Old October 3rd, 2012, 04:25 PM   #41
249cc
QrtLtrDog
249cc's Avatar
Motorcycle(s): '09 250
i see. i was under the impression the gauges were disconnected. what happens when you disconnect the black wire connected to the tachometer
You asked me to show you the wires that used to be attached. The picture of the back of the gauges was taken for reference if I decided to put things together. The picture with the hanging wiring harnesses/blocks is all I have right now as far as what wiring I'm working with.
249cc is offline   Reply With Quote
Old October 3rd, 2012, 05:25 PM   #42
249cc
QrtLtrDog
249cc's Avatar
I'm getting a little frustrated. I'm going to propose a solution:
I remove the black wire from the wiring harness that plugs into the CDI and plug in my own length of black wire from the CDI to the coil. Shouldn't this bypass any potential short along the length of the original wire?
Old October 3rd, 2012, 07:57 PM   #43
flynjay
flynjay's Avatar
That should work.
What did you do to the wiring that went to the gauges? My Hypothesis is: the wires that used to go to the tach are shorting together, or the black wire is touching the frame.
Old October 3rd, 2012, 08:04 PM   #44
249cc
QrtLtrDog
249cc's Avatar
Originally Posted by flynjay View Post
That should work.
Do you know off the top of your head what gauge the wire is?
I only disconnected the gauges from the wiring harness. I haven't touched much else on the bike end
If this doesn't work...well, it has to work!!.
Old October 3rd, 2012, 08:14 PM   #45
flynjay
flynjay's Avatar
Complete guess would be 16 gauge.
So what did you do with the disconnected wires?
Old October 3rd, 2012, 08:43 PM   #46
249cc
QrtLtrDog
249cc's Avatar
I unscrewed the wires from the back of the gauge cluster. They're loose, 'cept they're still held together by the wiring harness
Old October 4th, 2012, 06:38 AM   #47
flynjay
flynjay's Avatar
So you didn't protect the ends from touching anything, just left them hanging?
Old October 4th, 2012, 08:44 AM   #48
249cc
QrtLtrDog
249cc's Avatar
No. First I removed the gauges by the wiring harness. Then on the gauge side, I removed the cables from the back of the cluster but the cluster was already off the bike. Right now, the only thing hanging off the front end are two unplugged wiring harnesses that would have gone to the gauges.
Old October 4th, 2012, 08:55 AM   #49
249cc
QrtLtrDog
249cc's Avatar
I'm going to try the wire-from-cdi-to-coil thing and see of that works. I'm a bit hesitant to try it though because I'm afraid I might blow something up. But I feel it's the only easy way to prove and fix the short in the black wire.
Old October 4th, 2012, 09:36 AM   #50
flynjay
flynjay's Avatar
The other way is to unwrap the wiring harness and trace the wire.
Old October 4th, 2012, 09:40 AM   #51
Call @Kevin2109 and have him fix it for you
Old October 4th, 2012, 09:54 AM   #52
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
16 is a little big I think. 18 maybe 20 gauge is my guess. Definitely not 22+
Old October 4th, 2012, 10:49 AM   #53
249cc
QrtLtrDog
249cc's Avatar
I am frustrated as heck man. I'm about to call it quits.
I ran my own black wire from the CDI to the coil. Multimeter says 11volts with red probe on coil 1 red wire and black probe on my CDI black wire. I crank the bike and still NO SPARK. What now? :'(
Old October 4th, 2012, 10:56 AM   #54
249cc
QrtLtrDog
249cc's Avatar
I finally figured it out. I tried my girlfriends CDI again. It sparks now with the makeshift cable. Don't know why it didn't work before.
Thank you all so much for your help. Anyone selling a cdi ?
Old October 4th, 2012, 11:26 AM   #55
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Maybe, what are you paying?
AFM #676
Supersports are for n00bs
Old October 4th, 2012, 12:13 PM   #56
n4mwd
n4mwd's Avatar
The short may have burned out your CDI. Try ebay. And get one as close to your year as possible. Certain years are not compatible.
My Ninja Blog
Old October 4th, 2012, 12:38 PM   #57
flynjay
flynjay's Avatar
To verify your cdi is not working, try it in your girlfreinds bike.
I may have a cdi, I'll look when I get home ~6pm CST.
Old October 4th, 2012, 06:21 PM   #58
249cc
QrtLtrDog
249cc's Avatar
I can confirm, I am the fried CDI...
Seriously though, it didn't work. are CDIs expensive?
Old October 4th, 2012, 06:40 PM   #59
FvnnyL3tt3r1ng
http://www.kneedraggers.com/oem-part...mmy_source=oem
Old October 4th, 2012, 06:46 PM   #60
249cc
QrtLtrDog
249cc's Avatar
Originally Posted by FvnnyL3tt3r1ng View Post
There's a California ignitor? Would any other state cdi work?
Old October 4th, 2012, 06:49 PM   #61
249cc
QrtLtrDog
249cc's Avatar
Will a non California CDI work in my California bike? I found a couple on eBay for $40.
Old October 4th, 2012, 08:08 PM   #62
n4mwd
n4mwd's Avatar
I don't think california is different, but some years have different wiring.
My Ninja Blog
Changed Spark Plugs; Right Side Boot Won't Snap In Easily Lil_Green_Demon 2008 - 2012 Ninja 250R Tech Talk 8 February 16th, 2015 10:09 AM
Is it a huge issue not to use anti seize on spark plugs? tsdexter 2008 - 2012 Ninja 250R Tech Talk 4 June 27th, 2013 06:23 PM
Removing spark spark plugs? tsdexter 2008 - 2012 Ninja 250R Tech Talk 3 June 26th, 2013 03:48 PM
[crash.net - MotoGP] - Depressing race for Ducati Ninjette Newsbot Motorcycling News 0 July 18th, 2011 03:30 AM
[topix.net] - Motorcycles promoted to fight the most depressing day of the year Ninjette Newsbot Motorcycling News 0 January 16th, 2010 01:00 PM
