August 25th, 2012, 01:45 AM | #1 |
Ninja noobie
Join Date: Aug 2012 Motorcycle(s): ninja 250r Posts: 498
Bike won't start
Hey guys
my brand new ninja wont start after short trips to the shops? so when i first cold start the bike it starts up just fine, but once i go for a short trip to buy something and try starting it again it wont start am i doing something wrong ? or is there a problem with the bike thanks! |
August 25th, 2012, 06:38 AM | #2 | |
Join Date: Jun 2012 Motorcycle(s): 09 Ninja 250r Posts: 70
No, but seriously it might be your battery, because mine did that too. I had to jump it, rode for 40 minutes, and the battery was still dead when I went to start it back up |
August 25th, 2012, 09:08 AM | #3 | |
When hot, try starting with the throttle half opened and no choke. As soon as the engine fires, close the throttle to avoid over-revving it. Try also pouring some Seafoam into the gas tank for cleaning the carb's jets.
August 25th, 2012, 01:53 PM | #5 |
Jigglin' your Jiglets
MOTM - Apr '13
Push start it. Works every time
August 25th, 2012, 11:58 PM | #6 |
Ninja noobie
August 25th, 2012, 11:59 PM | #7 | |
Ninja noobie
August 25th, 2012, 11:59 PM | #8 |
Ninja noobie
August 26th, 2012, 12:05 AM | #9 |
MOTM - Apr '13
Pull clutch, push, release clutch, win
August 26th, 2012, 12:20 AM | #10 |
Ninja noobie
August 26th, 2012, 12:35 AM | #11 |
MOTM - Apr '13
nope just have the bike turned on and have the choke on too. If you get the engine moving it'll keep going
August 26th, 2012, 12:58 AM | #12 |
Ninja noobie
thanks alot for the info jiggles god bless man
August 26th, 2012, 01:00 AM | #13 |
Ninja noobie
the funny thing is this random guy who was trying to help me, told me to do the exact same thing, but he didn't explain it, man it was embarrassing cause I was in the middle of a busy car park
August 26th, 2012, 01:11 AM | #14 |
MOTM - Apr '13
Maybe I'll do a video on push starting a bike
August 26th, 2012, 01:15 AM | #15 |
Ninja noobie
yes you should remember there's are a whole lot of noobs out there! and more on the way!
August 26th, 2012, 09:27 AM | #16 |
jiggles, let the bike-pushing pro handle that video.
Yas, don't listen to jiggles. you dont need the choke when its warmed up already and the choke will make it too rich to start.
August 26th, 2012, 10:46 AM | #17 | |
Try what I explained only if no-choke starting of the warm or hot engine is difficult. Not really bad for the engine if you prevent rpms' from going much higher than 3,000. Other than for cold start ups', choke is bad for the engine; so, use it frugally.
August 26th, 2012, 10:53 AM | #18 |
MOTM - Apr '13
Who uses choke when it's warm
August 26th, 2012, 05:11 PM | #19 |
Ninja noobie
idk i thought the bike was still not warmed up cause the shops are like 2mins away X D
so i decided to use it |
August 26th, 2012, 05:20 PM | #20 |
Join Date: Jun 2012 Motorcycle(s): 2000 Kwak Ninja 250 and 1998 Yamaha YZ400F Posts: 534
I'm having a very hard time understanding why so many people have starting/running issues with these bikes. I only use my choke when the engine is stone cold (usually only at the start of the day) to get the bike to fire. I usually turn it off immediately, but keep it revved up as I'm taking off (I keep it under 8k when it's cold) and it runs great. I'll have to loop around my block because it's a one way road, but by the time I get to the highway which brings me to work/wherever I want to go it's only 1/10th of a mile away. By that point my bike has run enough to not idle perfectly, usually about 1000-1100 RPMs, but it won't die either. If I go about a mile or two up the road the bike settles down to a nice 1400 RPM idle. Starting after it's warmed usually requires no throttle if the engine is very hot. If it has sat a bit I hold the throttle open ever so slightly. I've never had any troubles getting my bike to start. Adjust your mixture screws people! 3 turns out!
August 26th, 2012, 07:17 PM | #21 |
MOTM - Apr '13
August 26th, 2012, 09:05 PM | #22 |
Ninja noobie
thanks!
New bike won't start. PLEASE HELP!! | Lookmomimaninja | 2008 - 2012 Ninja 250R Tech Talk | 39 | September 4th, 2015 10:50 PM |
Bought first bike and 1 day later it won't start: do I have a junk bike? | brendandubs | 1986 - 2007 Ninja 250R Tech Talk | 43 | May 11th, 2014 07:59 AM |
bike won't start. tried everything | rabies | 1986 - 2007 Ninja 250R Tech Talk | 17 | September 22nd, 2013 04:46 AM |
Bike won't start | joyinc | 2008 - 2012 Ninja 250R Tech Talk | 21 | May 31st, 2010 09:10 AM |
Bike down...won't start | Lurkable | 2008 - 2012 Ninja 250R Tech Talk | 17 | November 23rd, 2009 02:49 PM |
