September 11th, 2012, 09:59 PM | #1 |
Join Date: Sep 2012 Motorcycle(s): 2005 ZX6R, 2011 Sprint GT Posts: A lot.
shift shaft oil seal replacement
Does anyone have any pointers or a how to on this? As of right now, I'm just assuming remove the shift linkage, remove the front sprocket cover, and remove the old seal with a dental tool? Any hints to make it easier?
Also, are there any places on the engine that have common oil leaks? Is a very small oil leak "acceptable?" I am very new to bikes in general, so any info you could provide on this will be helpful. Thanks. |
September 14th, 2012, 09:23 PM | #2 |
September 15th, 2012, 10:47 AM | #3 |
Make sure that there is an actual leak.
Sometimes, excess of chain lubrication lands on and drips from that area.
September 15th, 2012, 11:49 AM | #4 |
Its an actual leak. 100% sure.
"The enemy is fear. We think it is hate, but it is fear." - Gandhi |
September 15th, 2012, 11:51 AM | #5 |
Then, the procedure that you describe is correct.
Just make sure that the shaft doesn't have sharp dents that could damage the inner lip of the seal. Any defect can be flatten with a file. Also use some lubrication over the shaft.
September 23rd, 2012, 08:09 AM | #6 |
Tried replacing this yesterday. Came across an issue:
The water pump is making the seal inaccessible. In the top picture you can see where the one bolt kind of goes over the left hand side of the seal. The bottom picture, showing how it's clear on the right side for comparison. The few walkthroughs and how to videos that I have watched are for similar motors, not this one in specific. Of course all of them don't have a water pump housing that goes over the shift shaft. Will I have to split the case for this?
September 23rd, 2012, 08:18 AM | #7 |
No, just lean the bike toward the right, so the oil level clears the pump opening in the crankcase.
Disconnect the pump tubing and just pull it out. The pump shaft will slide out from the coupling. A new pump-crankcase seal may be necessary. Are you sure of not being able to pull the old seal without removing the pump?
September 23rd, 2012, 08:22 AM | #8 |
So in the top picture, I disconnect the 5? bolts to the left of the shift shaft and then pull the water pump away from the bike?
September 23rd, 2012, 08:27 AM | #9 |
Check these threads: http://forums.ninja250.org/posting.p...&t=88025&tro=1 http://forums.ninja250.org/posting.p...&t=86472&tro=1 http://forums.ninja250.org/viewtopic...b8dbd52754cd72
September 23rd, 2012, 09:08 AM | #10 |
Reading through those threads......
doesn't seem really related to this at all though. At least no mention of removing the shift seal without removing the water pump.
September 23rd, 2012, 10:07 AM | #11 |
Sorry, I couldn't find any info specific to your case.
However, those threads show that the pump can be simply pulled out and that some seals can be very hard to remove.
September 23rd, 2012, 10:14 AM | #12 |
Based on what you read in there, does it seem that I should be able to remove the pump without having to drain oil or coolant?
September 23rd, 2012, 10:31 AM | #13 |
Seems like it would be easier removing the shift shaft first then you could slide a small puller and extract the seal in a few seconds. But I guess that's a lot of work
September 23rd, 2012, 10:34 AM | #14 |
You will need to dump the coolant if you drop the pump. Might as well drop the oil if you are going g to be removing engine components... If it's new oil use a clean container and reuse it
October 10th, 2012, 02:08 PM | #15 |
This thing was such a bitch to get out. Here is the aftermath:
October 10th, 2012, 02:24 PM | #17 |
drained coolant, removed the water pump, removed the shifter, removed the front sprocket cover.
broke off 2 dental tools, bent 3 hook tools from autozone, broke a chisel. FInally got it out by heating it up and using a punch to blow like 20 holes in it before it just came out mangled. The instructions had a single sentence; "Pry old seal out." Yeah it's not that easy. Especially since the picture of the one they "removed" looks brand new.
October 10th, 2012, 02:32 PM | #18 |
did you remove the external shift shaft as well as the shifter linkage itself? did you have to take off the right side clutch cover?
October 10th, 2012, 04:17 PM | #19 |
We did not take of the actual shift shaft, no. Just the shift linkage. One bolt.
We did not take of the clutch cover either.
October 10th, 2012, 04:20 PM | #20 |
dang son, you beat the piss out of that bushing, lol.
October 10th, 2012, 04:22 PM | #21 |
yeah we messed that thing up so bad. We were asking the neighbors for all kinds of crazy things trying to get it out. Some of them are into bikes, and started gathering outside our garage with @138. It basically turned into a spectator sport for them.
Finally we got that **** out and everyone was cheering lol.
shift shaft seal | BukkShot | Items Wanted | 4 | March 21st, 2015 10:35 PM |
OEM Brand New Fork Oil Seal, Dust Seal (08-12) | capriccio | Motorcycle-related | 3 | June 9th, 2013 05:11 AM |
KX250 shift shaft replacement | YamiLionheart | General Motorcycling Discussion | 6 | March 17th, 2013 10:55 AM |
Is this shift shaft damaged? | indr | 2008 - 2012 Ninja 250R Tech Talk | 4 | January 5th, 2013 05:49 AM |
Anyone replace a shift shaft seal. | zzrguy | General Motorcycling Discussion | 3 | March 18th, 2012 09:32 AM |
