August 27th, 2009, 05:32 PM | #1 |
ahhhh
my master link snapped going about 80 and im trying to put a new one on, any hints on how to get the locking washers to snap into place, or can i assemble the chain then put it on sprockets
August 27th, 2009, 06:03 PM | #2 |
I really don't want to sound rude, but if you have to ask this question, you probably shouldn't be attempting to do something as critical as this on your own. Have it done by someone who knows how... and can show you how.
August 27th, 2009, 07:20 PM | #3 |
what master link? my chain doesn't have one. what year is your bike?
August 29th, 2009, 08:36 AM | #4 |
i managed to do it after alittle online video showed me how, not difficult at all but if ive never seen it done then it would be over my head, im a look and learn guy, and its an 08 model
August 29th, 2009, 10:43 AM | #5 |
I've changed from linkless chains to ones that use a master link, but why did you do that? obviously you didn't do it correct if it came off.
I suggest you search the Internet for the proper way to use a master link riveting tool. Make sure you use the right tool for the right job using the correct master link replacement for your chain brand and model. You're lucky you didn't kill yourself when the chain came apart. |
August 30th, 2009, 08:11 PM | #6 |
i don't believe the side plates of the chain rub anything on an 08/09. I have seen some bikes that have a chain guide catch the master link clip and pop it off if the wheel moved backwards. Conversely if a master link clip is put on backwards and it catches something while the wheel rolls forward it could pop the clip off. Again, i don't see anything on my bike that rubs the side plates on my chain, which has no master link.
August 30th, 2009, 08:58 PM | #7 |
Join Date: Aug 2009 Motorcycle(s): '08 250R (sold), 2013 300SE Posts: 276
I take it you had just replaced or had your chain replaced as most stock chains are always riveted on from the factory. I just replaced mine. Stock was riveted, replacement is spring clip masterlink. Wasn't to worried about using this kind as our bikes are low hp/torque if it was a 100hp bike definitly would use a rivet on masterlink. Just make sure you have the retaining clip all the way seated in the grooves and is pointed in the right direction, which I gather the video showed. Have about 4000kms on my chain since I replaced it, no problems.
