January 13th, 2015, 01:49 AM | #1 |
Join Date: Dec 2013 Motorcycle(s): Ninja 250 (2001) Posts: 14
sluggish acceleration
i was riding tonight when i noticed my acceleration started going in and out as if i was running out of gas. when i got home i realized i had just gotten gas and my tank was more than halfway full.
last time i gassed up was friday (it's currently monday night) and it was raining the past 2 days. it was suggested that either something was in my tank and is clogging something or rain got in my tank and is messing with the gas. i thought maybe something was just acting up and i tried to test ride it about 20 minutes ago and the problem got even worse. any suggestions or walkthroughs on how to trouble shoot/fix the suggested errors? edit: if it helps at all, the carbs were cleaned very recently. obviously before i put gas in but within 2 months i believe. |
January 13th, 2015, 03:54 AM | #2 |
raining the past two days. Gas is less dense than water, so it 'floats' on top.
therefore water drains to the bottom. Drain your carb bowls to get any water out of them. Then try again. |
January 13th, 2015, 11:55 PM | #3 |
thank you. tried to no avail and the bike was running worse this morning. when in neutral it doesn't even rev past 3k, so it was suggested i clean the carbs.
after a long process i finally pulled them out and cleaned it. there wasn't a lot of rust or anything since they were recently cleaned but i think something was in the gas tank. a little black flake fell through one of the jet holes and was big enough to block. i'm hoping that was the problem, but i can't put it back in yet. now i've got a bigger problem, one of the collars somehow fell out. i have no idea how, but it fell out when i was cleaning. i got hold of an old carb but the collar is not coming out, any ideas? |
January 13th, 2015, 11:56 PM | #4 |
http://faq.ninja250.org/wiki/File:Jim_carb_2.jpg
this is the piece, btw |
January 15th, 2015, 10:01 AM | #5 |
Join Date: Apr 2013 Motorcycle(s): 2005 Ninja 250, 2006 SV650N Posts: 642
You sure it's not still in there mine won't come out even when I tip it over usually.
http://www.ebay.com/itm/EX250-EX-250...c64da1&vxp=mtr |
January 19th, 2015, 03:07 PM | #6 | |
http://faq.ninja250.org/wiki/How_do_...n_the_carbs%3F
No acceleration | Ninjamania | 2008 - 2012 Ninja 250R Tech Talk | 10 | November 12th, 2014 01:07 PM |
Sluggish rev, erratic idle, dies with throttle | Fappy | 2008 - 2012 Ninja 250R Tech Talk | 12 | October 8th, 2012 06:20 AM |
my 2010 ninja is running sluggish (HELP) | venmichaels | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 28th, 2012 07:13 AM |
Sluggish starting when WARM | n4mwd | 1986 - 2007 Ninja 250R Tech Talk | 4 | October 12th, 2011 05:10 AM |
[crash.net - WSBK] - Rea overcomes sluggish start to go front row | Ninjette Newsbot | Motorcycling News | 0 | July 25th, 2009 11:50 AM |
