May 19th, 2013, 09:47 PM | #1 |
Join Date: Nov 2012 Motorcycle(s): 2009 ninja 250 blue Posts: 31
integrated tailight killing battery
I installed an integrated taillight a few days ago and not sure what I did wrong. After a few hours my battery keeps dieing and I need to jump it. This never happened before the light so I know that the light is the problem, or at least my wiring. I got some relays from Oriellys hooked up so that the leds flash when my blinkers are on but they flash really fast. Did i buy the wrong relays and that is what is killing my battery?
May 20th, 2013, 02:00 AM | #2 |
Do you have LEDS on all of your indicators? That means it will be necessary to use the diode method do a search it up - but if your indicators flash that shouldn't be necessary. This was the flasher I used:
http://www.napaonline.com/Catalog/Ca...62D_0217779968 As for your battery issue...did you leave your key in during installation? Have to ask all possibilities . |
May 20th, 2013, 04:35 AM | #3 | |
Join Date: Apr 2012 Motorcycle(s): 650r 2009 Vulcan 800 2005 Posts: 557
Do both sides of the LED turn signals flash at the same time? If so, temporarily remove your dashboard turnsignal lamp and see if they now blink correctly (but fast). If so, you need to install a pair of diodes where the turn signal lamp is in the dash... http://www.ninjette.org/forums/showt...ht=turn+signal If the blink too fast, it is because the LEDs have less load than the stock lamps and the turn signal flasher thinks that a lamp is burned out. Replace the flasher with one designed for LEDs, or install load resistors... better to replace the flasher. Wes
It's all about the curves. If you ride, you understand. If you have a stick skinny g/f and ride, you're 1/2 way there. |
May 20th, 2013, 08:44 AM | #4 |
They flash separately just fast. Where would a get a flasher that is made for leds? The flasher is that little black box right? 7if I got a flasher would I get rid of the relay?
May 20th, 2013, 09:29 AM | #5 |
Join Date: Dec 2012 Motorcycle(s): 2008 Ninja 250R Posts: 263
Flasher and relay are the same thing here in this context. Just get the EP34. Autozone will have it. Not sure about OReilly.
May 23rd, 2013, 02:51 PM | #6 |
ModMy250.com
It all depends on how you wired in your relay. The OEM circuit does not connect the relay directly to the battery. There's no way the relay can be causing the drain unless you connected a wire to it on your own. See the link in my sig for a plug and play flasher relay that won't give you problems.
The www.ModMy250.com guy |
May 23rd, 2013, 03:25 PM | #7 |
Join Date: May 2011 Motorcycle(s): 2011 Ninja 250R SE GREEN! Posts: 562
Do you have one long light where you're blinking half of it or separate lights for signals? If you have separate lights you wired it wrong with the wrong relay, you need a new flasher and ditch the other ones. The LEDs wire in like the old signals.
Trust me, I'm a banana! |
May 23rd, 2013, 10:51 PM | #8 |
i bought the ep34 and will try installing it tomorrow and will let you guys know how that goes.
Can I be killing my battery? | Alpen10 | General Motorcycling Discussion | 7 | May 22nd, 2014 08:35 AM |
FS: Battery Tender 021-0128 Battery Tender Plus 12V Battery Charger (Automotive) tagg | Amazon Postbot | Amazon - Popular Motorcycling Items | 0 | April 23rd, 2013 04:52 PM |
FS: Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger (Automotive) ta | Amazon Postbot | Amazon - Popular Motorcycling Items | 0 | April 23rd, 2013 04:52 PM |
making an integrated tailight and flush blinkers work...I searched | Mac | 2008 - 2012 Ninja 250R Farkles | 2 | August 30th, 2010 04:29 PM |
