September 28th, 2012, 02:22 PM | #1 |
YMCMBillionaire
Join Date: Jul 2012 Motorcycle(s): 2008 Ninja 250R(Wrecked&Gone), 2004 Honda CBR1000RR (Trading back to dealer for 600cc) Posts: 81
Brake Light Issue
OK so I have the stock taillight brake light dual filament or w/e and I had a stock one lasted forever. finally gave out weeks ago got a new one laying around it worked a bit then blew I bought some bulbs again for it and both blew quickly I was wondering what brand and wattage volts etc should I use to stop this? BTW I threw away the original bulb that came with bike. Any help will be appreciated. Cheers and thanks.
PS I know about LED cause dual filament sucks as I read before I just need something to last while I look for a good LED upgrade.
September 28th, 2012, 02:51 PM | #2 |
Have you considered the Sylvania 2357 LL. It's a dual filament bulb that is brighter than a standard 1157 bulb when the brake is applied. The filaments are thicker and last longer and are cheaper than LED bulbs. I've had one last over 2 years.
Brake Light Issue/Front Master Rebuild? | TDMX595 | 1986 - 2007 Ninja 250R Tech Talk | 5 | October 24th, 2014 05:23 PM |
Ninja 250 2011 Brake light issue! | srecordz | 2008 - 2012 Ninja 250R Tech Talk | 13 | October 11th, 2013 11:01 AM |
Rear Brake Doesn't activate Brake Light And DOT3/4 FRONT BRAKE OIL | coelgrim | 2008 - 2012 Ninja 250R Tech Talk | 16 | March 11th, 2013 05:10 PM |
Brake Light Issue | Boomstick1491 | 2008 - 2012 Ninja 250R Tech Talk | 11 | June 1st, 2012 03:16 PM |
brake light issue | Kitdog | 2008 - 2012 Ninja 250R Tech Talk | 20 | July 26th, 2010 07:57 PM |
