Old September 17th, 2014, 08:20 AM   #1
red26
Motorcycle(s): Ninja 250R, GSXR600 K4, KX250F,NSR150SP, Yamaha TZM150
Aluminium Triple clamp
Hi
I have been eyeing on this clamp for quite some time. all i can find is made from China / Taiwan. It looks good, and supposedly as strong as standard item. My goal is to make the bike lighter, mine have 146KG measured after race with about 3litres of fuel.
Have anyone have experience on this clamp?
red26 is offline   Reply With Quote
Old September 17th, 2014, 12:35 PM   #2
cuong-nutz
cuong-nutz's Avatar
Nope. I've seen ten around for other bikes as well. Try googling it for other bikes and see the reviews.
HalfFast Racing Team
Old September 17th, 2014, 12:37 PM   #3
BlownWideOpen
BlownWideOpen's Avatar
Motorcycle(s): Stuff
Looks cheap, wouldn't trust it
Paint side up, rubber side down!
BlownWideOpen is offline   Reply With Quote
Old September 18th, 2014, 08:37 PM   #4
psych0hans
psych0hans's Avatar
Look for xrace triple clamp.
Old September 18th, 2014, 09:50 PM   #5
red26
any link for the Xrace?
is it the top clamp or full like the above?
Old September 18th, 2014, 09:58 PM   #6
psych0hans
psych0hans's Avatar
It's just a top clamp, I think they sell on eBay.
Old September 18th, 2014, 11:18 PM   #7
red26
Ah...i know that. But i dont just want to change the top as the standard one is already Alloy
Old September 22nd, 2014, 12:15 PM   #8
DCMoney
DCMoney's Avatar
The stem is the part that weights the most. A guy I know had a shop make one out of aluminum for him. Stock one weights a ton!
MCRA.com
Old September 22nd, 2014, 12:17 PM   #9
i would not trust an aluminum stem. nor would i ever use aluminum triple clamps. you're asking to destroy them on anything but a perfectly smooth track.
Old September 22nd, 2014, 12:27 PM   #10
aluminum 6061t6:
Hardness, Brinell 95 95 AA; Typical; 500 g load; 10 mm ball
Hardness, Knoop 120 120 Converted from Brinell Hardness Value
Hardness, Rockwell A 40 40 Converted from Brinell Hardness Value
Hardness, Rockwell B 60 60 Converted from Brinell Hardness Value
Hardness, Vickers 107 107 Converted from Brinell Hardness Value
Ultimate Tensile Strength 310 MPa 45000 psi AA; Typical
Tensile Yield Strength 276 MPa 40000 psi AA; Typical
Elongation at Break 12 % 12 % AA; Typical; 1/16 in. (1.6 mm) Thickness
Elongation at Break 17 % 17 % AA; Typical; 1/2 in. (12.7 mm) Diameter
Modulus of Elasticity 68.9 GPa 10000 ksi AA; Typical; Average of tension and compression. Compression modulus is about 2% greater than tensile modulus.
Notched Tensile Strength 324 MPa 47000 psi 2.5 cm width x 0.16 cm thick side-notched specimen, Kt = 17.
Ultimate Bearing Strength 607 MPa 88000 psi Edge distance/pin diameter = 2.0
Bearing Yield Strength 386 MPa 56000 psi Edge distance/pin diameter = 2.0
Poisson's Ratio 0.33 0.33 Estimated from trends in similar Al alloys.
Fatigue Strength 96.5 MPa 14000 psi AA; 500,000,000 cycles completely reversed stress; RR Moore machine/specimen
Fracture Toughness 29 MPa-m½ 26.4 ksi-in½ KIC; TL orientation.
Machinability 50 % 50 % 0-100 Scale of Aluminum Alloys
Shear Modulus 26 GPa 3770 ksi Estimated from similar Al alloys.
Shear Strength 207 MPa 30000 psi AA; Typical
mild steel a1020:
Mechanical Properties Metric Imperial
Hardness, Brinell 111 111
Hardness, Knoop (Converted from Brinell hardness) 129 129
Hardness, Rockwell B(Converted from Brinell hardness) 64 64
Hardness, Vickers (Converted from Brinell hardness) 115 115
Tensile Strength, Ultimate 394.72 MPa 57249 psi
Tensile Strength, Yield 294.74 MPa 42748 psi
Elongation at Break (in 50 mm) 36.5 % 36.5 %
Reduction of Area 66.0 % 66.0 %
Modulus of Elasticity (Typical for steel) 200 GPa 29000 ksi
Bulk Modulus (Typical for steel) 140 GPa 20300 ksi
Poissons Ratio 0.290 0.290
Izod Impact 125 J 92.2 ft-lb
Shear Modulus (Typical for steel) 80.0 GPa 11600 ksi
look at the elasticity modulus for steel vs aluminum... steel is about 3 times more "springy" than aluminum. ultimate tensile strength is typically around 60ksi as well compared to aluminum which is typically around 40ksi. yield ksi is around the same, but what that means is that a hit that would normally make your stock triple simply flex, will in fact bend an aluminum triple. the aluminum triple will "permanently" bend much sooner. how hard of a bump it takes to make 60ksi is another story though. the other big difference is the amount of deformation it can take before it actually breaks. aluminum is about 10%... soft steel is around 30%. that is a massive difference. that's the difference between hitting something on the road bending your front end and hitting something on the road ripping your front end completely off.
Old September 22nd, 2014, 12:34 PM   #11
BlownWideOpen
@alex.s english plz
Old September 22nd, 2014, 12:36 PM   #12
DCMoney
DCMoney's Avatar
What do you think your triple is currently made of?
And I never said the stem was made out of 6061.
MCRA.com
Old September 22nd, 2014, 12:39 PM   #13
my triple stem is made from high carbon heat treated steel and is probably rated over 100ksi.
Old September 22nd, 2014, 12:41 PM   #14
DCMoney
DCMoney's Avatar
Your triple tree clamps too?
MCRA.com
Old September 22nd, 2014, 12:55 PM   #15
nah bro my clamps are made from platinum
Old September 22nd, 2014, 12:59 PM   #16
i went and looked it up. they are cast in 7075-t7
Old September 22nd, 2014, 01:11 PM   #17
DCMoney
DCMoney's Avatar
lol
MCRA.com
Old September 29th, 2014, 08:48 AM   #18
bruce71198
bruce71198's Avatar
We have an SV650 race bike with an aluminum rear axle that has yet to bend or sheer. I would think the shock to to the axle would be more severe than to the stem, and the stems a lot thicker. This bike also has Titanium upper and lower triples that have proven quite durable.
Lower triple clamp DCkilla 1986 - 2007 Ninja 250R Tech Talk 4 July 14th, 2014 01:31 AM
triple clamp stem bolt Same as EX-500? willi777 1986 - 2007 Ninja 250R Tech Talk 5 November 7th, 2012 03:00 PM
X-Race Triple clamp ator Motorcycle-related 26 October 9th, 2012 06:02 AM
DIY: How to install an aftermarket upper triple clamp CThunder-blue 2008 - 2012 Ninja 250R Farkles 9 August 1st, 2012 08:40 PM
2010 triple clamp question kamikaze 2008 - 2012 Ninja 250R Farkles 8 August 17th, 2010 04:54 PM
