October 29th, 2012, 11:42 AM | #1 |
Join Date: Jun 2010 Motorcycle(s): Ninja 500, VFR750 Posts: 51
triple clamp stem bolt Same as EX-500?
Thought maybe someone would know- is the Ninja 250 stem bolt the same as on the EX-500? I'm swapping front ends on my 500 and don't wanna use the chrome bolt that is stock on the EX-500. According to the fiche, they're both 16 x 22, but different part numbers- but that is most likely because one is chrome and one is black. If no one knows for sure, maybe you can count the threads and i can compare to the EX-500 bolt. Thanks for any info
October 29th, 2012, 11:48 AM | #2 |
someone once told me the entire front end of the new gen 250 is the same as the ex500 but thats just hearsay
October 29th, 2012, 11:51 AM | #3 |
i know the pre-gen and newer Ninja 250 bolts are interchangeable, even though they don't have the same part #. I highly doubt Kawasaki would make a different bolt for the EX-500, but just trying to confirm before i buy a nice new Ninja 250 bolt.
October 29th, 2012, 04:36 PM | #4 |
Skippii has a ninja 500 front end on his pregen.
October 30th, 2012, 02:03 PM | #5 |
The Ex-500 bolt has about 13 threads- that seems to be a 1.25 pitch. If anyone has a spare Ninja 250 bolt and can count the threads, i'll know for sure whether they're swapable...
November 7th, 2012, 03:00 PM | #6 |
Dunno, but it's the same as the EX250E (1986-1987 Ninja 250R). The EX250F (1988-2007) and EX250J (2008-2012) bolts are the same as each other except for paint, but that one looks a lot more different.
Aluminium Triple clamp | red26 | 2008 - 2012 Ninja 250R Tech Talk | 17 | September 29th, 2014 08:48 AM |
Lower triple clamp | DCkilla | 1986 - 2007 Ninja 250R Tech Talk | 4 | July 14th, 2014 01:31 AM |
