February 11th, 2011, 11:39 AM | #1 |
Friend's newly purchased 2005 EX250F: Neglected battery issue
My friend recently bought a neglected pre-gen and promptly got the battery tested at an auto parts store. They said it was OK, but it still only starts with a jump start. When he tries it without the jumper cables the lights all come on and look bright but all he gets then is a click and they dim. He left the battery at the auto parts store for testing overnight, so I assume it's fully charged like he says that it is. What could cause this if the battery is tested good?
FWIW, I can't look at it directly because we now live on opposite sides of the country. Edit: I see that he registered as case86 but I'll ask these questions for him anyway. I'm moving stuff from this thread yet again because of the inability to edit the title. Ignore the pics below. I moved those questions to another thread due to inability to edit the thread title. Also, he just sent me this: Last futzed with by CZroe; February 16th, 2011 at 05:32 AM. |
February 11th, 2011, 11:56 AM | #2 |
Seems to me that if the bike starts with jumper cables, then the battery is no good. Purchase a quality battery and have him pick a tender to use after that. Problems solved!
February 11th, 2011, 12:15 PM | #3 |
Funny. I had a car battery that they said was bad even though it was still working fine (had it tested when having an unrelated issue). $100 later and I was no closer to finding out why my sister's '96 Taurus wouldn't start. I believe they err on the side of profit, so I'm surprised to hear that they may have been wrong. Obviously, he doesn't want to spend money on a new battery if there is any chance that the old one is OK, so is there anything else he can try to be sure?
February 11th, 2011, 12:19 PM | #4 |
An overnight trickle charge has been known to revive some batteries...
If he has one it's worth trying. Not sure I'd invest in one just for this concern though.
February 11th, 2011, 01:47 PM | #5 |
Join Date: Nov 2010 Motorcycle(s): ex250r, vulcan 800b, k1200r Posts: 40
Remove the battery and have it load tested. It might still have 12 volts+ but not enough amperage to crank the starter. Batterymart.com sells agm (maintenacefree) battery for under $36 bucks (ytx14bs).
February 11th, 2011, 01:54 PM | #6 |
February 11th, 2011, 03:22 PM | #7 |
Thanks guys.
February 15th, 2011, 05:54 PM | #8 |
Join Date: Feb 2011 Motorcycle(s): 05 kawasaki ninja 250 Posts: 19
thanks Czer0 i have found a new thing while the jumper box is connected i can rev the bike but when i take it off it will not let me rev it anymore. also while the jumper box is connected the lights remain bright but when i disconnect it the lights dim down. i'm not sure what to do! also how often should a motorcycle battery be replaced this one is five years old!?
Last futzed with by case86; February 15th, 2011 at 07:17 PM. |
February 15th, 2011, 08:37 PM | #9 |
jumper box? exactly what are you referring to?
February 15th, 2011, 08:49 PM | #10 |
You can bring the battery to any automotive store (autozone, o'reilly's, etc) and they can test it for free. If the battery is still good, they'll charge it up for you as well.
By jumper box, he may be referring to a portable battery that can jumpstart? |
February 16th, 2011, 05:34 AM | #11 |
OK, he just sent me this:
Yup. He did have it tested at a store and they said it was good, hence the thread wondering why a "good" battery still won't start his bike when a jumper box can. |
February 16th, 2011, 05:38 AM | #12 |
He needs to go to another store and have it tested. If I were a gambling man, his battery is garbage... Once we get it where it can be started on its own power, we can address any other concerns.
February 19th, 2011, 01:44 PM | #13 |
I just found out theirs no problem with the battery according to a mechanic he said theirs a bad connection so I'm back to needing the carbs cleaned and a wind screen
Posted via Mobile Device |
February 19th, 2011, 01:50 PM | #14 |
February 19th, 2011, 02:14 PM | #15 |
The battery post area
March 16th, 2011, 05:47 PM | #16 |
I bought a new battery it got rid of the problem so it was just a bad battery still need to clean the carbs
March 17th, 2011, 05:59 AM | #17 |
Thanks for the update. Now, I'm curious to see if disconnecting a battery post after starting causes the same thing in other Ninjette's because this did seem pretty weird!
battery/electrical issue | MagicMike | 2008 - 2012 Ninja 250R Tech Talk | 9 | May 14th, 2014 07:52 PM |
helping a friend start her 250, quick battery question. | cerberusrex25 | 1986 - 2007 Ninja 250R Tech Talk | 15 | July 30th, 2012 07:38 PM |
Battery part issue | checho323 | General Motorcycling Discussion | 2 | May 30th, 2012 09:08 PM |
Neglected 2005 250. Ready to fire her up? | lougar62 | 1986 - 2007 Ninja 250R Tech Talk | 26 | February 14th, 2011 03:33 PM |
Friend's '05 EX250F: Carbs, J-shock, mirrors, battery, windscreen, blinkers, etc Qs | CZroe | 1986 - 2007 Ninja 250R Tech Talk | 0 | February 9th, 2011 09:03 PM |
