Old July 12th, 2010, 09:48 AM   #1
Kitdog
Kitdog's Avatar
Motorcycle(s): 2009 Ninja 250r, 1996 Yahmaha YZ 125... Both in Blue the coolest color
brake light issue
Ok so last night I was backing up to a parking place and noticed when I use my rear brake brake that the tail light does not come on, I have never noticed this until last night because I was backing up to a huge window. so whats up how can I fix this if in fact it lights off the back brakes? No I'm not boxing up my my bike and shipping it to anyone for "disposal" because it's "defective" sorry. Any Idea's
"Well you know, for me, the action IS the juice"
Kitdog is offline   Reply With Quote
Old July 12th, 2010, 09:58 AM   #2
Change the bulb, it's a standard 1157.
Old July 12th, 2010, 10:07 AM   #3
dubojr1
dubojr1's Avatar
Just when you use the back brake?
Something must be wrong with the rear brake switch or it's components. Check to make sure the spring is still attached. If so then it may need adjusting. See "Brake Light Switches" in your owners manual under the "Maintenance & Adjustment" section.
Old July 12th, 2010, 10:07 AM   #4
Brently7785
NinjArmy
Brently7785's Avatar
Motorcycle(s): 2009 Ninja 250R Diablo Black (SOLD)
if its not the bulb...try and check the connection on the rear brake sensor located by right rear set and brake pedal. may just need to be turned or adjusted to make it come back on
Diablo Black 09' Ninja 250R / Fender Elim / DynoJet Kit / Sticker Delete / Painted Windscreen / CF TP / Rear Seat Cowl / HotBodies MGP Exhaust / Flush LED Front & Mini CF LED Rear Blinkers
Brently7785 is offline   Reply With Quote
Old July 12th, 2010, 10:08 AM   #5
Brently7785
NinjArmy
nice job jason....think you beat me only by seconds on this one!
Old July 12th, 2010, 10:09 AM   #6
bob706
bob706's Avatar
But it's broken. +1 for changing the bulb. While your at it buy a bunch of 'em. 1157's are the reason I went with LED's.
Old July 12th, 2010, 10:11 AM   #7
dubojr1
dubojr1's Avatar
Yeah I think your right. About 15 secs later my iPhone notified me of your post. Team effort though.
Old July 12th, 2010, 10:34 AM   #8
Kitdog
Kitdog's Avatar
No the bulb's not broken, it comes on with the front break. I check the switch on the rear when I get home.
Old July 12th, 2010, 11:00 AM   #9
g21-30
g21-30's Avatar
Look in your MOM and adjust the rear brake switch!
Old July 12th, 2010, 11:08 AM   #10
dubojr1
dubojr1's Avatar
huh?
Old July 12th, 2010, 11:11 AM   #11
MOM= Motorcycle Owner's Manual
Old July 12th, 2010, 11:20 AM   #12
dubojr1
dubojr1's Avatar
Ohhhhhhh....... Got it.
Old July 12th, 2010, 11:29 AM   #13
my rear brake's toggle switch spring has come loose a few times. not since i switched to some aftermarket rear-sets and fabbed my own mount for it. nice and solid now.
Old July 12th, 2010, 11:33 AM   #14
Gfortunes
love to ride
Gfortunes's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250r Ebony/Candy Persimon Red
I noticed something like this with my bike and upon further inspection I found that it just took more pressure to have the rear brake light come on when I asked the dealer they said it was because people tend to rest their foot on the rear brake so the switch is not activated until you really have it stepped on. Maybe off base but it is worth checking out.
Gfortunes is offline   Reply With Quote
Old July 12th, 2010, 11:35 AM   #15
Kitdog
Kitdog's Avatar
Originally Posted by dubojr1 View Post
huh?
That's what I was thinking too WTF
Old July 12th, 2010, 11:41 AM   #16
dubojr1
dubojr1's Avatar
It's cool. I'm confident there will be some issue with your switch. Check it out when you can. Should just be a small adjustment.
Old July 13th, 2010, 07:22 AM   #17
Kitdog
Kitdog's Avatar
yes it was the switch needed adjusting, I fiddled with it some last night and got it to come on. I'm taking my kids on vacation today so It will have to wait for final adjustment till I return, glad to know it was something simple though.
Old July 13th, 2010, 07:34 AM   #18
dubojr1
dubojr1's Avatar
Awesome. Glad it was a simple fix.
Old July 13th, 2010, 07:34 AM   #19
Old July 26th, 2010, 12:46 PM   #20
Reading the manual should be a requirement. You'd know to check the light more often (it suggests every ride) AND how to adjust it. I just put my hand behind it while seated and press the brake. My hand will light brighter and I'll know that it's working.
Old July 26th, 2010, 07:57 PM   #21
Kitdog
Kitdog's Avatar
Funny you say that I did read the manual, I went back after reading your reply and found Page 121-122 (break light switch adjustment), and 161-162(about the labels on the bike) are missing from my Manual, I just never noticed becasue I never looked at the page numbers... Quality control must suck at the printers lol!!! I went to my dealer and they photocopied said pages for me, now I have them (would have given me a new manual but I have written stuff on the cover of mine). Good thing I had an electronic copy of the service manual to use to fix the problem. I kinda figured something came loose just wasn't sure.
Brake Light Issue/Front Master Rebuild? TDMX595 1986 - 2007 Ninja 250R Tech Talk 5 October 24th, 2014 05:23 PM
Ninja 250 2011 Brake light issue! srecordz 2008 - 2012 Ninja 250R Tech Talk 13 October 11th, 2013 11:01 AM
Rear Brake Doesn't activate Brake Light And DOT3/4 FRONT BRAKE OIL coelgrim 2008 - 2012 Ninja 250R Tech Talk 16 March 11th, 2013 05:10 PM
Brake Light Issue YMCMB 2008 - 2012 Ninja 250R Tech Talk 1 September 28th, 2012 02:51 PM
Brake Light Issue Boomstick1491 2008 - 2012 Ninja 250R Tech Talk 11 June 1st, 2012 03:16 PM
