Old September 8th, 2010, 01:51 PM   #1
leesic66
Motorcycle(s): 2005 Ninja 250
blinker issues
Hi all!
So I have gone through about 7 10 amp fuses in the past 2 weeks. My blinkers are burning them out somehow. I dont know much about electrical stuff. My left side blinks really fast when I turn it on. Any thoughts??
leesic66 is offline   Reply With Quote
Old September 8th, 2010, 01:56 PM   #2
Snake
Snake's Avatar
Have you tried putting some new bulbs in and see if it still blows the fuse?
Old September 8th, 2010, 02:27 PM   #3
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Short in the harness or the socket is my bet. Start off with a visual check for damaged wiring at each signal stalk.
Old September 8th, 2010, 06:26 PM   #4
darrell85
darrell85
darrell85's Avatar
Motorcycle(s): 2001 250 ninja
Is the right side working ok??? And are the signals factory or integrated,or flush mounts??? If so check those connections first , sounds like something grounding out.
darrell85 is offline   Reply With Quote
Old September 9th, 2010, 02:10 AM   #5
bamaland
bamaland's Avatar
Motorcycle(s): 93 kawi gpz500
Originally Posted by leesic66 View Post
Hi all!
turn blinkers on and see which blinker is not coming on front or rear..
if rear, look uner the tail theres a grey and yellow wire (i think thats the correct colors) that runs into your turn signal, make sure that wire hasnt been ripped apart by your rear tire..
happened to me this weekend lol.
bamaland is offline   Reply With Quote
Old September 10th, 2010, 11:22 AM   #6
leesic66
thank you for all the replies....... All 4 lights turn on when I have a new fuse in. But the left side blinks very rapidly. They are the stock blinkers. And now sometimes they come on and sometimes they dont.......
Old September 10th, 2010, 11:24 AM   #7
bamaland
bamaland's Avatar
do what i said, check the wires all of them.. make sure none have slices in them.. im 75% sure one has to have a slice in it and is causing it to ground out ..
Old September 10th, 2010, 11:24 AM   #8
check for corrosion in the blinker sockets. remove the bulbs and see if the socket interiors need a good cleaning. it should be absolutely clean in there.
Old September 10th, 2010, 11:54 AM   #9
leesic66
Thank u all!! I will try those things.....
Old September 10th, 2010, 02:10 PM   #10
highpsiguy
highpsiguy's Avatar
Motorcycle(s): 1981 Honda Cx500 Custom, 2002 Ninja 250
I used a ground going to my left blinker for my 12v acessory outlet. Ever since my left blinker has blinked 2x faster than right side. It still works... i just have to turn faster when going to the left hehe
"Rudeness is a weak persons attempt at strength."
highpsiguy is offline   Reply With Quote
Blinker issues. JeffM 1986 - 2007 Ninja 250R Tech Talk 8 July 1st, 2014 07:22 PM
Blinker fluid? JeffM General Motorcycling Discussion 73 May 16th, 2014 10:03 AM
Blinker Problem ChrisCusi 2013 - 2017 Ninja 300 Tech Talk 7 February 21st, 2013 11:14 AM
blinker akcalhoun 2008 - 2012 Ninja 250R Tech Talk 8 August 17th, 2012 02:31 AM
blinker problems TrueFader 2008 - 2012 Ninja 250R Tech Talk 10 August 21st, 2010 09:37 PM
