Old November 23rd, 2010, 04:02 PM   #1
indr
Coolant Drain Bolts
There are two of them right?
I found the first one, on the left leg side close to the gear shifter.
I can't find the second one and have no clue where it is. I'm looking at he ****** B&W pictures in the Service Manual page 2-44. The picture at the bottom of the page. I have no clue where the hell that is. Help?1!
indr is offline   Reply With Quote
Old November 23rd, 2010, 04:53 PM   #2
indr
Never mind. Found it.
Front of the engine, between the two cylinders.
Old November 23rd, 2010, 05:07 PM   #3
austexjg
austexjg's Avatar
Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r
How about some pics of the bolts for reference?
austexjg is offline   Reply With Quote
Old November 23rd, 2010, 05:58 PM   #4
indr
Good idea.
Here's the one on the left leg side of the bike. Just under the engine. Since I didn't know what or where the hell the water pump was, I'm going to assume most people that start working out on this bike won't either. So, it's to the left of the shifter. With the bike on it's sidestand, you've got to duck down a little to see it. Once you do, you'll see three bolts. It's the one in the middle.
It's the one that has a drop of water coming out of it.
To find the next one, approach the bike from between the front tire and the exhaust pipes. Now turn your head towards the engine and look right between the two pipes. There is a single bolt right between the two cylinders.
Old November 24th, 2010, 05:57 AM   #5
randomwalk101
self wrencher
randomwalk101's Avatar
http://www.kawiforums.com/ninja-250r...sh-refill.html
Old November 24th, 2010, 06:01 AM   #6
randomwalk101
self wrencher
attachment of diy
Coolant drain plug thread size Kneedragon88 2008 - 2012 Ninja 250R Tech Talk 1 June 7th, 2014 12:06 PM
Coolant drain bolt. desperately need help coraya 2008 - 2012 Ninja 250R Tech Talk 16 June 2nd, 2014 06:35 PM
Should I drain the carbs even though... Runeknight95 2008 - 2012 Ninja 250R Tech Talk 6 March 14th, 2013 02:56 PM
Where to get sealing washers for coolant drain bolts? WhiteRice 2008 - 2012 Ninja 250R Tech Talk 1 November 11th, 2011 05:03 PM
Okay, so what's that OTHER drain plug for? adouglas 2008 - 2012 Ninja 250R Tech Talk 5 August 23rd, 2009 07:18 PM
