May 19th, 2014, 04:08 PM | #1 |
Cam Chain Issues, need advice
I recently had some service done to my '06 Ninja 250 because I noticed a oil leak when I was at work. I saw a puddle of oil when I got out of work and took it home since there was still enough oil in the screen. About 30 minutes on the freeway and I get off and I noticed when I came to a stop a few streets down that the oil light came on the quickly off. Took it to the shop to get it fixed and had them also do a valve adjustment since it was about 6k miles since the last one. He said I had an issue with my cam chain and that it would eventually cause me to get a new engine. Today when I was riding on the freeway the throttle gave out and I took it off and let it sit for a few minutes and it started up with no issue and made it to work fine, but with a slight ticking sound. Not sure if you guys have any advice for me on this issue, but I am fairly new and have been riding for about 6 months. Only has about 12k miles on it and dropped once.
May 19th, 2014, 06:49 PM | #2 | |
You bike is too young to have any issues. It only takes some adjustment and lubrication. What year is your bike?
May 19th, 2014, 06:54 PM | #3 |
used engines are only $300ish so don't worry. if you want to split the case to replace the chain its not hard. the chain is only like $40 and bolts are cheap. i would clean the cam chain adjuster really well and put it back and see if it helps
May 21st, 2014, 01:14 PM | #4 |
The bike is a 2006 model with only 12500 miles on it. The mechanic said it was probably from the previous owner riding hard without oil. I know that I got it at 6,000 miles and the previous owner had it garaged for quite a bit. The ticking/clanking noise is louder during idle or high rpm. I know I want to upgrade to the ninja 650 eventually, but just dont have the funds currently. I dont know too much about fixing or the tools necessary. Think a novice can take on these repairs?
May 21st, 2014, 05:49 PM | #5 | |
Low funds mean that your only option is learning how to do it yourself. On top of that, it is hard to find a mechanic that tests his ideas before assuming and guessing, as this man has just done. We offer the know-how if you put the tools and the time and the patience.
May 21st, 2014, 07:01 PM | #6 |
I meant the funds for a brand new vehicle, but I know what you mean. I would definitely prefer to work on my bike then have someone else do it for me. I guess the learning process is just wrenching on it and try and figure it out. Would it be helpful to upload the sound Im hearing? Also what kinda tools are necessary?
Thanks for the advice. |
May 21st, 2014, 07:47 PM | #7 | |
May 21st, 2014, 07:54 PM | #8 | |
Please, read these: http://faq.ninja250.org/wiki/I_Need_...or_Tools/Parts http://faq.ninja250.org/wiki/New_Rid...ht_a_Ninja_250 The other important thing that you need is a flat clean surface with some illumination and protection from Sun and rain.
Cam Chain Replacement Advice | jayman87 | 1986 - 2007 Ninja 250R Tech Talk | 34 | April 21st, 2018 06:44 AM |
Changing cam chain | scorch | 2008 - 2012 Ninja 250R Tech Talk | 17 | April 28th, 2014 08:46 AM |
cam chain tensioner | kittyslasher | 2008 - 2012 Ninja 250R Tech Talk | 2 | June 16th, 2013 09:17 AM |
Video Cam advice | Old Guy on a '08 | General Motorcycling Discussion | 85 | November 25th, 2012 09:26 PM |
stretched cam chain | alex.s | 2008 - 2012 Ninja 250R Tech Talk | 22 | June 28th, 2012 06:52 PM |
