July 28th, 2011, 06:16 PM | #1 |
Join Date: May 2011 Motorcycle(s): 06 Buell Uly, 05 VStar 1100 Posts: 577
Help! I need somebody, Help, Anybody!?
ooook guys, it figures a week before the meeting and my bike breaks down. Heres the story. went to ride to work this morning, got on it like normal, choke it crank it, and it turns over like its gonna start, but it doesnt. Try again, same thing. Try it again and all i get is a "Click".
Thought it was the battery, so I took the brand new battery outa my gf's 250 and same thing. Try my battery in hers and it works. so its not the battery. the "Click" is coming from the starter relay. Took it off and switched em, and my relay works with hers, hers doesnt with mine. Not the relay. Took the J-Box off hoping maybe its just corroded, its not, lubed it up and still "Click". Any ideas please?!?!? I got exhuast coming saturday and was hoping to get that on for the dragon next weekend but if I cant get it figured out I'll have to take my other bike |
July 28th, 2011, 06:29 PM | #2 |
Have you tried switching rectifiers?
July 28th, 2011, 06:36 PM | #3 |
nope, dont even know what it is, but my papi does! So we'll check that tomorrow.
Keep the ideas coming guys pleaseeeeeeeeee. Wanna get it up and going for next week. |
July 28th, 2011, 07:29 PM | #4 |
Just take her bike
July 28th, 2011, 07:33 PM | #5 |
Fuse box check?
July 28th, 2011, 07:42 PM | #6 |
+1 Check the main fuse, and the aux ones as well.
July 28th, 2011, 07:58 PM | #7 |
I would but its lowered 3" and i bottom it out, PLUS no way i'd be able to get around those curves, if the ninja cant get fixed, I'll take the connie.
I've checked every single fuse and the main 30amp fuse. all looked ok. |
July 28th, 2011, 10:01 PM | #8 |
Join Date: Jan 2011 Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r Posts: A lot.
I was riding around one day and the bike suddenly sputtered and died. Then refused to start for the next 10 minutes or so. It just took some time, I've never had a problem since. When it happened the ignition would roll over but not start. It may just be a hiccup in the system like mine. I hope so for your sake .
p.s. have you tried opening the gas cap to release pressure? I did that when mine died and it may have been the vacuum or something contributing to the bike not starting though it still took a few minutes for it to start after that.
July 29th, 2011, 06:39 AM | #9 |
I know I have opened the gas cap, I know I'm kinda low on gas but its still in there. I hope its the recitifier and not hydrolocked..............Stay tuned for the exciting conclusion.
July 29th, 2011, 08:11 AM | #10 |
Join Date: Jan 2010 Motorcycle(s): 2005 Suzuki S50, 2006 Kawasaki Ninja EX250F, 1990 Honda PC800, 2000 Yamaha TW200 Posts: 848
You can jump directly to the starter and see if it turns over, ie., to see if the starter is good.
Have you tried to roll it in 4th, 5th, or 6th gear to see if the engine is locked up or seized? You may have to pull a plug or both to make sure the engine will turn over. BTW - releasing pressure (really vacuum) in the gas tank by opening the cap has nothing to do with the failure of the engine to turn over. |
July 29th, 2011, 08:14 AM | #11 | |
July 29th, 2011, 08:29 AM | #12 |
Smoker
Rectifier has no role in cranking over the engine.
And I can't believe noone has told you to check the safety switches. If the bike was fine one minute and then all of a sudden won't start after being turned off, it's probably a safety switch. |
July 29th, 2011, 08:31 AM | #13 |
I'll add switches to the list too. Thing is, it wasnt turned off, the key wasnt switched off in between it "trying" to crank and then just the "click"
July 29th, 2011, 08:50 AM | #14 | |
ninjette.org Monkey Spank
Join Date: Apr 2009 Motorcycle(s): 2008 250R Track-Bike Woodcraft clip-ons and rearsets FZ-6 track bike Posts: A lot.
start at the key and kill switch and follow the wires.
Black 250R Full Area P QC Dyno Jet Kit 100 main 41T Rear Sprocket |
July 29th, 2011, 10:17 AM | #15 |
like others said the clicking is your starter relay. if you hear it click that means your switches and everything are working and sending the stuff to the relay. your relay should connect your battery to your starter motor through a big fuse. its a very simple circuit, either your relay is bad (ruled out), your starter is bad or disconnected some how, or that fuse is blown... or the wiring is jacked... or your engine is seized.
you should still be able to jump start it
July 29th, 2011, 10:24 AM | #16 | |
Thats what I was thinking with the switches. It is Clicking at the relay. The starter we took out of the bike yesterday and used a car battery and it rotated, but once we got it back in the bike we could never get it to do anything, with the bike battery or the car battery.......... Would this lead to bad wiring, or what does the starter "plug into?" The engine? Possible the starters working but not cranking the engine. In which case I need to see whats up with it. |
July 29th, 2011, 10:34 AM | #17 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
The guy push starting the ninja, doesnt know how to do it. Its not that difficult. 1. You dont have to push it that hard and fast, just a simple roll will do it, its not a literbike. 2. You dont drop the clutch and leave it out. 3. Its best to actually GET ON the bike, not run beside it. If it fires in gear, it could leap out of your hands, and take off riderless.
When you drop the clutch, you just pop it for half a second to get the engine to turn over, and then quickly pull it back in so it can run. The ignition has to be on. And dont use the choke...start it with the choke off, then turn it on if needed to keep it running. If you push start it with the choke on, you could flood it if it doesnt start quickly. edit...nevermind, alex removed the vid... |
July 29th, 2011, 10:45 AM | #18 | |
July 29th, 2011, 11:01 AM | #19 |
For some reason I didn't think of this reading your post last night...
My 2004 gave me some issues starting a few times (well over course of 2 days). It started to crank like it was going to start then went to clicks only. Through messing with it, I found the kickstand up had some effect, but did not fix the issue 100%. I then went through checking all the safety relays. When I got the the kickstand safety thing, having to take the stand off to get it off, w/ that unpulgged it fired right up everytime. Cleaned that piece and re-assembled and had no prob since. |
July 29th, 2011, 11:05 AM | #20 | |
July 29th, 2011, 11:26 AM | #22 |
it sounds like one of two things, the wiring for the starter, or something keeping the engine from rotating... have you tried pushing it in gear? does it move at all? if it does i would think the only thing left since you know your relay and starter and battery work is the wiring or fuse between them... do you have a multimeter? disconnect the relay and the starter and test the wiring between
July 29th, 2011, 11:26 AM | #23 | |
July 29th, 2011, 12:23 PM | #24 | |
Thank you all for your help so far. |
July 29th, 2011, 01:59 PM | #25 |
Ok, its not the rectifier, also any ideas on how to get it into 2nd? It wont go. Tried to push start it in 1st and dropped it (yea not a smart move). But it wont go up into 2nd.
ok also dads trying to jump the circuits on the starter relay but it's not sparking or anything. This is leading us to the wiring. Wered be the best place to dig in? |
July 29th, 2011, 03:06 PM | #26 |
i usually have to hold the clutch halfway in and rock the bike to get it into second with the bike off...
i would start by taking your plug off the starter and putting your multimeter to the highest dc amp setting it will go and while taking a reading, hit your starter. when it clicks, you should see no current if we're on the right track, from there take the connections off your relay and check each wire's continuity (resistance check) from the relay side to the starter motor side. no continuity? bad wire.
July 29th, 2011, 03:23 PM | #27 |
You are totally wasting your time unless you can find out if your engine is seized. Roll the bike a little and get it to go into 2nd gear, then shift up until you are at least in 4th. or 5th, let out the clutch and see if you can roll the bike and turn the engine over. If you can get it all the way up the 6th and you can't roll it in gear, then you have another problem and all the time and energy you are expending now is a waste.
July 29th, 2011, 03:36 PM | #28 | |
July 29th, 2011, 04:19 PM | #29 |
you would also hear more than just a click from the relay if the motor was actually trying to turn the engine. you would hear that awesome repeating whineclickclick noise that you get from a halted starter motor
July 29th, 2011, 04:25 PM | #30 |
YEAH ITS FIXED!!!!!!! I feel like a complete idiot though The kill switch was off the whole time.............JUST KIDDING. Dad tried jumping it straight from the relay to a battery to bypass all the switches, and it still wouldnt work....so we took apart the starter, and the brush plates were sticking. Its weird becuase when we took the starter out the first time and used a battery it spun freely, but we cleaned them and now shes running!!!!!! I'll order a plate just in case but
THANK YOU ALL SOOOOOOO MUCH FOR ALL YOUR HELP. Now, I got my 15t front today, and gettin the Area P exhaust in (hopefully) tomorrow then I'll be ready for the rally! |
July 29th, 2011, 05:18 PM | #32 |
July 29th, 2011, 10:44 PM | #33 |
Starter brush plates sticking ... I'll add that to the odd things to check when the bike won't start.
Tenacity pays off. |
