Old November 27th, 2010, 12:38 PM   #1
joe250
Motorcycle(s): 2009 250r
Troubles from too lean?
Hi all, I just recently bought my 250 and had a couple questions.
The guy I bought it from had a Yoshi slip on installed and said he removed a snorkel, but did not tune it with a jet kit. From reading these forums, I know that these bikes are already pretty lean, is it possible that with those modifications the bike is running even more lean? Could there have been any damage to the valves as a result? I know the valve adjustment is coming up at 7500 miles, but I was curious if anything could have happened in 4-5000 miles he had bike set up this way.
Thanks all!
joe250 is offline   Reply With Quote
Old November 27th, 2010, 12:42 PM   #2
scotty
scotty's Avatar
Motorcycle(s): Yahama v star 650 classic
Did he shim the needles that you know of? I dont think a slip on and no snorkel would cause a large problem, but I would wait till someone who has more knowlage with tat on here answers your qestion.
scotty is offline   Reply With Quote
Old November 27th, 2010, 12:43 PM   #3
I read about someone here who didn't do his 7,500 miles valve check, was running too lean, and ruined his motor (valves "mushroomed") around 10,000 miles. I haven't modified mine in any way, but because they told me that all my valves were "in spec" at my last service ~8,600 miles, I'm really worried because I can't afford one and I'm now over 17,000 miles.
If anything, I think it's running rich because the exhaust has been really smelly since my last valve service.
Old November 27th, 2010, 01:21 PM   #4
scotty
scotty's Avatar
Shimming will get the job done. But rejetting is always better too. Many threads on how to do both things.
About that other post, he had a full exhaust I belive, and he didnt do the valve check. The valves could have been way off which coud have been the main reason of the motor failing. Poor maintenance will distroy any motor. I dont think your set up will make it run much leaner.
Old November 27th, 2010, 01:50 PM   #5
joe250
Thanks Scotty, I read the threads on shimming and jetting, I will do one or the other once I take it out again in the spring.
I rode it maybe 50 miles and it felt fine the entire time, hopefully it isn't lean to the extent that it causes damage .
Old November 27th, 2010, 02:35 PM   #6
http://www.ninjette.org/forums/showthread.php?t=57543&
I suggest you shim the needles, at least.
Old November 27th, 2010, 02:47 PM   #7
joe250
Yeah, I read that thread and got worried. I definitely plan to atleast shim the needles before I ride it in the spring.
Newb Troubles momoru 1986 - 2007 Ninja 250R Tech Talk 5 July 13th, 2014 03:32 PM
Starter troubles ZeroG General Motorcycling Discussion 11 June 8th, 2013 05:01 PM
Car troubles SabreValkyrn Off-Topic 3 February 23rd, 2013 04:51 PM
Key troubles areifel 2008 - 2012 Ninja 250R Tech Talk 1 September 21st, 2012 06:59 PM
[superbikeplanet.com] - Our Troubles Are All The Same Ninjette Newsbot Motorcycling News 0 September 24th, 2008 03:17 PM
