Old March 29th, 2013, 01:50 PM   #1
05Ninjette89
Motorcycle(s): 05 Kawasaki Ninja 250R
Can I adjust the Speedo?
My Speedo seems to be showing me going slower than i actually am. Its there any way i can adjust it or should i take it to my local bike shop?
05Ninjette89 is offline   Reply With Quote
Old March 29th, 2013, 02:15 PM   #2
DaBlue1
Long Time Rider
DaBlue1's Avatar
It is a mechanical gear driven instrument attached to the front wheel. No adjustments can be made to calibrate it. The speedo can be around 5-7 mph off. This is normal for many gear driven speedos. Electronic ones tend to be more accurate.
Old March 29th, 2013, 02:18 PM   #3
05Ninjette89
It is attached to the front wheel, and that range is exactly what its Off by dependin on the mph so no adjustments can be made? That sucks looks like I'll have to compensate then. Thanks for the speedy reply :-)
Old March 30th, 2013, 09:10 AM   #4
j98sprint
Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900
You say it "seems" to be off. If you're not using a GPS then a good way to check your speedo is to get on I-75 and ride next to a late model Honda Civic.
You can see the digital MPH display on the dash quite clearly. It's big and bright.
j98sprint is offline   Reply With Quote
Old March 30th, 2013, 09:47 AM   #5
05Ninjette89
I just gps'd the bike on my phone and it's about 1mph off at 30mph.
Last futzed with by 05Ninjette89; March 30th, 2013 at 09:47 AM. Reason: spelling error
Speedo Drd, Speedometer and Odometer Accuracy-Speedo Healer/drd Klondike1020 General Motorcycling Discussion 8 August 17th, 2014 12:23 AM
My speedo is way out! Damo990 2013 - 2017 Ninja 300 Tech Talk 14 March 5th, 2014 06:54 AM
Speedo not working LR1914 2008 - 2012 Ninja 250R Tech Talk 5 June 24th, 2013 01:01 PM
Speedo Came Off! komohana 1986 - 2007 Ninja 250R Tech Talk 8 May 29th, 2011 01:55 PM
My speedo is off??? Kitdog 2008 - 2012 Ninja 250R Tech Talk 3 June 28th, 2010 03:24 PM
