Old February 13th, 2013, 01:34 PM   #1
Rekognize
Rekognize's Avatar
Motorcycle(s): Ninja 300
Wheel Bearings: Identical to 250!
Hey folks,
Just wondering if the front and rear wheel ball bearings are similar to the 250s?
Dimensions:
2x Front - 6202 BEARING-BALL,15X35X11 Item#: 92045-0734
1x Rear - 6203 BEARING-BALL,17X40X12 Item#: 92045-0732
1x Rear - 6303 BEARING-BALL,17X47X14 Item#: 92045-0733
1x Coupling Dampner - 6205 BEARING-BALL,25x52x15 Item#: 601B6205
You're better off going to your local Motion Industries and ask for NSK, SKF, or Fafnir bearings.
My Ninja 300 Build Photoblog
Greater Toronto Area 250/300 Riding Group
Last futzed with by Rekognize; February 27th, 2013 at 11:25 AM.
Rekognize is offline   Reply With Quote
Old February 13th, 2013, 01:52 PM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Originally Posted by Rekognize View Post
Hey folks,
I notice the part #s are different..
300 BEARING-BALL,15X35X11 (92045-0734)
250 BEARING-BALL (601B6202UU)
Thanks in advance!
I could find out but first.
Why?
Old February 13th, 2013, 02:11 PM   #3
Rekognize
Rekognize's Avatar
Going to get the wheels powdercoated
Old February 13th, 2013, 02:14 PM   #4
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Ok so I just measured my 250s bearing and they're 15mm ID x 35mm OD x 11mm thick. So it sound like they're identical.
Old February 13th, 2013, 02:24 PM   #5
Rekognize
Rekognize's Avatar
Thanks a lot!
I assume the circlip and seals are identical as well?
Old February 13th, 2013, 02:34 PM   #6
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
250 only have the seal on one side and it should be the same as for the other side the 250 uses the wheel speed hub spacer doohickey as a dust seal.
Old February 27th, 2013, 09:32 AM   #7
Rekognize
Rekognize's Avatar
Dimensions:
2x Front - BEARING-BALL,15X35X11 Item#: 92045-0734
1x Rear - BEARING-BALL,17X40X12 Item#: 92045-0732
1x Rear - BEARING-BALL,17X47X14 Item#: 92045-0733
1x Coupling Dampner - BEARING-BALL,25x52x15 Item#: 601B6205
Old April 21st, 2013, 02:11 AM   #8
red26
Motorcycle(s): Ninja 250R, GSXR600 K4, KX250F,NSR150SP, Yamaha TZM150
Any ideas on where to source for the ceramic bearings?
red26 is offline   Reply With Quote
Old April 21st, 2013, 05:04 AM   #9
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Bicycle shop owner in town seems to hate ceramic bearings becuase he says there service life under shock load sucks. He says in the cranks they are great but in the wheels they tend to fracture and fail sooner then steel. I can't say if this is true but something to look into and be weary of since the load on a motorcycle is much greater.
The more something spins the greater effect upgrading to ceramic will have, example steering head upgrade is pretty pointless. I wonder how ceramic would fair as crank bearings?
Old April 21st, 2013, 06:37 AM   #10
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
http://worldwidebearings.com/
Contact Dave Conforti 800-575-3220 Please tell him Eric aka Racer X sent you.
Worlds fastest 250 ninja
3 Rear Wheel Bearings. Where Does The 3rd Go? az3200 1986 - 2007 Ninja 250R Tech Talk 5 June 15th, 2014 07:21 AM
front wheel bearings snot 2013 - 2017 Ninja 300 Tech Talk 12 May 14th, 2014 05:57 PM
replace wheel bearings cuz 2008 - 2012 Ninja 250R Tech Talk 7 May 3rd, 2013 05:03 PM
Full set of new double sealed wheel bearings Zim Motorcycle-related 11 April 21st, 2010 07:47 PM
