April 14th, 2016, 08:31 PM | #1 |
Join Date: Aug 2014 Motorcycle(s): '10 Ninja 250 track bike, '06 Goldwing, '81 HD FXB Posts: 30
Are the ignition coils grounded?
Long story short, have a 2010 race bike that currently has power to the coils but no spark.
Before we do any more troubleshooting I want to make sure the coils aren't supposed to be grounded, just bolted to the rubber mounts and no ground wire to them that I've missed some how.
April 14th, 2016, 08:34 PM | #2 |
Vintage Screwball
MOTM - Mar '16
The bars that come out of the coils are grounded to the frame by the bolts. Check continuity from the coil bolt to the frame. If you have continuity, they're grounded.
Goin' fast on slow bikes! |
April 14th, 2016, 08:39 PM | #3 |
n00bie to wannabie
Join Date: Sep 2015 Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!) Posts: A lot.
MOTM - Nov '15
Will you be at Greg Moore on the 24th Norm? If so; what's your number or bike colour? I'll root for you from the stands.
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over |
April 14th, 2016, 08:56 PM | #4 | |
No ground = no sparks
April 14th, 2016, 09:56 PM | #5 | |
I will start by check for continuity tomorrow, thanks.
April 14th, 2016, 09:58 PM | #6 | |
Bike is green, number 762. Can't miss me, I'll be in last place!
April 14th, 2016, 10:36 PM | #7 | |
n00bie to wannabie
MOTM - Nov '15
I'll have a look at my coils tomorrow or Saturday and see if I can pass on an answer to the grounding. You know I trust; if you show up on the 24th and mention you're having problems; you will be swarmed with good peeps, a deep pool of knowledge and willing hands to get you out on the track!
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over Last futzed with by SLOWn60; April 15th, 2016 at 07:50 AM. |
April 15th, 2016, 07:46 AM | #8 |
EX500 full of EX250 parts
According to the wiring diagram (which matches up for the PreGen, NewGen, and 500), the coils get power on the red wire from the Ignition fuse through the kill switch. The green and black ground wires go back to the igniter, which is how the spark is actually controlled.
April 15th, 2016, 08:19 AM | #9 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
I'm not sure what I'm missing here, but if the coils are grounded, wouldn't the spark go through the ground instead of to the spark plug?
Wouldn't the ground be the spark plug being connected to the engine? IE - the coils should ride in those rubber grommets and not be grounded to the frame directly? Or, am I just thinking of the secondary coil and the primary coil needs a ground to create the field which collapses into a spark?
My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
April 15th, 2016, 09:59 AM | #10 |
Fighting Texas Aggie '05
This, the primary side receives the capacitor discharge, the secondary side gets the pulse induced spark.
April 15th, 2016, 11:27 AM | #11 |
MOTM - Sep '18, Feb '16
Are you still using the key? There is a 100 ohm resister in the key circut
April 15th, 2016, 12:44 PM | #12 | |
Everything worked fine when I put it away in November, so it's something I've screwed up over the winter. Installed a quick throttle, rejetted the carbs, put on a new kill switch/start switch, installed new bodywork, and snipped a few more unused wires from the harness... I suspect this is going to be where the trouble originates. troubleshooting to this point has shown: There is power to the igniter and we have tested with a known good igniter and ruled that out There is power to the coil but they don’t pulse/no spark signal. kill switch and starter button both work checked the diodes per the manual and jumped all the safety switches. The starter relay is good, not that that is really relevant since we know the motor spins I don't like electrical
April 15th, 2016, 03:19 PM | #13 |
My bike did this once and I never really did find the problem. I ended up replacing the wiring for another reason and it worked again. Keep diagnosis goin and be scientific about it.
April 15th, 2016, 05:20 PM | #14 |
n00bie to wannabie
MOTM - Nov '15
@Fishbine
Do you have a shop manual? I assume so and you've done the coil check on page 16-36? And followed the Ignition System Troubleshooting chart on page 16-39? I ask because often there are relatively inexperienced posters to the forum and it's easy to misinterpret the experience of an OP. I don't want to presume a level of expertise and also help other readers regardless of their experience or knowledge level.
April 16th, 2016, 12:36 PM | #15 |
Bill, yes I have a manual… I suck at electrical but I've had some good help trying to figure this out. At this point it looks like the problem is the crank position sensor, which was about the last thing left to test before I shot the lock off my wallet and handed it off to burnaby kawasaki
I'll update this post once I've gotten in there. Thanks to all.
April 16th, 2016, 01:08 PM | #16 | |
n00bie to wannabie
MOTM - Nov '15
Well that's ok as long as you make it there next weekend! Cheers!
April 18th, 2016, 03:44 PM | #17 |
Join Date: Jan 2012 Motorcycle(s): Race bikes:08 Ninja 250,11 R6,16 ZX6,SV650.3 HD-1947,2-2003,2010. 1946 Indian and a lot of dirt bikes.2 Posts: 999
no
How To Bench Test Ignition Coils? | ithaca00 | 2008 - 2012 Ninja 250R Tech Talk | 8 | April 5th, 2015 10:09 PM |
[motorcyclistonline] - EXACTFIT High Voltage Ignition Coils | Ninjette Newsbot | Motorcycling News | 0 | March 9th, 2011 06:00 PM |
