Old April 27th, 2011, 10:03 PM   #1
CantDecide
Idle Speed, Choke, and Throttle Hunting on a New-to-me '07
Hello,
I have a new-to-me '07 with 1700 miles on it. When warming up with the choke on, the throttle seems to drift up to around 4000 rpm. If I tweak the choke to idle around 2000, the engine starts to sputter and threatens to stall.
Is that normal?
I was riding the bike this evening for the first time, and I noticed it seems to like to idle around 4500 RPM, which seems really high. I twisted the idle knob and it got very loose, but I was able to drop the idle speed down to about 2500.
Is the idle-adjuster screw locked into the carb? Can I accidentally back it out by unscrewing it all the way?
The bike had been sitting for about a year before I bought it, and it might have gas from last year in it (I'm not sure), could that affect this?
Once warmed up, the bike seems to idle smoothly, though a bit fast. I'm not very familiar with bikes, but the throttle might be a wee touch sticky as well, before I adjusted the idle, sometimes it would stick at 5500 or 5000 rpm, and if I blipped the throttle it would drop to 4500. Is that normal?
Thanks for any advice you might have!
CantDecide is offline   Reply With Quote
Old April 27th, 2011, 10:17 PM   #2
try running some fuel system cleaner through the bike for a couple of tanks and see if it improves. I like seafoam, but berryman's has a good following as well.
for choke issues...
http://faq.ninja250.org/wiki/What_is..._at_startup%3F
to properly set your idle speed...
http://www.ninjette.org/forums/showp...55&postcount=5
Old April 28th, 2011, 07:59 AM   #3
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Carbs need to be cleaned out, especially the idle jet passages and the air bleed tubes. My '06 had 2,042 miles when I got it in February of '09 and I had the same problems; it took a full dismantling and cleaning of the carbs to get things working properly. Also, drain the old gas out of the tank and put fresh in, and install a real fuel filter in the fuel line. That'll save lots of grief down the road.
I use Brakleen (red can, not green can) and compressed air to clean everything, including dismantling the choke mechanisms. Don't get any on the rubber diaphragms under the hats.
Having Idle issues, only running on choke..??? rubber duckie 1986 - 2007 Ninja 250R Tech Talk 10 May 14th, 2017 08:31 AM
Dying at idle with choke off jonnybravo9 2008 - 2012 Ninja 250R Tech Talk 6 October 2nd, 2014 09:17 PM
Idle jumps to 9000 rpm on choke then wont stay idle after off Shawn250 2008 - 2012 Ninja 250R Tech Talk 1 June 19th, 2012 06:45 AM
Choke has no effect on idle... Help. Jono 1986 - 2007 Ninja 250R Tech Talk 15 September 14th, 2011 09:45 PM
Choke Idle Speed has Changed patw 2008 - 2012 Ninja 250R Tech Talk 21 August 1st, 2010 10:27 PM
