Old June 19th, 2021, 09:55 AM   #1
JackTheAlbatross
Motorcycle(s): Ninja Kawasaki 250r 2006
Single Click when Trying to Start My 2006
So last Sunday I cranked up my 2006 250r Ninja to warm up. I forgot to set the petcock "ON" instead of fuel. I come back and it's not running anymore of course. I realize I forgot to set it to "ON." No problem.
I try to crank it up, and I get a single click from the right side of the bike. There's no multiple clicks like I'd expect with a dead battery. Just a single click when I press the start button.
The sound, from what I can tell is coming from the starter relay. I've checked the battery and it's at a 12.67v.
*Feel like I should mention this: I've noticed the starter relay is getting pretty hot after a couple of attempts to start the bike...? Not sure if this is normal.
Things I've tried:
1. Charging the battery - the battery stays at 12.7- 12.5v after charge.
2. Complete the circuit from the starter relay with a screw driver - there's absolutely no spark when I touch the two screws
3. replaced the 30 amp fuse on the starter relay - same click when trying to start.
4. Ordered a new starter relay - same single click
5. Tightened the battery connections
6. cleaned the battery connections
The battery is relatively new. I bought it earlier this year. I'm thinking of trying to jump the battery with a jumper pack. But I have no idea what to do now. lol
Please help. :|
Last futzed with by JackTheAlbatross; June 19th, 2021 at 11:05 AM.
JackTheAlbatross is offline   Reply With Quote
Old June 19th, 2021, 10:06 AM   #2
Measure the battery voltage while you're actually trying to crank the engine. My bet is that it'll be very low.
Old June 19th, 2021, 10:13 AM   #3
JackTheAlbatross
Hmm.. just checked. It's at ~12.3v while holding down the start button. Too low?
Old June 19th, 2021, 10:40 AM   #4
No, not bad actually. I would say you've ruled out a battery failure as the cause.
Old June 19th, 2021, 11:34 AM   #5
JackTheAlbatross
Hoo boy...
I think I may have found the issue.
Looked at my engine and noticed the left boot was sticking out a bit. Tugged on it and it came right out with no resistance. The boot is split and the spark plug is lodge in the engine with the other half of the boot on it.
Not sure how to get it out of there.
Old June 26th, 2021, 08:51 AM   #6
JackTheAlbatross
Update!
I changed the sparkplug boot.
Still getting the same *click* sound when pressing the ignition switch.
Is my engine seized?? I'm at a complete loss.
Old June 26th, 2021, 09:12 AM   #7
Originally Posted by JackTheAlbatross View Post
Update!
You should remove the circular cover on the left engine case and use a ratchet/socket to turn the engine over.
That will tell you.
Pulling the plugs will make it easier to spin over, but you should be able to spin it over slowly with them in.
This is the cover - https://faq.ninja250.org/wiki/File:CIMG0030Large.jpg
How you spin it over - https://faq.ninja250.org/wiki/File:CIMG0031Large.jpg
It looks like you want to turn it counterclockwise, but maybe someone can confirm. You want to turn it in the normal direction of rotation.
Old June 26th, 2021, 10:02 AM   #8
Right, the engine rotates in the same direction as the wheels.
Old June 26th, 2021, 10:17 AM   #9
JackTheAlbatross
That will tell you.
So you're saying I should try to start the bike (press the ignition) while turning it counterclockwise?
Old June 26th, 2021, 10:35 AM   #10
JackTheAlbatross
Craftshaft does move! But very resistant to turns. I tried to turn over the engine after a few turns and I got a bit of a sputter and then nothing.
Old June 26th, 2021, 11:02 AM   #11
No! The idea was to see if the engine is seized. You just try to turn it with a wrench.
Old July 24th, 2021, 12:40 PM   #12
JayVapes
JayVapes's Avatar
Motorcycle(s): Ninja EX250
I wonder what happened... the idea was to hand crank the pistons to see if they’re truly seized
Old July 24th, 2021, 12:42 PM   #13
JayVapes
JayVapes's Avatar
Should be a little hard to turn the crank while the spark plugs are still in. It shows there is still compression happening inside the cylinder. Also I’m glad it’s not seized.
Old July 24th, 2021, 01:43 PM   #14
JackTheAlbatross
wow has it been a month already? :O
Still not running! Haha
I'm able to turn the crankshaft but it's a bit resistant after a quarter of the turn.
Old July 24th, 2021, 03:43 PM   #15
Jim Moore
Jim Moore's Avatar
Motorcycle(s): 2000 Ninjette, 98 CBR600, 98 VFR800, 2000 BMW R1100RS, Kymco Movie 150
How long did it run? Did it overheat and kill the engine?
That being said, 12.3 is a strange number. I would expect to see 10-11 volts during crankingwith a good battery. With a bad battery, a starter or seized engine I'd expect to see even les as the battery gave its all to try to turn the engine.
Jim Moore
Jax, FL
Jim Moore is offline   Reply With Quote
Old July 24th, 2021, 06:17 PM   #16
SibSerge
Is the oil level ok? if the hydrolock is already ruled out and you are certain the crank is turning just try to push start the bike in the first gear. If the starter/ rely is an issue and the rest of the bike is ok it would start. But you want to make sure its not locked up before you do that or it will make the matter worse.
Old August 24th, 2021, 02:34 PM   #17
JackTheAlbatross
**UPDATE**
Hey, yall! Thanks for the help!
I'm not sure what I did right but it worked.
I came to the conclusion that my engine might have been seized.
I poured some Marvel Mystery Oil into both my cylinders and let it sit for about 3 days.
Afterwards, I turned the crankshaft clockwise and noticed a quick hissing noise and stopped. Pressing the start button gave me a VERY quick crank up sound. Looking at the nut in the crankshaft, I could see it trying to spin counter clockwise.
I turned the crankshaft again until I heard a hissing noise and repeated.
Eventually, I held down the start button while turning the crankshaft clockwise and for whatever reason the pressure of me turning it that way resulted in the engine wanting to start up (which requires it to spin clockwise).
It slowly started to spin on its own without me turning the crankshaft and eventually cranked up!! I'm riding again!! I only had to do the whole cranking process once more after I rode it the first time. Today (two days after the big miracle day) I went to crank it up and it's turning over just fine!!
I'm happy it's working but I'm not 100% sure on what caused it or fixed it!
Can anyone explain the mechanics of whatever the hell I did to fix my bike?
Old August 25th, 2021, 06:11 AM   #18
Was the oil level correct?
I might change the oil and keep an eye on the level.
The battery may not be fully charged. Check the voltage before starting. Should be over 12.7V if it's fully charged. You could have a bad battery.
Old August 25th, 2021, 12:09 PM   #19
JackTheAlbatross
Oil level is good. I bought a new battery just in case but it didn't work until I manually rotated the engine while holding down the ignition button.
Old August 26th, 2021, 06:55 AM   #20
Many new batteries are not fully charged - you need to check and usually charge.
I'd still check it. Should be 12.7V or more before hitting the button. If that's good, check while cranking. It should stay over 10V during cranking.
Intermittent idle woes, single click sound RPM drop mistified 2008 - 2012 Ninja 250R Tech Talk 37 January 22nd, 2019 01:41 PM
Trouble Shooting - Bike Click Wont start RisingRay 1986 - 2007 Ninja 250R Tech Talk 11 May 31st, 2018 06:53 AM
No start, click from fuse box, batt is good WAGESLAVEesc 1986 - 2007 Ninja 250R Tech Talk 17 June 7th, 2014 04:09 PM
[motorcyclistonline] - Adjusting Motorcycle Suspension | Click, Click | Street Savvy Ninjette Newsbot Motorcycling News 0 July 10th, 2012 10:20 PM
one click, no start coondog 1986 - 2007 Ninja 250R Tech Talk 12 September 12th, 2011 04:43 PM
