Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 Farkles
Old September 24th, 2013, 10:41 PM   #1
anacron
anacron's Avatar
Motorcycle(s): Triumph Street Triple R
My Woodcraft Clip-on installation experience
The stock bar ends may be "Kawasaki genuine parts" but I have some Kawasaki genuine hate for them.
Look at what they did to my Philips head bit... utterly destroyed. I managed to get them off after some fiddling and getting creative.
anacron is offline   Reply With Quote
Old September 24th, 2013, 10:47 PM   #2
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
Sounds about right... welcome to the club! F*ck everything about those bar ends.
CVMA #531
Trailerboy531 is offline   Reply With Quote
Old September 24th, 2013, 11:06 PM   #3
Chefdota
Motorcycle(s): 250r
I had to saw the stock bar ends off because i stripped the nuts. that's not gonna be the end of it your going to want shortie levers , new windscreen and new brake lines for a cleaner look. ENJOY its Worth it for me :P
Chefdota is offline   Reply With Quote
Old September 24th, 2013, 11:20 PM   #4
anacron
anacron's Avatar
Yeah, I was already thinking about shortie levers and some detailing work
I need to stop though... I'm already up for an R6 upgrade, now that I crashed my 300
Old September 25th, 2013, 05:08 AM   #5
S1att3r
S1att3r's Avatar
Motorcycle(s): White 2013 Ninja 300(Storm), Silver 2003 Fjr1300
Did you use an impact driver? I didn't have a single problem with stripping or breaking bits when I used an impact driver.
ATGATT
For all I know, women who ride motorcycles are all man-hating dominatrix's.
It was like a mild panic attack!
S1att3r is offline   Reply With Quote
Old September 25th, 2013, 08:13 AM   #6
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
What brand of Phillips bit is that? I am willing to bet it is a cheap brand. I destroyed a cheapo bit getting mine off. But then slapped in a good brand name bit and was able to twist them out with no heat just a little man power no problem.
Old September 25th, 2013, 08:39 AM   #7
A set of quality Japanese Industry Standard (JIS) screwdrivers makes a huge difference when it comes to installing and removing screws on Japanese cycles and cars.
JIS screws look like standard Phillips-head screws - but aren't. All of the screws that look like Phillips are really JIS. A standard Phillips screwdriver doesn't have the proper contact needed to hold much torque when used in a JIS screw.
I bought the JIS 3-piece standard set (#53325A61 - made in Japan) from McMaster-Carr a while ago, and they make a huge difference.
In a pinch, the screwdrivers in the tool kit are also JIS.
Old September 25th, 2013, 09:46 AM   #8
ChickenRun
ChickenRun's Avatar
Motorcycle(s): 2010 250r SE (without stupid tribal decals)
At least the bit didn't snap in half like mine.
"It sounds like a lawnmower."
"Shut up no it doesn't."
ChickenRun is offline   Reply With Quote
Old September 25th, 2013, 10:39 AM   #9
anacron
anacron's Avatar
@S1att3r
Nope, didn't use an impact driver. I'm sure this is the preferred way to remove red loctite bolts but I wanted a cheaper option.
@subxero
It was a cheapo brand, so not too bothered about losing the bit. Just incredibly frustrated at how hard a job it was for something so small.
@jkv45
I ended up duct taping the tool kit's screwdriver bit to my socket wrench and removing the bar ends that way. Of course, by that time the screw heads were stripped to the point where it didn't really matter which bit I used.
Old September 25th, 2013, 12:31 PM   #10
Chicagobob
Chicagobob's Avatar
Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B
I agree that the Japanese standard driver head is a must, but with my bar-ends, even that wasn't enough, so I drilled out the screw heads, then removed the bolts with vice-grips once the weights were off. Still a pain, but didn't take too long.
I re-attached the bar-end weights with hardware store stainless hex-head flathead bolts.
Chicagobob is offline   Reply With Quote
Old September 26th, 2013, 05:12 AM   #11
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Um… you DID use heat, right?
You take a propane torch and use it to heat the screw head. That breaks the bond.
Those suckers don't want to go anywhere if you don't.
But you found that out….
And yeah, impact driver. The "cheaper option" isn't so cheap when you start destroying things and flames start shooting out of your eye sockets. How much is your time and aggravation worth to you?
A rule I learned early is that buying the right tool for the job is ALWAYS cheaper in the long run.
Old September 26th, 2013, 06:50 AM   #12
Chicagobob
Chicagobob's Avatar
Yes, I used heat, but only after I had the screws drilled out and the weights off, and then it didn't take much, because I could apply it near the threads. I didn't want to torch the screws from the ends.
Old September 26th, 2013, 07:06 AM   #13
SMman
SMman's Avatar
Motorcycle(s): 15 CBR300R, 14 BWS50, 09 FZ1, 09 Ninja 250, 06 CRF450R Motard, 03 ZX-6R
I used a socket with a phillips head and applied pressure towards the bar end. I never had an issue at all and didn't have to use heat.
Thanks for the tip about JIS screwdrivers. Now I have something to shop for. I agree that its always good to have the right tool for the job (insert dirty comment here )
15 CBR300R, 14 BWS50, 09 FZ1, 09 Ninja 250, 06 CRF450R Motard, 03 ZX-6R 636
SMman is offline   Reply With Quote
Old September 26th, 2013, 10:05 AM   #14
anacron
anacron's Avatar
Second hardest job was getting the grip off of the left handlebar. Saw posts about compressed air being the best option but I really didn't want to buy something for a one time use.
Ended up using a screwdriver to create some space between grip and handlebar, then squirted some windex into the gap. Start twisting the grip back and forth and before you know it the thing just slides right off!
In hindsight, removing the grip should've been a 2 min job but it took me some time (and brute force attempts) to arrive at the idea to use liquid as a lubricant... worked like a charm and I had a chance to clean the bugs off my windshield!
Old September 26th, 2013, 10:59 AM   #15
SMman
SMman's Avatar
Compressed air does work very well. I've done many grips with it. Go out and start buying tools. You will definitely use them again.
Old September 26th, 2013, 11:16 AM   #16
anacron
anacron's Avatar
I sure will... once I'm out of grad school and housing situation is no longer temporary and garage situation not so ridiculous.
Old September 26th, 2013, 12:09 PM   #17
psych0hans
psych0hans's Avatar
Using heat makes the whole process pain free... Use a flame torch to heat up the screws and they come off pretty easy...
Old September 26th, 2013, 09:29 PM   #18
anacron
anacron's Avatar
All done!
Unfortunately, I had a lapse in concentration when checking the lock-to-lock clearance and accidentally caused a stress fracture on the Tacho. You can see the off-white line around the contour of Speedo display.
Hate myself for losing that bit of focus but C'est la vie. Otherwise, clip-ons feel great!
Anyone know if that bit of clear plastic is modular and individually replaceable?
Edit: Not sure why the pics are rotated post-upload... i'll upload better angles tomorrow.
Old October 1st, 2013, 01:41 PM   #19
Xtina
Xtina's Avatar
Motorcycle(s): 2013 Ninja 300, 2007 Gsxr 600, R6-sold :(
You have to replace the whole cluster.
Xtina is offline   Reply With Quote
Woodcraft Clip-ons cuong-nutz Items Wanted 14 July 17th, 2012 03:00 PM
Woodcraft Clip-Ons kingkang204 Motorcycle-related 4 July 4th, 2012 12:32 PM
Hotbodies Undertail Experience & Installation Guide wvninja 2008 - 2012 Ninja 250R Farkles 35 May 14th, 2011 10:24 PM
