June 8th, 2011, 07:16 PM | #1 |
Join Date: Apr 2011 Motorcycle(s): green ninja 250 Posts: 69
Quick brake question
I took my first ride with Jeff today and while looking the bike over, noticed that the rotors had slight grooves. I know that with cars, the rotor is supposed to be completely smooth, but didn't know if the same held true for bikes.
June 8th, 2011, 07:17 PM | #2 |
yes, sometimes there are grooves. a picture would really help to determine if you have a problem or not.
June 8th, 2011, 07:19 PM | #3 |
I will take a picture and post it tomorrow. The grooves are very light, not deep at all.
June 8th, 2011, 07:21 PM | #4 |
I think you'll be fine. Post a pic when you have the time to confirm, though.
June 9th, 2011, 12:47 PM | #5 |
I took a picture, but I think I'm going to have to let Jeff post it.
It's more a curiosity, and trying to learn bike maintenance, thing than anything else. If it were a car, I'd say the rotors were starting to need to be ground, but I know very little about bikes. |
June 9th, 2011, 01:25 PM | #7 |
the grooves don't look too bad, but I see quite a bit of wear as to the thickness of the rotor. The minimum thickness is stamped on the rotor somewhere. check to see how close you are to that measurement.
did someone install aftermarket front brake pads on the bike? |
quick question | Electronic M | 2013 - 2017 Ninja 300 Tech Talk | 57 | March 17th, 2015 04:41 AM |
Quick Question | PsHYk | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 10th, 2012 02:58 PM |
Just a quick question | zooman | 2008 - 2012 Ninja 250R Tech Talk | 12 | May 18th, 2012 10:52 PM |
Quick Question! | shiftdrift06 | 1986 - 2007 Ninja 250R Tech Talk | 4 | March 1st, 2012 08:31 PM |
some quick brake question | reaperw | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 21st, 2011 08:42 PM |
