January 9th, 2009, 05:47 AM | #1 |
[kropotkin thinks...] - Saving MotoGP Part 2 - How To Encourage The Cheats
If you enjoyed reading this article, please click here to view it on Kropotkin's site, MotoGP Matters.
----------------- Yesterday, we examined why MotoGP turned into the bottomless pit which swallows money, and looked at the mistakes which made this result inevitable. Today, we'll be examining the suggestions being put forward to fix the situation, and get spending in MotoGP back under control, and picking them apart looking for flaws in their logic. The proposals being put forward come from all around the motorcycle racing world, from seasoned veterans and respected thinkers in major media outlets, to the purest of noobs in every racing corner of every motorcycle discussion board around the internet. The ideas vary from the brilliant to the absurd, with all shades in between. But there are a few common themes which keep reoccurring, and which need to be looked at more closely. The most common proposal for reducing costs is to limit the role of electronics. There may be a lot of good reasons for wanting to do this - to give more control back to the rider, for a start - but the one thing this suggestion will not do is reduce costs. For the reason that it won't cut costs, look no further than the lessons of reducing engine capacity to 800cc. Beyond the practical difficulties of limiting electronics, the teams would simply spend more time looking for ways to circumvent the spirit of the law, while balancing on a razor's edge on the right side of the letter of the law. The Workaround The most well-known example of this is the attempt by the AMA to ban traction control. The Yoshimura Suzuki team found a way to get around the restrictions - imposed by banning the use of front wheel speed sensors - by doing some clever calculations using comparisons of throttle opening, rear wheel speed and engine speed. This way, the team was able to build a traction control system that passed every single technical inspection it was subjected to. Likewise, attempts to reduce the role of electronics - by banning GPS, traction control, launch control, etc - will simply spur teams on to find a way around them. If GPS is banned to stop the teams using separate engine maps for different parts of the track, then the engineers will simply use braking marker points (clearly identifiable on data traces) to do the same job. If traction control is banned, then development time will be spent developing a "passive" traction control system based on comparing gear selection, rear wheel speed, engine speed and throttle opening. Add in braking data, and you have a decent basis to start building a rudimentary but refinable traction control system. read more
[kropotkin thinks...] - 2013 Misano MotoGP Race Result: Saving The Best For Last | Ninjette Newsbot | Motorcycling News | 0 | September 15th, 2013 03:40 AM |
[kropotkin thinks...] - MotoGP's Big Problem: Not Enough Cheats Making The Rules | Ninjette Newsbot | Motorcycling News | 0 | August 20th, 2010 09:10 AM |
[kropotkin thinks...] - Suter MotoGP Project To Use No Part Of Ilmor X3 | Ninjette Newsbot | Motorcycling News | 0 | August 1st, 2009 08:40 AM |
[kropotkin thinks...] - Saving MotoGP Part 3 - Avoiding The Traps Of The Past | Ninjette Newsbot | Motorcycling News | 0 | January 10th, 2009 04:00 AM |
[kropotkin thinks...] - Saving MotoGP Part 1 - Why Is MotoGP So Expensive? | Ninjette Newsbot | Motorcycling News | 0 | January 8th, 2009 01:00 PM |
