September 7th, 2011, 10:57 PM | #1 |
Revolver Wario
Join Date: Jan 2009 Motorcycle(s): 2003 Ninja 250 Posts: 198
Logo Dude
Turn Signal Relay Help
So the first bike shop that I went to swapped my CDI box with a box that wasn't even for the right bike, and took parts of my carbs. I just found out that they swiped my turn signal relay too, so I was wondering if you guys could help out.
Is there an alternative to the Denso fe246bh that I can use? I read in another thread someone used a Napa 552 thermal relay flasher, but not sure if that's 100% legit. Would I be better off getting the Denso off of eBay? Or is there a comparable part I can get at an Autozone or something?
September 7th, 2011, 11:50 PM | #2 |
Gear crash test dummy
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r Posts: A lot.
a tridon E34, pretty sure its that one... Tri (user CThunder_blue) he uses these things plenty and knows what he's talking about.
Anyway that one should work, but check with Tri! |
September 8th, 2011, 11:45 AM | #3 |
Revolver Wario
Logo Dude
Would you be referring to the EP34? Are these things readily available from a local shop?
September 8th, 2011, 12:45 PM | #4 |
Revolver Wario
Logo Dude
Thanks for the help. Just ended up buying a used relay on eBay.
September 8th, 2011, 01:21 PM | #5 |
IC2(SW)
September 8th, 2011, 02:14 PM | #6 |
Revolver Wario
Logo Dude
Owner of the shop facing mad litigation, bailed to France, prolly isn't coming back soon.
September 8th, 2011, 05:50 PM | #7 |
I used the basic one with the same connector as the stock one from superbrightleds.com since I went with LED's. I'm willing to ship you my stock relay as long as you pay shipping, but I won't be home for a few weeks until fall break
September 8th, 2011, 05:55 PM | #8 |
Revolver Wario
Logo Dude
Thanks man, really appreciate the gesture. I already ordered one from eBay, hopefully it'll be in by next week.
September 8th, 2011, 06:03 PM | #9 |
glad you got something that works. In the mean time, get good at hand signals to make turns
January 18th, 2012, 09:28 AM | #10 |
Join Date: Jan 2011 Motorcycle(s): 10' Ninja 250R Posts: 164
Hi. I'm using a led taillight and led turn signals. All installed with 25w resistors.
But when the turn signal are blinking, the reds in tail light blinks off. Anyone know how can I fix it? Maybe a relay could fix?
January 18th, 2012, 10:32 AM | #11 |
you need a diode for more than one set of LEDs to function properly. modmy250.com has a no-cut diode kit. Ask Tri on this site CThunder-blue, he's the owner of the site/creator of the kit. He can verify a diode is what you need and help you out.
January 18th, 2012, 10:37 AM | #12 |
Thanks! I'll ask to him.
January 18th, 2012, 12:35 PM | #13 |
No need to ask, it's right on his site:
http://modmy250.com/LP.html Ninja 250R 2008-2011 No-Cut Diode kit $15.00 |
January 18th, 2012, 01:25 PM | #14 |
Milkshake Drinker
Join Date: Aug 2011 Motorcycle(s): 2007 Orange DRZ400-S, 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
If you're running LEDs, you could just run a 40-Cent 555 and a transistor instead of a relay
Posted via Mobile Device |
January 18th, 2012, 09:00 PM | #15 | |
Join Date: Mar 2010 Motorcycle(s): Several Posts: A lot.
http://www.cyclegear.com/eng/product...lay/web1006869 It's plug and play. |
January 18th, 2012, 10:05 PM | #16 | |
Milkshake Drinker
"What a sweetheart."- ninja_sleeper to me |
How to install LED front turn signals & relay | CThunder-blue | 2008 - 2012 Ninja 250R Farkles | 56 | August 17th, 2014 02:31 PM |
turn signal relay flasher install | contact148 | 2008 - 2012 Ninja 250R Tech Talk | 11 | October 8th, 2013 02:05 PM |
Looking for 09 oem rear turn signal and front turn signals and tail fairings | mbbernas | Items Wanted | 1 | September 11th, 2013 10:48 AM |
'08 Turn Signal Relay | Countersteer | Motorcycle-related | 0 | June 10th, 2012 01:54 PM |
