Old October 22nd, 2018, 02:03 PM   #1
Rotorhead
Motorcycle(s): 08 250R
Looking for BRIGHT LEDs...
Hi all, new member here. I did a bit of poking around already and have found many older threads on this, and have checked out some of the products recommended (blaster-x) but it's not what I'm looking for.
My '08 has stock turn signals all around. I want to put on proper, bright LED turn signals, preferable with integrated running lights (ideally, rear ones would be run-turn-brake).
I don't want an integrated like the blaster-x, as Hawaii is a safety inspection state and bikes are required to have separate signals at least 9 inches apart. Plus, as I mentioned, I'd like R-T-B or at least R-T.
I just finished a bobber project that used Kuryakyn R-T-B signals, and they were fantastic - well-made metal casings and BRIGHT LEDs...I also tried some e-bay ones that were a lot cheaper but not bright enough for me. Unfortunately the Kuryakyn ones are bullet-style and don't really match the Ninja's aesthetic.
Any recommendations for bright, multi-function LED turn signals? I'm going to run an LED flasher unit with them.
Thanks and aloha,
RH
Rotorhead is offline   Reply With Quote
Old October 22nd, 2018, 02:46 PM   #2
“Bright” is subjective.
“Lumens” is objective and measurable.
“DOT” is objective and can be proved.
Old October 22nd, 2018, 05:25 PM   #3
Ceeloo Yello
Motorcycle(s): 250
Check out Greg737's post in the pregern section.
LEDs !! chef 2008 - 2012 Ninja 250R Tech Talk 6 May 12th, 2013 07:07 PM
LEDs just came in!! smackenz 2008 - 2012 Ninja 250R Farkles 2 March 1st, 2012 05:59 PM
I'm getting LEDs.... TxriderMike 2008 - 2012 Ninja 250R Farkles 18 September 26th, 2011 08:31 AM
some leds greatwhiteninja 2008 - 2012 Ninja 250R Farkles 36 September 19th, 2011 10:18 AM
I played with my LEDs a little. Verus Cidere Pictures 7 April 10th, 2009 09:44 AM
