June 2nd, 2013, 10:57 AM | #1 |
Join Date: May 2012 Motorcycle(s): 2011 Ninja 250R Special Edition (sold), 2017 CRF250 Rally Posts: 384
Race tech valves and springs vs. spacers
Hell-O there,
Next Saturday will be my first day on a race track, I received a sport riding beginner course. I'm quite excited but a bit nervous too. Can't wait to learn some new techniques and having the chance to practice them in a safe environment and under supervision. I think it will be a good thing for me... But until then, I have to prepare my Ninjette for that day. Well, not much to prepare, but some upgrade that will make the day better. First, I'll change my IRC stock tires for some Avon Roadriders. But, my biggest concern is about my fork, I had some troubles with my fork seals, but after having the fork tube "sanded" and all the seals and bushings changed, it's not leaking anymore. But my fork still feels kind of "mushy", even with the race tech springs and valves. We used the recommended oil weight, the right quantity. Our only concern might be about the spacer needed to "fill the gap", not the one you put as preload. Does anyone would know what length they used? I'd like to compare to see if you got our calculation right, or if we missed something when trying to understand the explication in English. Thanks for you help. |
June 2nd, 2013, 11:40 AM | #2 |
Please, provide a link to the "the explication in English", so we can help you better.
As far as I know, the length of the spacers is determined by the sag of the front suspension when loaded as ready for the track (30~35 mm). The length of your springs + spacers should be the same as in the stock suspension, regardless the rate of the new spring. http://faq.ninja250.org/wiki/Where_c...oad_spacers%3F With emulators, the suspension should be soft for quick inputs (like road ripples) and harder for slow inputs (like hard braking).
June 2nd, 2013, 11:48 AM | #3 |
From what I understand, I have to kind of spacer to put back. The one that will make the race tech emulator valve and race tech springs the same height as the OEM springs and spacers.
From what I read, those after market springs are not made for only one model, they are made for several, so they don't have the same length as the OEM. The other one is to get the right preload for the sag. That one is given when I go to their web site. I'll come back later with the English web page, I had to fiddle around to find it. Thanks, |
June 2nd, 2013, 07:25 PM | #4 |
Join Date: Mar 2012 Motorcycle(s): Ninja 250r 2010 SE Posts: 573
You don't need extra spacers.
You can put use them but. Basically an extra spacer will give you more preload. If it feels mushy and you have race tech valves then you can adjust them. I would try a heavier weight oil then what you are using. If it feels mushy on both compression and rebound then you need a heavier oil. Do you know how much fork travel you are using? Are you using all the available fork suspension? |
June 3rd, 2013, 07:22 AM | #5 |
Well,
I'm back... Here's the sheet that might have caused us translation/understanding problems. http://www.racetech.com/page/title/F...20and%20Actual For the oil weight, I'm using 15wt in... for the spacers, I'll start with the one that will make the Race tech springs and valves the same height as the OEM configuration, if I don't have the same, my preload spacer might be not doing its job perfectly. Once, I'll have that cleared, I'll attack the valve adjustment. Thanks, |
June 3rd, 2013, 07:36 AM | #6 |
Fast-Guy wannabe
MOTM - Jan '13
Stock preload 22mm is a bit much for springs of the correct rate. I'm going to make a thread tonight titled Rojoracing53's front suspension setup and in it ill cover all this. I will say that RT suggestions were WAY off of what I ended up finding worked for track riding.
June 3rd, 2013, 10:54 AM | #7 | |
http://translate.google.com/ I don't think that this sheet applies to your case, if you are installing valve emulators. That article is for cartridges that have extra soft rebound springs inside (which pre-load compression should be considered). That is not the case of our Ninjettes: you will not extend the forks by adding pre-load. Are you installing valve emulators and springs or something else?
June 3rd, 2013, 11:03 AM | #8 |
Fast-Guy wannabe
MOTM - Jan '13
Ignore the top out springs in the measure of preload. Our bikes don't have long soft top out springs so its not a factor for us. I learned this from calling RT and asking some details in regards to that confusing sheet.
June 3rd, 2013, 12:27 PM | #9 | |
I aleready have the emulators and springs in it... Just want to make them work, like I think they should... So, I'll try to check everything again, with the help of ninjette.org, hopefully, it will be better tune by this saturday... |
June 3rd, 2013, 12:40 PM | #10 |
Translate these too:
http://www.racetech.com/page/title/E...Tuning%20Guide http://www.racetech.com/page/title/E...%20They%20Work
June 4th, 2013, 08:04 PM | #11 | |
I'll go with different approach, I fetched my OEM springs and spacers, they're 420mm and 100mm long. I'll try to get the race tech spring length and emulator thickness. By getting the difference between the OEM stuff and the race tech parts, I should get the spacer length I need. I wish I had any kind of a garage, doing those things in the back alley makes it difficult to work, since I can't leave anything open or in pieces. So the more specs I can find, the easier and faster it is for me to go work on my bike. Once again, thank for your help and patience. |
June 4th, 2013, 08:13 PM | #12 | |
Fast-Guy wannabe
MOTM - Jan '13
June 4th, 2013, 08:32 PM | #13 |
I'm at 200 lbs and I took the .70 kg\m springs
For my recommendation, oil level should be at 140mm, oil weight 15wt, 3.0 turns on the emulator valve spring preload and a 10mm spacer for the fork spring preload. By taking a look at the spring rate, I found out the spring length 370mm, so I'll just need the emulator thickness now to get my spacer length. Thanks Rojo for making me dig through my old boxes... |
June 4th, 2013, 08:41 PM | #14 | |
Fast-Guy wannabe
MOTM - Jan '13
June 4th, 2013, 08:49 PM | #15 |
Tabarnak! Et Putaing de merde...
I can understand why everything is so mushy... A bit late to order some heavier rate... Like you wrote, they were on really good stuff... Well I guess, I'll try to do the I can with what I have... Thanks... Off to bed now... Well I think, they don't put the right weight of the bike... They state 304 dry, but with 374 (curb weight), I get .85kg for a novice rider doing street. |
June 4th, 2013, 09:09 PM | #16 | |
Fast-Guy wannabe
MOTM - Jan '13
Just sell you .70kg spring to some other noob unlucky enough to have read my posts . Ill be selling my .80kg spring to Cameron who is 30lbs lighter then me. |
June 5th, 2013, 06:36 AM | #17 |
Fast-Guy wannabe
MOTM - Jan '13
Here read this
http://www.ninjette.org/forums/showt...200#post695200 |
June 5th, 2013, 07:27 AM | #18 |
Thanks,
Your write-up clarifies things a lot for me... Now, got to find tube and washers... I know it is recommanded to lift the front by the triple. but in my back alley, I don't have acces to that kind of front stand, I only have the one that raise by the fork, will I be able to change my spacer anyhow? Or am I asking for trouble? |
June 5th, 2013, 07:34 AM | #19 | |
Fast-Guy wannabe
MOTM - Jan '13
June 5th, 2013, 07:35 AM | #20 |
Fast-Guy wannabe
MOTM - Jan '13
I hate the idea but how about that idea of have the bike on a rear center stand and using a floor jack under the motor to lift the front end?
June 5th, 2013, 08:11 AM | #21 |
I haven't pull anything yet... I got my bike last year and the front end bugged me at the start. I have a friend's friend who is a bike mechanic. So he changed the spring last year and installed the emulator. Since I knew nothing about motorcycle and I wasn't equipped, it was better for me and the bike.
But I was plagged with leaking oil seals, so the front end worked better, but never as my moutain bike fork did, so I want to put my nose there, to see what was done and how it was done. Since I'm supposed to go on a track this week end, I wanted to see if I could do something to make it better. He told me that too, that I could put the rear on my stand and use a car jack to lift the front, but I'm a bit cold about this idea, I don't want to crack or break the bottom of my fairing. So that's why i was asking if I could get away with it by keeping the front wheel on the ground. |
June 5th, 2013, 08:20 AM | #22 |
You are welcome, Thomas
You are now in better hands; follow Rojo's advice, he is very good. Just in case it could help you: http://www.ninjette.org/forums/showthread.php?t=136034
June 5th, 2013, 08:41 AM | #23 |
Fast-Guy wannabe
MOTM - Jan '13
Alright so with the rear center stand holding the bike and the front wheel on the ground you can do everything to the front end except change the oil or set the oil height. What you'll do is work on one side at a time and you'll need at least one other helper to compress the fork cap so you can pull the clip(this is going to be a bitch with the front wheel on the ground) and possibly another friend to try and hold the other handlebar up to relieve some of the weight. Once you get on cap off you need to have your helpers lift the front wheel off the ground long enough for you to measure the distance from the top of the preload spacer(the thing touching the bottom of the fork cap you just removed) to the top of the Crome fork tube. Once you get this number subtract it from 20mm and that will give you your current preload setting. From there you can pull out the spacers and springs then fish out the emulator with a long grabbing tool, its going to be under the oil level so you won't see it. Once you have it out you can make adjustments to it as well as change out the colored springs to the other rate.
Just so you have a base you should get two people to help you set sag so you at least know where your at. As a reference Jiggles is still running the stock front end and I'd say at this point he above your average street 250 rider on track and be doesn't experience any of the chattering problems I or many of the other racers feel. Although he out weighs me by 40lbs(200lbs as well) that difference in weight is nothing compared to the extra stress I apply to the suspension with my faster laps times. I'd say if you not up to racer speeds just yet you may be fine at the track but I guarantee with a better setup you'll grow into a faster pace more easily. |
June 5th, 2013, 09:15 AM | #24 |
Well,
Right now, I just wanted to take a look at the preload and the spacer, I just want to make and try to make the front end a little stiffer for saturday. I'm sure I'll be fine on the track, I don't think I'll beat anyone out there, it's more of and advance course, I think, than pure race course. I was just uneasy with the front end diving that much under break. For the whole thing, I'll ask my good friend if he can help me, he has a garage and he is better equipped than me. So we'll be able to raise the front by the triple and take our time to adjust those things. but it will be another day. But I'll keep you posted. Very appreciated. |
'08 Fork Springs and Spacers | Countersteer | Motorcycle-related | 0 | June 14th, 2012 06:17 PM |
race tech springs | sombo | 1986 - 2007 Ninja 250R Tech Talk | 4 | March 27th, 2011 11:14 AM |
[sportrider - tech] - Ask The Geek: Carbon Fiber Wheels And Pneumatic Valves | Ninjette Newsbot | Motorcycling News | 0 | April 13th, 2010 04:00 AM |
[sportrider - tech] - Ask The Geek: Carbon Fiber Wheels And Pneumatic Valves | Ninjette Newsbot | Motorcycling News | 0 | March 29th, 2010 11:40 PM |
Race Tech Fork Springs | wyckedflesh | 2008 - 2012 Ninja 250R Tech Talk | 10 | April 28th, 2009 08:27 PM |
