June 1st, 2022, 04:13 AM | #1 |
[webbikeworld.com] - 2022 Zero DSR [Specs, Features, Photos]
Click here for full story...
The 2022 Zero DSR: An Electric Dual-Sport That’s Ready to Tackle Any Challenge Contents If you don’t plan on hitting the trails or the dirt often, a dirt bike may be too steep a commitment to make. There’s also the fact that most dirt bikes aren’t road legal and will require you to use a truck or trailer to transport. On the other hand, as the name suggests, a dual-sport motorcycle combines the best of both worlds — tarmac and dirt — to form a bike that can pretty much do anything you set out to do on two wheels. For American company Zero Motorcycles, the Zero DSR is the top-of-the-line dual-sport offering, sitting above the Zero DS. The bike features the same ZF14.4 kWh battery pack system that also powers the more premium models in the 2022 Zero Motorcycles lineup. You also can upgrade to the ZF14.4 Power Tank (18kwh battery pack), which offers even more range. In top-spec, the Zero DSR will give you 204 miles of range in the city and 97 miles on the highway (at 70mph), which is plenty enough for the kind of bike this is. If you think you’ll need a little extra juice, the DSR offers Zero’s hot-swappable battery tech, so you can strap an extra down on your ride to double your distance. The Zero DSR comes with the Z-Force 75-7R motor that produces 70hp and 116lb-ft of torque, propelling the bike to 102mph. Considering its off-road intentions, the Zero DSR comes with fully adjustable Showa suspension at either end. Suspension travel is a respectable 178mm at the front and 179mm at the rear. Braking hardware is pretty neat, too, with J.Juan hardware at either end. Zero Motorcycles has equipped the DSR with Pirelli MT-60 dual-sport tires. The 2022 Zero DSR starts at $16,195 USD / $20,895 CAD. On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Zero DSR in one place. Motorcycle Overview General Info
Main Specs
Competitors 2022 Zero DSR Specifications Engine Peak torque116 ft-lb (157 Nm) Peak power70 hp (52 kW) @ 3,500 rpm Top speed (max)102 mph (163 km/h) TypeZ-Force® 75-7R passively air-cooled, high efficiency, radial flux, interior permanent hi-temp magnet, brushless motor ControllerHigh efficiency, 775 amp, 3-phase brushless controller with regenerative deceleration LubricationDrivetrain TransmissionClutchless direct driveClutchFinal Drive90T / 20T, Poly Chain® HTD® Carbon beltChassis Suspension FrontShowa 41 mm inverted cartridge forks, with adjustable spring preload, compression and rebound damping Suspension RearShowa 40 mm piston, piggy-back reservoir shock with adjustable spring preload, compression and rebound dampingBrakes FrontBosch Gen 9 ABS, J-Juan asymmetric dual piston floating caliper, 320 x 5 mm disc Brakes RearBosch Gen 9 ABS, J-Juan single piston floating caliper, 240 x 4.5 mm disc Tires FrontPirelli MT-60 100/90-19Tires RearPirelli MT-60 130/80-17Fuel Tank CapacityN/AColorPower system Power packZ-Force® Li-Ion intelligent integrated Charger type1.3 kW, integrated Charge time (standard)9.8 hours (100% charged) / 9.3 hours (95% charged)Dimensions Wheelbase56.2 in (1,427 mm) Overall WidthTrail4.6 in (117 mm) Rake26.5° Seat Height33.2 in (843 mm)Curb Weight419 lb (190 kg) Warranty Warranty2 years Extension 2022 Zero DSR Features ALWAYS DIALED Crossing from smooth asphalt to loose gravel fire roads? All good. Change performance profiles at the press of a button to master any terrain. The Zero DSR is pre-programmed with Eco or Sport modes and performance can be fully customized using the Zero Motorcycles app where you can also see detailed ride stats. CHARGE UP TO 6X FASTER Grab lunch. Have a coffee. Recharge. Live your life while adding up to 94 miles of range for every hour you’re plugged in. The Charge Tank option is compatible with Level 2 charge stations and delivers roughly 6x faster charging than when compared to a standard wall outlet. Depending on the battery, a typical recharge can now take as little as an hour.</p> CHARGING. MEET HOUSEHOLD OUTLET. No special equipment required: your standard household outlets can be used as fueling stations for a fraction of the cost of gasoline. Plug in at night and start the day with a full tank. LONG RANGE BATTERY TECH The Zero DSR carries the highest power and energy density battery in the EV industry. With over thirteen years of rigorous off-road experience, the Z-Force® battery confidently delivers you to your destination. CHASSIS Featuring a twin-spar aircraft-grade aluminum chassis, the Zero DS’s frame offers superior torsional rigidity. SUSPENSION Custom-tuned for Zero by Showa, the Zero DSR suspension offers 7 inches of plush travel that enables you to tackle virtually any terrain thrown your way. The entire suspension system can be fully and easily adjusted to glide over any city street or rip down your favorite fire road. DASH The Zero DSR comes equipped with a full color display to project the specs you need: speed, state of charge, power output, selected riding mode and more. Sync with your smartphone to customize the information that is displayed on your dash. ONBOARD CHARGER No additional charging equipment required. The standard 1.3 kW onboard charger plugs into any household outlet. It can be operated in conjunction with the off-board Quick Charger accessory and/or the Charge Tank option to accelerate charge times. TANK The standard Zero DSR “tank” is equipped with spacious lockable storage—perfect for stowing personal items like cell phones, wallets, or gloves. Interested in faster charging or greater range? Swap the standard tank for the Charge Tank option for 6x faster charging or the Power Tank accessory that adds an additional 3.6 kWh of battery. BRAKES The Bosch anti-lock brake system (ABS) delivers confident braking. Tested for just about any situation you can imagine, the system optimizes deceleration when you hit your brakes hard. Braking is actuated via levers that can be adjusted for improved ergonomics. ABS can be switched on or off by the rider. DIRECT DRIVE Strip away clutches, gears, shifting, chains and all their weighty complexities. Seamlessly rocket to speeds in excess of 95 mph with pure efficiency as energy quietly transforms into propulsion. The Zero DSR is direct drive. Its state-of-the-art motor connects directly to the rear wheel using a carbon fiber belt. WHEELS AND TIRES Shred confidently on anything from twisting tarmac to loose fire roads, the Zero DSR’s Pirelli MT-60 tires 2022 Zero DSR Photos 2022 Zero DSR Videos Zero DSR Review by MOTOBOB: Zero DSR Black Forest Edition Review by ADVRIDER: Links Zero Motorcycles Websites Social Media Links The post 2022 Zero DSR [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 Zero DS [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 1st, 2022 04:13 AM |
[webbikeworld.com] - 2022 Zero FXS [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 1st, 2022 04:02 AM |
[webbikeworld.com] - 2022 Zero S [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 1st, 2022 03:47 AM |
[webbikeworld.com] - 2022 Zero SR [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 1st, 2022 03:27 AM |
[webbikeworld.com] - 2022 Aprilia SR GT [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | May 31st, 2022 01:47 AM |
