February 10th, 2016, 07:40 PM | #1 |
Join Date: Dec 2015 Motorcycle(s): 2007 Hoodrat 250 Posts: 242
Fork reassembly
What's the easiest way to reassemble the forks? YouTube is pretty disappointing. I'm mainly having trouble with the clips. Is there a certain tool for the clip or just use a flathead?
This is probably basic sh!t but I just need a few pointers before I kill it with fire. Thank you sirs and ma'am. Ps: I'd appreciate if you just shared your knowledge instead of making smart remarks. Thanks again.
"Brah, you can't be looking like that on a 250, brah. You gotta mod a 250, brah. It's like the hachi-roku of bikes." |
February 10th, 2016, 07:46 PM | #2 |
Vintage Screwball
MOTM - Mar '16
If you did not drive the seal in far enough the snap ring will be a PITA.
It should go in with fingers all except maybe the last inch. If it's not that clip, which one are you talking about? The one at the top of the forks?
Goin' fast on slow bikes! |
February 10th, 2016, 07:52 PM | #3 | |
I'm pushing the cap down with another spacer. Enough room for the ring to seat on one side, but the opposite side will pop up. Off to google land. If harbor freight has the pliers, that would be just wonderful.
February 10th, 2016, 07:59 PM | #4 | |
Vintage Screwball
MOTM - Mar '16
February 10th, 2016, 08:00 PM | #5 |
Vintage Screwball
MOTM - Mar '16
Snap rings have loops in the end of the clip with a hole in them. These aren't those...I looked it up.
February 10th, 2016, 08:03 PM | #6 |
n00bie to wannabie
Join Date: Sep 2015 Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!) Posts: A lot.
MOTM - Nov '15
If it's the wire ring at the top of the forks then the snap ring pliers aren't the right tool.
To get the ring out: a pointy tool like an awl works best to get behind the ring and lever it out of the slot. To install the ring: press the cap past the slot, work one end of the ring into the slot (groove) and work around the ring with a regular flat screwdriver until the whole ring is seated in the slot. Release pressure on the cap and double check the ring is in the groove.
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over |
February 10th, 2016, 08:10 PM | #7 | |
Ah well, the struggle is real. First world problems. Thank you sirs. It's motivational to say the least Haha.
February 10th, 2016, 08:13 PM | #8 | |
Vintage Screwball
MOTM - Mar '16
This way the tube won't slide into the lower part.
February 10th, 2016, 08:20 PM | #9 |
n00bie to wannabie
MOTM - Nov '15
What am I missing here
You don't put the caps on until you've filled the fork with oil to the level you want (stick with stock) with the fork compressed then install spring & spacer. The fork will be extended or there's no way in hell you'll get the cap on!
February 10th, 2016, 08:23 PM | #10 |
I feel like Homer Simpson after reading this.
February 10th, 2016, 08:29 PM | #11 |
n00bie to wannabie
MOTM - Nov '15
DOH! No smart remarks! Your rules!
February 10th, 2016, 08:40 PM | #12 |
That'll do it. What a pain in the a55 that was. Got the clip in.
You both have been a great help. The triple tube trick worked. Chalk up another life lesson.
February 10th, 2016, 09:12 PM | #13 |
Vintage Screwball
MOTM - Mar '16
Good job! We're all here to learn right?
February 10th, 2016, 09:40 PM | #14 |
Schönen Tag noch
Join Date: Sep 2013 Motorcycle(s): 08 ninja 250 race bike, 02 gixxer 600 telefonica Posts: 184
Harbor freight picks work well, only $1.99. http://www.harborfreight.com/4-piece...set-66836.html The ninjettewiki has some good info to help u along. Search the forum and there are other good threads as well.
February 11th, 2016, 06:33 AM | #15 | |
Thanks! First time is always a b!tch.
February 11th, 2016, 09:16 AM | #16 |
Join Date: Aug 2015 Motorcycle(s): 05 Ninja 250, 04 KTM 625 SMC, 01 Xc250 Posts: A lot.
Stock they don't have snap rings, but If you take the circlips out I highly recommend buying a pair of snap rings and replacing them, it makes life much easier when changing springs or oil weights. (Ask me how I know)
Because Unregistered sucks at riding. |
February 11th, 2016, 09:36 AM | #17 | |
But yeah, snap rings at home depot apparently. For now, I need a pipe cutter for the spacers.
February 11th, 2016, 09:40 AM | #18 |
I didn't want to destroy my stock spacers, so I bought some plastic pipe (it wasn't pvc, because whatever material this is fit better) and cut it with a compound miter saw.
February 11th, 2016, 10:41 AM | #19 | |
n00bie to wannabie
MOTM - Nov '15
I also use a washer between the spring & plastic pipe for a better seat for the pipe.
February 11th, 2016, 11:06 AM | #20 |
PVC is White, eletrical is grey, ABS is black, the stuff I used was ivory with a yellow stripe.
DIY- Replace fork seals, dust seals and fork oil | shortstuff | 2008 - 2012 Ninja 250R Tech Talk | 212 | November 6th, 2023 10:53 AM |
FS: Pregen : Fork Springs, Fork Clamp, Factory Pro Jet kit | FvnnyL3tt3r1ng | Motorcycle-related | 20 | February 24th, 2016 08:24 AM |
Beyond the telescopic fork | Motofool | General Motorcycling Discussion | 4 | June 8th, 2014 06:00 PM |
Can fork springs be changed without removing the fork tubes? | AlanDog | 1986 - 2007 Ninja 250R Tech Talk | 26 | April 23rd, 2014 05:19 AM |
Fork Replacement | Ninjesterai | 2008 - 2012 Ninja 250R Tech Talk | 6 | March 23rd, 2012 07:26 PM |
