 10:39 AM   #12
agentbad
agentbad's Avatar
Old July 18th, 2014, 05:09 PM   #13
ninjakuma
Stunts Extraodinar
ninjakuma's Avatar
Motorcycle(s): 1999 Ninja 250
I watched the locksmith do mine when I lost my keys. They put a blank in, turn it really hard so there are tiny faint marks on the blank, pull it out and file it down a bit. Repeat until it works. At least that's how mine did it
Will backflip for tips
ninjakuma is offline   Reply With Quote
Old July 18th, 2014, 05:35 PM   #14
VinceNJules
Well, the key was from the second owner and was supposedly the original key. It fit the ignition, gas tank, seat, and helmet lock. Considering the helmet lock had the key code written, and the new keys opened nothing, not even the helmet lock, I would have to think that the locks were original and the new key lacking.
One curious thing was that the paper with the dimensions of the lock had a header that said, "Kawasaki - Ninja ZX 2003+". This makes me wonder about whether it's the right key, considering that the 250 is an EX, not ZX. Also, according to one site, there may be multiple bittings in the Z5000-Z6000 series. Any suggestions?
Old July 18th, 2014, 07:58 PM   #15
Bob2010
Bob2010's Avatar
slight thread jack, I have 1 key left and i am trying to get a spare made. Where are you guys getting the blanks ?
I see these on amazon, you get 3, different colors and under $10
Key blanks
2010 Red Ninja 250
2009 Black Ninja 250
Old July 18th, 2014, 08:08 PM   #16
agentbad
agentbad's Avatar
Key blanks
Lost value? scubaru General Motorcycling Discussion 6 April 9th, 2014 04:57 AM
Lost cause Carytowncat New Members 16 March 8th, 2014 02:42 PM
I lost my only key the_game General Motorcycling Discussion 132 August 6th, 2013 01:59 PM
[topix.net] - Joe Soucheray: We lost more than spelling when we lost the classifieds Ninjette Newsbot Motorcycling News 0 June 10th, 2012 12:30 AM
'07 just lost power slnarcissist 1986 - 2007 Ninja 250R Tech Talk 6 May 31st, 2012 04:37 PM
