April 17th, 2015, 05:59 PM | #1 |
Join Date: Jul 2014 Motorcycle(s): 2012 ninja 250 Posts: 7
valve adjustment
When you take the valve tappet off, how do you remove the shim? Is there a tool to press down on the spring? Looked at the DYI threads with the pics, but wasn't clear to me how the shims are actually removed once you wiggle the tappets out.
Thanks for any assistance! : |
April 17th, 2015, 08:09 PM | #2 |
The shim is usually stuck on the underside of the tappet/bucket and can be removed by hand. A thin film of oil is what is causing it to stick to the bottom. Just when you remove the tappet, go slowly in case it decides to fall out.
You do not need to press down the springs. The pictures that you saw are most likely with the shims already removed. When you replace the shim, you can place it by hand in the depression over the valve stem then place the tappet over it. |
April 17th, 2015, 08:15 PM | #3 |
Thanks for the input!!
Valve adjustment | ninjaryda | 1986 - 2007 Ninja 250R Tech Talk | 6 | April 6th, 2013 06:02 PM |
Valve adjustment | blink | General Motorcycling Discussion | 7 | February 21st, 2013 01:41 PM |
Valve Adjustment-Really Tight adjustment screw? | mikesova | 1986 - 2007 Ninja 250R Tech Talk | 5 | May 2nd, 2010 04:57 AM |
anyone want to help with a valve adjustment? | diablo250 | Group Rides and Local Events | 2 | March 28th, 2010 02:00 AM |
Valve adjustment | Apex | 1986 - 2007 Ninja 250R Tech Talk | 7 | September 1st, 2009 05:53 PM |
