July 9th, 2010, 05:51 PM | #1 |
Join Date: Jul 2010 Motorcycle(s): Black '11 ZX-6R Posts: 209
photon flushmounts
I hooked up one and while it blinks my back stock blibkers just stays on...What should i do?I'm sure im going to get clowned but just give me a straight forward answer please.Thanks!!!
My 250 is mine and mine alone, you may see better you'll definitely see worse but mine, she's one of a kind!!!!btw, SHE'S SEXY!!! |
July 9th, 2010, 09:57 PM | #2 |
Join Date: Jul 2009 Motorcycle(s): 2008 blue 250r "KameSane" Posts: 67
you have to connect the right wires, look at the paper work it came with. there's like 3 different settings you can set the blinkers to do. i don't think you connect all the wires. i had someone install them for me, but i'm pretty sure it said in the paper work how to connect it.
July 9th, 2010, 10:20 PM | #3 |
ninjaholic
Join Date: Jun 2010 Motorcycle(s): 09' SE 250R (sold), 03' ZX-6R, 99' XL1200C SP Posts: A lot.
If you haven't done the diode mod and swapped the flasher relay for an electronic version that would be your problem.
09' SE Ninja 250R $2,547.83 worth of mods installed... come on Unregistered, you know you want to know what? Check my Blog "Modification List" |
July 9th, 2010, 11:13 PM | #4 |
what are photon flushmounts?
July 10th, 2010, 09:12 AM | #5 |
ninjaholic
I assumed he meant Proton flushmounts... but I could be wrong
July 10th, 2010, 09:22 AM | #6 |
yes proton and can i get link to diode mod. i went to autozone to get relay according to a post and it didnt work
July 10th, 2010, 09:42 AM | #7 |
You said you hooked one up - the stockers will stay solid if all 4 are not connected...
July 10th, 2010, 09:56 AM | #8 |
i had three stosks hooked up and one proton. The side with two stocks worked ok but the side with one of each, the proton would flash (kind slow i think) and the back stock stayed solid. I went to replace stock flasher according to someone it was on left side but what i see that looks like flasher has something also hooked to it that runs to engine.I AM SO FRUSTRATED RIGHT NOW ITS NOT FUNNY!!!Something that show have been so seimple has my bike in pieces.
July 10th, 2010, 10:30 AM | #9 |
July 10th, 2010, 08:25 PM | #10 | |
Join Date: May 2009 Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt Posts: A lot.
July 10th, 2010, 10:03 PM | #11 | |
ninjaholic
Also, here is a link to follow to build the diode kit you need: http://www.ninjette.org/forums/showp...6&postcount=76 Then you can get a good idea of where it goes from this thread: http://www.ninjette.org/forums/showthread.php?t=24500 (I have a better set of pictures that I saved from some thread somewhere but can't find it now that I put into a word document and printed for when I did my install... if you can't figure it out from what I've provided here just let me know and I will e-mail my word doc to you if you want it.) Lastly, you need to purchase a CF12ANL-01 relay from www.superbrightleds.com here is the link for that, trust me it works and you will thank yourself, I had the one from autozone and it didn't work for this application... here is your link: http://www.superbrightleds.com/cgi-b...ers.htm#Table4 If you need anything else just let me know... this install frustrated me until I got the right parts and put everything together properly... good luck!
July 10th, 2010, 10:48 PM | #12 | |
That said, I do agree that the red wire is entirely extraneous for any application involving mating the protons to just stock wiring (you'd have to do some modification of the main electrical harness to make use of the running lights). Don't recommend wasting your time with the red wire, best to keep the wiring clean and leave it out. +1 to the CF12ANL-01 relay from superbrights. Works great. In theory, just getting the right relay should resolve the issue the OP is having. Diode mod is more for people switching to all-LED. I could be wrong, but that was my experience installing protons with otherwise-stock blinkers.
July 11th, 2010, 12:27 PM | #13 |
Confirmation
Here are pics of the stock relay, where i got it from and what wires were hooked up to it when i took it off, to make sure im working with right part.Is that the stock flasher relay because it seems to be configureed differently.
July 11th, 2010, 01:32 PM | #14 |
That looks like the starter relay.
Below is what you want to replace. |
July 11th, 2010, 01:50 PM | #15 | |
ninjaholic
Yes, with both wires connected once you selected the blinker it would flash dim... bright... dim... it never went out until you pushed the switch back in.
July 11th, 2010, 02:04 PM | #16 |
Whew ok thanks fellas. i had feeling that was the wrong thing the second i saw it had power supplied to it. I feel kind of stupid but much better. Again, THANKS!!!!!!!!I'll go ahead and order that relay from the link you sent me Cazper
July 11th, 2010, 04:30 PM | #17 |
Its alive!!!!!!
Thanks everyone who helped. I hooked up the fl-32 relay and everything blink and at a good blinking rate.I going to use that relay until i get teh relay Cazper recommended.I am so relieved.Thanks for the help again!!!You friendly neighborhood NOOB!!!!!!!!!!
***WTB*** Asian Cycle Flushmounts | kazman1 | Items Wanted | 0 | January 3rd, 2013 10:38 AM |
ModMy250's Flushmounts vs. Protons | AeroXtasy | 2008 - 2012 Ninja 250R Farkles | 26 | August 30th, 2011 11:24 PM |
GB #2 for P&P LED flushmounts!!! | CThunder-blue | Motorcycle-related | 36 | July 30th, 2011 06:41 PM |
Alternative to Proton flushmounts? | sarapacman99 | 2008 - 2012 Ninja 250R Farkles | 25 | May 29th, 2011 03:39 PM |
anyone have these? (flushmounts) | ajaygraci | 2008 - 2012 Ninja 250R Farkles | 11 | May 23rd, 2010 06:08 PM |
