February 13th, 2013, 01:34 PM | #1 | |
Wheel Bearings: Identical to 250!
Hey folks,
Just wondering if the front and rear wheel ball bearings are similar to the 250s? Quote:
My Ninja 300 Build Photoblog Greater Toronto Area 250/300 Riding Group Last futzed with by Rekognize; February 27th, 2013 at 11:25 AM. |
February 13th, 2013, 01:52 PM | #2 |
Fast-Guy wannabe
MOTM - Jan '13
February 13th, 2013, 02:11 PM | #3 |
Going to get the wheels powdercoated
My Ninja 300 Build Photoblog Greater Toronto Area 250/300 Riding Group |
February 13th, 2013, 02:14 PM | #4 |
Fast-Guy wannabe
MOTM - Jan '13
Ok so I just measured my 250s bearing and they're 15mm ID x 35mm OD x 11mm thick. So it sound like they're identical.
February 13th, 2013, 02:24 PM | #5 |
Thanks a lot!
I assume the circlip and seals are identical as well?
February 13th, 2013, 02:34 PM | #6 |
Fast-Guy wannabe
MOTM - Jan '13
250 only have the seal on one side and it should be the same as for the other side the 250 uses the wheel speed hub spacer doohickey as a dust seal.
February 27th, 2013, 09:32 AM | #7 |
Dimensions:
2x Front - BEARING-BALL,15X35X11 Item#: 92045-0734 1x Rear - BEARING-BALL,17X40X12 Item#: 92045-0732 1x Rear - BEARING-BALL,17X47X14 Item#: 92045-0733 1x Coupling Dampner - BEARING-BALL,25x52x15 Item#: 601B6205 You're better off going to your local Motion Industries and ask for NSK, SKF, or Fafnir bearings.
April 21st, 2013, 02:11 AM | #8 |
Join Date: Apr 2013 Motorcycle(s): Ninja 250R, GSXR600 K4, KX250F,NSR150SP, Yamaha TZM150 Posts: 68
Any ideas on where to source for the ceramic bearings?
April 21st, 2013, 05:04 AM | #9 |
Fast-Guy wannabe
MOTM - Jan '13
Bicycle shop owner in town seems to hate ceramic bearings becuase he says there service life under shock load sucks. He says in the cranks they are great but in the wheels they tend to fracture and fail sooner then steel. I can't say if this is true but something to look into and be weary of since the load on a motorcycle is much greater.
The more something spins the greater effect upgrading to ceramic will have, example steering head upgrade is pretty pointless. I wonder how ceramic would fair as crank bearings? |
April 21st, 2013, 06:37 AM | #10 |
MOTM - Sep '18, Feb '16
http://worldwidebearings.com/
Contact Dave Conforti 800-575-3220 Please tell him Eric aka Racer X sent you.
3 Rear Wheel Bearings. Where Does The 3rd Go? | az3200 | 1986 - 2007 Ninja 250R Tech Talk | 5 | June 15th, 2014 07:21 AM |
front wheel bearings | snot | 2013 - 2017 Ninja 300 Tech Talk | 12 | May 14th, 2014 05:57 PM |
replace wheel bearings | cuz | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 3rd, 2013 05:03 PM |
Full set of new double sealed wheel bearings | Zim | Motorcycle-related | 11 | April 21st, 2010 07:47 PM |
