Old March 27th, 2018, 08:43 AM   #41
mgentz
Board Member
I have a non oring chain as well and regularly run 200 miles in a stint. I should lokk into an auto oiler as well.
Old March 27th, 2018, 09:58 AM   #42
Originally Posted by Alex View Post
Why a non-O-ring chain on a streetbike? What is the perceived advantage in performance, chain life, or something else?
Non-O-ring chains do spin with noticeably less friction than O-ring chains, which might give a slight performance advantage. Not sure if it would be noticeable on the street or not.
I have seen (somewhere...) dyno tests that show a significant increase in power transmitted to the rear wheel with just lubricating the chain.
Non-O-ring chains typically cost half as much and last half as long - but probably longer if you really attend to them.
Old March 27th, 2018, 10:45 AM   #43
Yeah, frees up some power, but only when you're at max-throttle would the extra power make a difference (otherwise on street bike, you can just open throttle more). Weight savings of a couple pounds also really only affects a race-bike.
All the guys I've talked to on track says their 415 lasts about 1-season before needing replacement. That's with regular cleaning and oiling, but the average load is much, much higher than a street-bike.
I prefer my 428 conversion with X-ring chain. Almost as much weight-savings as 415, but lasts much, much longer. Longer than stock even.
Old March 27th, 2018, 10:50 AM   #44
Ram Jet
Ram Jet's Avatar
Why a non-"O"-ring chain on anything. I did something this past Spring I NEVER would have done in the past, I installed new sprockets on an "O" ring chain with 9,700 miles on it. There was no perceived wear on the sprockets and there is still none at 11,700 miles. I used to joke about "O" ring chains being junk - that's when I would change my entire chain/sprocket set at 18,000 miles. I no longer joke about "O" ring chains. I wouldn't be surprised to see 25-30,000 miles on the current chain and sprockets. I lube my chain every 235 miles.
Bill
Old March 27th, 2018, 10:55 AM   #45
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
this question has been thrown around quite often. granted o ring chains are great but they have drawbacks too. since i will be using motobriz oiler i don't think its a problem.
"trying not to get old"
Old March 27th, 2018, 10:56 AM   #46
maverick9611
MOTM - Feb '18
yup, on my own again. my way/against the grain.
Last futzed with by maverick9611; March 27th, 2018 at 01:12 PM.
Old March 27th, 2018, 11:08 AM   #47
I think X-ring chains are happy medium in between!
Old March 27th, 2018, 11:46 AM   #48
mgentz
Board Member
where did you get the 428 conversion package?
Old March 27th, 2018, 01:11 PM   #49
maverick9611
MOTM - Feb '18
i will do a install thread
Old March 27th, 2018, 01:50 PM   #50
Oh yeah, retaining lubricant and needing minimal maintenance is such a downside for a streetbike.
sorry about the sarcasm. But you get my point. I get it though. It's the principle of making it great instead of stopping at good. Just gotta make sure you can experience proper feedback.
Old March 27th, 2018, 02:02 PM   #51
maverick9611
MOTM - Feb '18
point taken.
Old March 27th, 2018, 02:25 PM   #52
There's an interesting interval.
Old March 27th, 2018, 02:36 PM   #53
What are the drawbacks? Weight? Cost? I understand that racing chains that you're replacing every 100 track miles can eke out a fraction of a percent better performance by being lighter and perfectly oiled prior to hitting the track. I understand on dirtbikes the stresses on the chain are low enough and you're cleaning them often enough that dirt will get them before bad oiling does. While I don't mean to be intentionally dense, I just can't understand the benefits on a streetbike. Losing the internal oiling, and now relying on a secondary system that is bound to work OK at best, seems like something most people would pay to avoid, not to gravitate to.
Which are just cool-shaped O-rings with a snazzier name, right?
Old March 27th, 2018, 02:41 PM   #54
Ram Jet
Ram Jet's Avatar
That's when I hit reserve. I mistakenly said I hit reserve in a previous post at 135 miles - duh - senior moment. I also check oil level, coolant, lights and look for loose bolts.
Kinda anal, huh?
Bill
Old March 27th, 2018, 03:08 PM   #55
No, kinda anal was correcting you when you had a senior moment. With math!
Old March 27th, 2018, 03:16 PM   #56
Sprocket Specialists. Info and part# here: http://www.rcramer.com/bikes/ex250/428.shtml
I run 18/59t sprockets to reduce chain-wrap angle as much as possible.
So far, I've gotten past 2-seasons from chain, about 70 track days total.
Changed it and flipped sprocket for this season.
Old March 27th, 2018, 03:40 PM   #57
Ram Jet
Ram Jet's Avatar
I'll be 70 in June punk - I gotta right!!
Bill
Old April 14th, 2018, 05:19 AM   #58
maverick9611
MOTM - Feb '18
the day has arrived! motobriz install! oh no! i'm putting on a non o ring chain too!
[webbikeworld.com] - Cameleon PLUS Chain Oiler Review Ninjette Newsbot Motorcycling News 0 April 28th, 2016 06:22 AM
[webbikeworld.com] - Cobrra Nemo 2 Chain Oiler Review Ninjette Newsbot Motorcycling News 0 September 24th, 2015 05:00 PM
[webbikeworld.com] - Cameleon Chain Oiler Review Ninjette Newsbot Motorcycling News 0 July 26th, 2014 05:40 PM
DIY - Scottoiler vSystem (automatic chain oiler) NevadaWolf 2008 - 2012 Ninja 250R Tech Talk 18 July 21st, 2014 08:14 AM
DIY chain oiler Ntotot Pictures 4 December 21st, 2010 10:30 AM
