Old December 14th, 2015, 04:41 AM   #41
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
For anyone just now seeing this, the stock NewGen spring is 9.3kg/mm, good for a 209-218lb rider based on RaceTech's calculator. RT breaks the ZX-6R into '05-'06 and '07-'08 (not '06-'07), with 9.7kg/mm and 9.2kg/mm springs respectively, good for 230-240lb and 204-213lb.
The shock is definitely more advanced, but the spring isn't that much different for all the work involved in fitting it. The GSXR shock swap seems to give about the same results with less work and staying closer to stock suspension geometry (though it's still not perfect).
Old December 14th, 2015, 07:10 AM   #42
HoneyBadgerRy
HoneyBadgerRy's Avatar
But who wants the stock suspension geometry?
Old December 14th, 2015, 07:54 AM   #43
^^^^ ummm most of us should. It's a four bar linkage system. As you change the length of the dogbones to raise/lower the tail, you're changing the position vs velocity of the wheel as it travels through it's arc, thereby requiring a different damping profile from your shock.
So if you're already getting an aftermarket shock that's intended to to be adjustable for length, then you're fine because it's likely had this accounted for with it's valving. But if you're using stock, you're taking concessions in the designed damping feeling by raising/lowering. Is it big enough to notice? minimally. Is it big enough to worry about that you'd want to give up the faster turn in from a higher tail? Nah.
Just food for thought.
https://en.wikipedia.org/wiki/Four-bar_linkage
For how cheap these bikes are, they work damn well in stock form. They have their flaws, but they're still more than most owners will ever use.
Old December 14th, 2015, 08:00 AM   #44
HoneyBadgerRy
With the longer shock and longer dogbones it will raise the rear end a little (depends on how much longer your dogbones are) and it will change the leverage of the shock. It should make the valving and spring less effective at the beginning of the stroke and more effective at the end of the stroke. Its not for everyone, but personally its a change that I like. The spring is still a little stiff, but I probably have something softer of the shelf that I'll swap out later.
Old December 14th, 2015, 08:10 AM   #45
yes... thank you for typing back something I just typed.
Make up your mind.
Old December 14th, 2015, 06:29 PM   #46
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
I absolute don't like it, the stock suspension geometry is for commuter with the 300 is much more of this than the 2-fiddy
Old December 14th, 2015, 08:18 PM   #47
HoneyBadgerRy
Old July 29th, 2017, 07:15 AM   #48
TheDuck
Da Duckman
TheDuck's Avatar
Motorcycle(s): '08 250R, '06 Chopper, '80 Puch Magnum II, '01 SV650, '99 CR250/CR500AF Sportbike. '02 CRF450/CR500AF Dirt
@TheDuck do you have a yotube channel?
A little late for the reply, but yes, I have several of them.
https://www.youtube.com/user/DuckmanCycles
https://www.youtube.com/user/vvtheduckvv
https://www.youtube.com/user/skeetertheduck
TheDuck is offline   Reply With Quote
Gixxer rear shock question - rear stiffness too high cookiebug79 2008 - 2012 Ninja 250R Tech Talk 20 January 17th, 2015 08:19 AM
Rear shock set to high (rear wheel slipping)? passive101 2008 - 2012 Ninja 250R Tech Talk 6 August 10th, 2014 08:45 PM
Anyone tried a '09-'11 ZX6R rear shock upgrade? Nemesis 2008 - 2012 Ninja 250R Tech Talk 2 April 21st, 2011 11:22 AM
For sale: 2003 ninja 250 rear brake pedal and rear shock ReDnEcK Motorcycle-related 0 October 6th, 2010 12:02 PM
Replacing my rear shock with a newgen rear shock... ReDnEcK 2008 - 2012 Ninja 250R Tech Talk 4 September 10th, 2010 12:38 PM
