July 12th, 2010, 08:41 AM | #1 |
NinjArmy
Join Date: Apr 2010 Motorcycle(s): 2009 Ninja 250R Diablo Black (SOLD) Posts: 71
LED Light Issue
I went ahead and replaced the tail lights with mimi CF LED lights and it looks amazing. I have done alot of research tho and and reading and knew that I needed a new sensor to fix the flash rate and make them work properly. Here in lies the problem. I ordered the Kawasaki universal led normalizing sensor Plug and Play from RoaringCustoms.com. It has my bike listed along with several others and I ordered it through a actual bike shop from the parts catalog.
Got it home, took off the seat and left rear farings and cannot find for the life of me where it plugs in. There was not another single sensor that matched the one that was sent to me. I have checked with the shop and the website and they both say that will fit my bike. Its a '09. Only thing I could think of was do I have to look up by the headlight and take off the front fairings and front cowling? Has anyone used this part or a plug and play sensor before and where did you have to mount it? Any help would be nice as right now the lights will not blink at all and both of them always come on when I turn on juts one blinker. I also have no front blinkers and think that might be part of the both lights and no blinking problem. PLEASE HELP!
Diablo Black 09' Ninja 250R / Fender Elim / DynoJet Kit / Sticker Delete / Painted Windscreen / CF TP / Rear Seat Cowl / HotBodies MGP Exhaust / Flush LED Front & Mini CF LED Rear Blinkers |
July 12th, 2010, 08:43 AM | #2 |
NinjArmy
just to be clear
to be clear...when i said there was nomtahcing sensor...I meant there was not another plug in piece that matched the end on the sensor.
July 12th, 2010, 09:08 AM | #3 |
NinjArmy
correction
part was from rumblecustoms.com
#RU35957
July 12th, 2010, 09:26 AM | #4 |
ex-ninjette.org guru :o
Join Date: Jun 2010 Motorcycle(s): 2003 SV1000 S Posts: 475
I can't even get their website to work properly, but by the sounds of things you were sold a flasher relay, which means you'll need to pull your existing flasher relay and replace with the one you bought. without seeing what you got tho, that's all the speculation I'm prepared to make.
July 12th, 2010, 09:33 AM | #5 | |
NinjArmy
July 12th, 2010, 09:43 AM | #6 |
self wrencher
You mean the flasher?
Posted via Mobile Device |
July 12th, 2010, 09:45 AM | #7 |
Join Date: Nov 2008 Motorcycle(s): Ninja 250R 2009 Posts: A lot.
July 12th, 2010, 10:02 AM | #8 |
NinjArmy
Sam - You are awsome. I could find this anywhere! Heres the problem and now I think I know what I am going to need to do. I was bale to find this and thought it was the relay but was unsure. Now I know I was gunning for the right sensor. My problem now is that the connectors are different. The stocker comes in a larger "L" shape and the other is not remotly the same. I am going to see if I cant find a connector to connector wire or if I need to order a new relay all together.
Thank you for your help! If you or anyone knows of where I could get the correct relay or a connector-to-connector wire please let me know.
July 12th, 2010, 10:47 AM | #9 |
Check this thread:
http://www.ninjette.org/forums/showthread.php?t=36477 You should see a link for the replacement flasher Here you go: Lastly, you need to purchase a CF12ANL-01 relay from www.superbrightleds.com here is the link for that: http://www.superbrightleds.com/cgi-b...ers.htm#Table4 |
July 12th, 2010, 11:18 AM | #10 | |
NinjArmy
July 12th, 2010, 04:41 PM | #11 |
Join Date: Feb 2010 Motorcycle(s): '94 Vulcan 1500, '06 Katana 600, '08 FZ1 Posts: 133
Yes they will flash perfectly. The new flasher will need a ty-wrap to hold it to the rubber mounting thing.
July 13th, 2010, 05:17 AM | #12 |
NinjArmy
Thanks ALL
I went ahead and ordered the correct relay from the above website and it will be here in a couple days! Thanks for the help. Ive already got plans for mounting it in a more simple area as well. Hopefully this time everything works!
July 13th, 2010, 07:40 AM | #13 |
Well done!
Sequential LED Tail Light small issue | ez12a | 2008 - 2012 Ninja 250R Tech Talk | 7 | April 5th, 2015 05:46 PM |
Oh No, not another LED tail light issue...please see video | ryker | 2008 - 2012 Ninja 250R Farkles | 1 | April 4th, 2015 03:31 PM |
Brake Light Issue | YMCMB | 2008 - 2012 Ninja 250R Tech Talk | 1 | September 28th, 2012 02:51 PM |
Brake Light Issue | Boomstick1491 | 2008 - 2012 Ninja 250R Tech Talk | 11 | June 1st, 2012 03:16 PM |
brake light issue | Kitdog | 2008 - 2012 Ninja 250R Tech Talk | 20 | July 26th, 2010 07:57 PM |
