September 12th, 2013, 10:11 PM | #1 |
Certified looney toon
MOTM Jul '13, Jul '14
FS: OEM NewGen bits and bobs
I ended up over ordering a few parts during my repair, so I want to clean out the garage. I genuinely have no idea what the are worth so taking prices from other sales. If you see something you want and have a fair offer, let me know and I'll consider it. Everything is plus shipping.
More pictures/angles available if you want, just ask! Front fender $40 Suspect from an '09 Has slight white paint splatter and a light rash on the back portion. FENDER-FRONT,M.D.BLACK 35004-0079-15Q Let tail cover $25 Suspect from same '09 Slight white paint splatter and light rash on underside. COVER-TAIL,LH,M.D.BLACK 36040-0114-15Q Grips $10 From my '12 - ONLY the grips, the throttle assembly is not part of this set. GRIP-ASSY,THROTTLE 46019-0001 GRIP,LH 46075-1144 Levers - $5 From my '12 These were damaged in the wreck but they felt straight last I used them. LEVER-GRIP,CLUTCH 46092-0030, LEVER-GRIP,FRONT BRAKE 46092-0028 Chain Cover $15/each From my '12 Yeah, I have two. Swapped to a Honda tire hugger. CASE-CHAIN 36014-0036 Radiator cowling $30 From the '09 I think this one escaped the white paint. COWLING,RADIATOR 55028-0229 Left side cover $15 From the '09 This did not escape the paint. COVER-SIDE,LH,F.BLACK 36001-0113-6Z Throttle assembly $10 From an '08 (I think) That's all I know. GRIP-ASSY,THROTTLE 46019-0001 Meter Assembly $125 From my '12 Reads in MPH, has 13216.8 on the odometer, white face with a smoke plastic on top (easily removed if desired), missing one tapping screw. METER-ASSY,MPH&KPH CAUS 25031-0360
<-- Linky Hey Unregistered! The code [you] shows the username currently logged in. IBA # 56020 AMA # 521481 Fun Rides! ][ My Videos ][ My Gear Hold yourself to the same rules you expect others to follow. Last futzed with by NevadaWolf; September 15th, 2013 at 05:14 AM. |
September 13th, 2013, 08:48 PM | #2 |
ill take the turn signals.
September 15th, 2013, 05:14 AM | #3 |
Turn signals sold. Thank you!
WTB - NewGen OEM blinker lens (the clear part) | iamjacob | Items Wanted | 1 | March 31st, 2015 11:40 AM |
[visordown.com] - Ducati 848 bits and bobs for sale | Ninjette Newsbot | Motorcycling News | 0 | February 16th, 2013 08:30 AM |
WTB: OEM newgen rearsets | CynicalC | Items Wanted | 8 | November 10th, 2011 09:34 PM |
F.S. Newgen oem parts. | nickadolph | Motorcycle-related | 8 | August 19th, 2011 04:20 PM |
