May 30th, 2017, 09:15 PM | #1 |
Slow speed maneuvers overheating
So recently I purchased an 09 ninja 250r as my first bike. I went up to where the local msf course was held and started practicing my figure 8's. After sometime I looked down and saw my idiot light on. I did not hear my fan turn on but I also never have so I'm not sure what it sounds like.
After the light kicked in I turned it off let it sit for a few minutes and took off never to see the light again for the rest of the day.(including no slow speed maneuvers for prolonged time). I'm trying to figure out if this is a fan issue or if it is something else. Idk if it is the fan because it was below 60 degrees F and I was still moving just very slowly |
May 31st, 2017, 06:25 AM | #2 |
Join Date: Jul 2016 Motorcycle(s): 2014 Ninja 300 ABS, 2007 Yamaha FZ6 Posts: 210
Keep an eye on your fan. Whenever you're at a stop light or doing those low-speed maneuvers, look down to see if the fan is spinning, especially when you see the light come on.
If the fan isn't spinning, it could be a bad sensor/switch. |
May 31st, 2017, 07:05 AM | #3 |
Have you checked the oil and coolant levels?
Does the '09 have a "high temp warning light"? I didn't think it did. |
May 31st, 2017, 12:09 PM | #4 | |
From what I can tell the fan has not come on. How do you test which part of the fan is going bad. It does spin freely so it's not jammed |
May 31st, 2017, 12:22 PM | #5 |
If 12v applied to the fan motor makes it spin, it's OK. If 12v never gets to the fan, the temperature switch or wiring is bad. You could connect a test lamp to the fan motor terminals with it still connected as normal, and see if you can get the test lamp to come on. You could also take out the temp switch and put it in boiling water while reading its resistance, and see if it ever closes its contacts.
Or another simple test you devise. |
May 31st, 2017, 12:50 PM | #6 | |
I'm pretty sure you could ground the wire that goes to the temperature sending unit and that would make the fan start (ignition ON, but engine doesn't need to be running, and after you've confirmed that the fan will run when powered). If that does start the fan, it would tell you the temperature sending unit is bad. |
May 31st, 2017, 02:15 PM | #7 |
Welcome to the board!
June 1st, 2017, 09:18 AM | #8 |
Thanks everyone for the quick replies. Will test out in a couple days when I'm off and will update.
Off topic question: I have a hand full of questions regarding this bike. I'm trying to figure out if the chain needs replacing or the tires because they have cracks in the sidewalk. Is it frowned upon to keep posting topics in regards to these questions or just make one topic with all questions |
June 1st, 2017, 09:43 AM | #9 |
The advantages of making separate threads as new questions arise are less confusion, and if you make good thread titles, others can find them later if they have the same questions.
Cracks in the sidewalk? Those are expansion joints. Cracked sidewalls are a sign of deterioration of the rubber, but it's up to you to decide when you're not confident in the tires any more. Depending on how bad they are, it might be time to get new, safer tires. Here's some good information about chains: https://faq.ninja250.org/wiki/Final_Drive |
June 1st, 2017, 11:19 AM | #10 |
There's no question in my mind about tires in that condition - they should be replaced immediately or sooner.
June 1st, 2017, 11:29 AM | #11 |
It just depends on if they're a few slight, almost microscopic cracks or bigger ones that indicate serious deterioration. Without closeup photos, I don't know which it is.
2 slow speed crashes after changing tires | kekdamar | !%@*#$%!)@#&!%@ I crashed! | 11 | May 2nd, 2017 08:42 AM |
Slow speed balance | cadd | Riding Skills | 5 | May 28th, 2016 07:18 PM |
Slow throttle response and slow return to idle help | Crriiissss | 1986 - 2007 Ninja 250R Tech Talk | 22 | August 7th, 2013 12:26 AM |
Throttle hand position for low speed maneuvers | ForceofWill | Riding Skills | 3 | December 26th, 2011 10:27 AM |
[motorcyclistonline] - Drawing the Line - Motorcycle Marketing Maneuvers | Ninjette Newsbot | Motorcycling News | 0 | July 2nd, 2010 12:00 PM |
