October 24th, 2011, 06:51 AM | #1 |
james250ninjette.newbie
Join Date: Mar 2010 Motorcycle(s): 1986 ninja 250 Posts: 276
the choke
im in jersey its getting cold, i shimmed my needles .
when i got too start my bike inthe morning its haed to start ,even when i use the choke its still hard to start ,after 7 tries it finally starts up any ideas on how to start the bike in morning |
October 24th, 2011, 07:21 AM | #2 |
The Ninja is hard to start in the cold, shims, or no shims, choke or no choke. Period. Using the choke is just adding more fuel to the carb that is already richened by shims. Instead try starting the bike without the choke and let it try to idle up on it's own for a bit then try micro turning the throttle to help it along until it is able to maintain a low idle on it's own. Be patient, it may take a starting cycle or two, but it will get going. Also keep in mind that there are a number of other factors going on (temp, winter blend gas & air density). You may even have to adjust your idle speed (up and down) a little for the fall / winter riding season. All of these things will have an affect on performance.
October 24th, 2011, 07:56 AM | #3 |
when it's real cold, kick it.
November 6th, 2011, 04:52 PM | #4 | |
Join Date: Apr 2011 Motorcycle(s): 2013 Ninja 300SE Posts: 47
Last futzed with by ninjaprof; November 6th, 2011 at 04:52 PM. Reason: I can't spell |
November 6th, 2011, 05:38 PM | #5 | |
To choke or not to choke? | Greyfox | 2008 - 2012 Ninja 250R Tech Talk | 14 | May 9th, 2012 08:03 PM |
Never using choke | kano6280 | 2008 - 2012 Ninja 250R Tech Talk | 22 | March 29th, 2012 03:26 PM |
choke? | reabo | 2008 - 2012 Ninja 250R Tech Talk | 4 | February 2nd, 2012 05:24 AM |
So how does choke work? | ericeng91 | 2008 - 2012 Ninja 250R Tech Talk | 10 | April 15th, 2011 06:50 AM |
