August 25th, 2011, 10:53 AM | #1 |
james250ninjette.newbie
Join Date: Mar 2010 Motorcycle(s): 1986 ninja 250 Posts: 276
removing gas tank - petcock question
is there an off switch near the petcock all i see is on and prime
how do u keep gas from comming out .. |
August 25th, 2011, 10:56 AM | #2 |
The petcock is vacuum operated. It should not pour fuel once disconnected. It may leak a bit so be prepared for that but as long as it is functioning correctly... it will NOT continue to flow fuel.
August 25th, 2011, 11:04 AM | #3 |
Join Date: Aug 2009 Motorcycle(s): 2008 Ninja 250 (Blue!) Posts: 488
August 25th, 2011, 11:05 AM | #4 |
Leave it at ON. Turning it to PRIME will allow fuel to flow, even if the engine is off/disconnected.
August 25th, 2011, 11:21 AM | #5 |
Pretty sure I covered that...
August 25th, 2011, 11:23 AM | #6 |
But I did miss that detail. The petcock should be in the "ON" position. Prime will flow all the time. Thanks Alex!
Changing Spark plugs w/o removing gas tank? | ScorpionNinja | 2008 - 2012 Ninja 250R Tech Talk | 6 | March 9th, 2016 09:12 PM |
Took off fuel tank and petcock is dripping gas... | Navigon | 2008 - 2012 Ninja 250R Tech Talk | 31 | February 4th, 2013 07:16 PM |
WTB : 08+ gas tank petcock. | abhijitz | Items Wanted | 0 | August 22nd, 2012 06:23 PM |
Gas Tank Petcock Problem? | jboyd12 | 2008 - 2012 Ninja 250R Tech Talk | 17 | April 2nd, 2012 09:15 AM |
