June 1st, 2022, 04:36 AM | #1 |
[webbikeworld.com] - 2022 Zero FXE [Specs, Features, Photos]
Click here for full story...
The 2022 Zero FXE Is a Compact, Agile, and Fun Electric Supermoto Contents The Zero FXE is the latest addition to the 2022 Zero Motorcycle lineup. The supermoto-styled electric motorcycle is based on the Zero FXS and is an agile, lightweight machine most comfortable in the urban jungle. Equipped with the American company’s ZF7.2 (7.2 kWh total capacity) battery pack, the Zero FXE will take you as far as 100 miles in the city. Get on the highway at a steady 70mph cruise, and that number drops to a humble 40 miles. A full charge with the standard charger takes nearly 10 hours — 9.7 hours, to be precise — so it’s a good idea to spend the extra money on the accessory chargers that bring the time down considerably to 1.8 hours. The FXE is equipped with the Z-Force 75-5 motor that also powered multiple other models in the Zero Motorcycle portfolio. The motor, producing 46hp and 78 lb-ft of torque, can propel the bike to a top speed of 85mph. As it typically does, Zero has equipped the FXE with some pretty neat hardware — grippy Pirelli Diablo Rosso II tires, fully adjustable Showa suspension, and Bosch Gen 9 ABS that works alongside braking hardware from J.Juan. The 2022 Zero FXE starts at $12,195 USD / $15,695 CAD. On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Zero FXE in one place. Motorcycle Overview General Info
Main Specs
Competitors 2022 Zero FXE Specifications Engine Peak torque78 ft-lb (106 Nm) Peak power46 hp (34 kW) @ 4,300 rpm Top speed (max)85 mph (137 km/h) TypeZ-Force® 75-5 passively air-cooled, high efficiency, radial flux, interior permanent magnet, brushless motor ControllerHigh efficiency, 550 amp, 3-phase brushless controller with regenerative deceleration LubricationDrivetrain TransmissionClutchless direct driveClutchFinal Drive90T / 18T, Poly Chain® HTD® Carbon beltChassis Suspension FrontShowa 41 mm inverted cartridge forks, with adjustable spring preload, compression and rebound damping Suspension RearShowa 40 mm piston, piggy-back reservoir shock with adjustable spring preload, compression and rebound dampingBrakes FrontBosch Gen 9 ABS, J-Juan asymmetric dual piston floating caliper, 320 x 5 mm disc Brakes RearBosch Gen 9 ABS, J-Juan single piston floating caliper, 240 x 4.5 mm disc Tires FrontPirelli Diablo Rosso II 110/70-17Tires RearPirelli Diablo Rosso II 140/70-17Fuel Tank CapacityN/AColorPower system Power packZ-Force® Li-Ion intelligent integrated Charger type650 W, integrated Charge time (standard)9.7 hours (100% charged) / 9.2 hours (95% charged)Dimensions Wheelbase56.0 in (1,422 mm) Overall WidthTrail2.8 in (71 mm) Rake24.4° Seat Height32.9 in (836 mm)Curb Weight298 lb (135 kg) Warranty Warranty2 years Extension 2022 Zero FXE Features DESIGN Zero partnered with Bill Webb in 2018 on a Custom build of the Zero FXS. Ultimately we wanted to utilize the build to inspire elements of future Zero motorcycles. Many concept builds push the envelope so far it doesn’t translate to the reality of riding and functionality. Bill Webb took a different approach. He set out to create something that pushed the boundary but relatable and something that could become a reality. We were not surprised when the Motorcycle industry loved the bike. This enthusiasm went well beyond our industry. TECHNOLOGY Built on the foundation of the revolutionary Zero ZF 75-5 powertrain and Cypher II operating system, the road before the FXE is always bright thanks to new LED head and tail lights as well as a full color and bonded TFT dash to literally outshine motorcycles well above its station. Brains and brawn.</p> PERFORMANCE PROFILE Transform performance profiles with the press of a button to perfectly conquer city streets or your local supermoto track. The Zero FXE is pre-programmed with Eco or Sport modes. Connect using your mobile device to customize performance or get stats on your ride. EXPERIENCE The FXE is lighter than any motorcycle with this much power, has no gears and clutch, and an upright riding position making it the most user-friendly vehicle on the road. This bike truly becomes a seamless extension of the rider. Gliding effortlessly through traffic has never been so fun. The FXE is the motorcycle rides as smooth as it looks. 2022 Zero FXE Photos 2022 Zero FXE Videos 2022 Zero FXE Review by RevZilla: 2022 Zero FXE Review by Electrek.co: Links Zero Motorcycles Websites Social Media Links The post 2022 Zero FXE [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 Zero DS [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 1st, 2022 04:13 AM |
[webbikeworld.com] - 2022 Zero DSR [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 1st, 2022 04:13 AM |
[webbikeworld.com] - 2022 Zero S [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 1st, 2022 03:47 AM |
[webbikeworld.com] - 2022 Zero SR [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 1st, 2022 03:27 AM |
[webbikeworld.com] - 2022 Aprilia SR GT [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | May 31st, 2022 01:47 AM |
