June 23rd, 2012, 07:56 AM | #1 |
Join Date: Jan 2012 Motorcycle(s): 02 zx-12r, 13 zx-10r abs Posts: 245
FS: sprocket carrier bearings, extra seals 08+
some new leftovers from an all balls and a pivot work bearing kit. fits the sprocket carrier. $5.50 shipped priority mail 50 states
Last futzed with by GlassAnkles; June 23rd, 2012 at 09:13 AM. |
June 23rd, 2012, 10:22 AM | #2 |
I'd get them if they were for the pregen. That said, how do you replace bearings and seals without special tools like the service manual calls for? I'd love to see a DIY. It'd be especially useful for those of us interested in powder-coating (anything we can do ourselves helps lower the cost).
June 23rd, 2012, 12:13 PM | #3 |
They may actually fit the pregen, i believe the part numbers are the same.
I use a cheap tusk brand bearing puller, takes alot of the struggle out of removal. Its a good investent of 89, cheaper if you can find a coupon. http://www.rockymountainatvmc.com/p/...earing-Remover Without the tool, if you move the spacer thats between the bearings of the wheels, you will have a good shot at getting them out. Just find a long rod and proceed to push them out from the opposite side, a little heat will help also. Check your local auto parts stores, most let you rent tools for free. |
June 24th, 2012, 03:05 PM | #4 | |
Now, you say that these are for the sprocket carrier, right? In that case, I don't think I could use them because I wouldn't have to do anything to the sprocket carrier to PC the rims (entire carrier and cush drive can be removed independently). I'm now not so sure that I am going to get it powdercoated job but, I'm still curious. Now, along those lines, why did you do a bearing job? |
June 24th, 2012, 06:20 PM | #5 | |
- i bought those cheap V-rossi wheels from overseas, they include cheap-o bearings that need upgraded |
June 24th, 2012, 06:41 PM | #6 | |
June 24th, 2012, 06:52 PM | #7 |
June 24th, 2012, 07:15 PM | #8 |
No! Not enough pics of those wheels on our bikes. Haven't seen any on US bikes.
GLWS |
June 24th, 2012, 08:09 PM | #9 |
who is the manufacturer of the bearings
June 24th, 2012, 08:51 PM | #10 |
Sprocket carrier bearing replacement | The_big_dill | 1986 - 2007 Ninja 250R Tech Talk | 6 | May 27th, 2014 10:08 AM |
bearings replaced, extra seal or circlip? | The_big_dill | 1986 - 2007 Ninja 250R Tech Talk | 12 | August 4th, 2013 03:48 PM |
WTB: 08+ Sprocket Carrier and Cush Drive | SNAPPY | Items Wanted | 0 | April 4th, 2012 08:37 PM |
