April 17th, 2014, 08:26 PM | #1 |
Join Date: Jun 2013 Motorcycle(s): 2010 Kawasaki Ninja 250R (Passion Red, Ca Model) Posts: 107
I highly Despise my Carbs!!
So my bike has been acting up lately. Yes its those darn Carbs again, at least I think so. The bike seems to be hesitating at the top end it doesn't want to rev to redline. After 9k-11k it just feels forced to keep going. It also makes weird crackling pops and it almost feels like it's missing the power. It will also refuse to go past 85-90mph. I don't know why it started doing it, it seems like it just started out of the blue. The bike was running fine during the winter, not so much now that its starting to warm up.
The bike has pods, smog delete with block of plate, full exhaust, newish Iridium plugs, its Rejetted with DynoJet kit. 108 mains, stock pilots, 2 1/2 to 3 turns not sure, needles in the 3rd clip, elevation 600 or so feet. I recently did the old ninja CDI box swap but it was running fine before. I'm going to pull the plugs soon and inspect them. I also checked for vacumm leaks, resynced and cleaned the pods not to long ago. Any suggestions? I am going to rejette again hopefully that solves my issue. Going to try 110 mains and #40 pilots, mid range seems fine might add a washer, maybe even drill the slides. It also has a erratic idle no matter what i do. If I bring it to 1500rpms it climbs to 1700rpms then settles back down. If I lower it under 1500 it iddles real low, just shy of 1k. It also doesn't turn on without full choke on. Im just frustrated with it, when I apply the choke when the engine is somewhat warm it boggs a little , drops the rpms then starts to climb again. So its hard to tell if its lean or rich.. Once she's fully warm then the lean idle symptoms arise.. I checked all the wires on the cdi box all is well. Any help or suggestions would be much appreciated.
I would be rich by now if I had a dollar for every person that has told me "You need to upgrade, You need a bigger bike, You need more power..." |
April 18th, 2014, 06:35 AM | #2 |
How old is the gas?
What's the condition of the air filter? |
April 18th, 2014, 06:45 AM | #3 |
The plug color will tell you if your lean or rich. Light color/white = lean, dark color/black = rich. Check the simple stuff first though, battery connections, gas, filters (pod/fuel), carb boots, petcock, vac leaks, ect, ect.
Pods are more fickle to temp changes and somewhat a pain to tune. Your gunna have to pay someone to tune it or... learn to love carbs or... loose the pods. /real-talk Good luck!
April 18th, 2014, 07:18 AM | #4 |
Fuel is good always use 93 and it never has sat more than 2 weeks. I'll pull the plugs today, and inspect everything else. I'll probably end up pulling the carbs out and opening them up, make sure everything looks clean..
April 18th, 2014, 07:21 AM | #5 |
Save dem pennies yo, there really isn't a "need" to always run 93 all the time. In fact, you might find the bike performs better with the cheap stuff.
April 18th, 2014, 07:32 AM | #6 |
Once I moved to Tn from Cali I started putting 93 in everything even my Bronco and lawn mower lol.. Gas is cheap over here so I take advantage of it.
April 18th, 2014, 08:27 AM | #7 |
Join Date: Jul 2012 Motorcycle(s): 2010 Ninja 250 2009 Ninja 250 Posts: 730
2010 Red Ninja 250 2009 Black Ninja 250 -If you ride like lightning,you're gonna crash like thunder- |
April 18th, 2014, 08:44 AM | #8 |
Just a few things to consider
1. Gas- 87 octane is better than 93 for the Ninja 250. Winter gas is good for the winter, but would be better for summer it you could get it. E0 87 octane is what you want. More octane does not necessarily equate to better running or more power. Even though you've basically changed your timing with a CDI swap, your compression did not change. Read; The truth about winter gas Bad Gasoline More Octane For More Power? | Mythbusters 2. Erratic idle- Could be battery/electrical issues; Motorcycle Battery Maintenance & Battery Charger Tips 3. Idle speed- Your Ninja is no longer stock, so the stock idle setting really does not apply to your application. Many have increased their idle speed a little to what performs best. Last futzed with by DaBlue1; April 18th, 2014 at 05:35 PM. |
April 18th, 2014, 11:15 AM | #9 |
Plugs
Here are my plugs, I kept the motor at 9-10k rpms then shut it off. Battery was fine had a full charge in under 2 minutes. I'm going to open up the carbs and see what I find..
April 18th, 2014, 11:59 AM | #10 |
Your plugs look OK, but your filters look a little blue. Is that FAB 1 on them?
Too much FAB 1 can cause the filter not to breath well. Ask me how I know. |
April 18th, 2014, 01:00 PM | #11 |
Yeah that's the stuff... I remember once I ran it without the filters just parked and it ran well.. Started up easier with hardly no choke..
April 18th, 2014, 02:03 PM | #12 |
It's good stuff and only takes a little bit. You have to spray a little bit and let it sit. If a spot gets to much, press the filter into that spot. I accidently sprayed too much on my filter that has much bigger pores than yours. It instantly ran like crap after putting it in. So it was re-clean, re-dry, re-oil. All good.
April 18th, 2014, 03:18 PM | #13 |
Join Date: Apr 2013 Motorcycle(s): 2013 600RR, 2009 250r Posts: 130
April 18th, 2014, 05:19 PM | #14 |
Everyone is trying to persuade me to use regular.. I suppose I can try a tank full once I get the old gas burnts up. The bike is in shambles right now, doing a whole bunch of random stuff as usual.
April 18th, 2014, 05:42 PM | #15 |
Try it on pure gas if you can. None of that ethanol bullsh**
April 18th, 2014, 05:46 PM | #16 |
I do whenever I get a chance and I'm not lazy, its a 45 mnt journey round trip. But I've only used the 93 ethanol free not 87..
April 18th, 2014, 05:59 PM | #17 | |
Also, meant to say good luck with your ride. I hope all ends up well with it and you can enjoy her. |
April 20th, 2014, 07:18 AM | #18 |
So I inspected the bike, looked at what you guys suggested. Everything checked out OK. I decided to mess around with the jetting, the needles were left as they were 3rd notch from the top with two washers. I changed the pilots to #40s and turn the idle air mixture screws 2 1/4 turns out.
So I went to both extremes on the main jets. I took out the 108s and dropped in 110s. What I noticed was the bike was running way too hot, previous symptoms got worse, hesitation, crackling, rpms not wanting to climb after 9k rpms. I could just smell yummy gas fumes coming out the pipe. I knew it was bad to I only rode for about 3mnts. The idle still hangs a little but it got better than before, and the transition from off idle to the neddles is very smooth now, and then all hell breaks loose when I hit the main jet circuits. So I pulled the carbs opened them up and take out the 110s and install my 104s. I was real excited and figured that would fix it. Went for a test ride and all the symptoms stated previously became worse! Except the smell of fuel. Now from 8k rpms it would just crackle and sputter and the rmps would just fight each other trying to climb up but couldn't in any gear. The plugs with the 110s were very similar in color to the 108s. The bike revs freely in neutral with no load. There's no vacuum leaks or broken hoses. One thing I do need to do is disassembled and inspect the fuel petcock, but I've never done it. The battery had some slight corrosion on the positive terminal so I cleaned that up. I might also switch back the CDI box the OEM one. Try and rule out that possibility. I'm confused........... .... It must be the Gremlins!
April 20th, 2014, 07:48 AM | #19 | |
April 20th, 2014, 07:59 AM | #20 |
I haven't done that yet, thanks for the reminder. The 104s are still in there I filmed a video but my roommate ran off with the laptop so I can't upload it right now. Here's a picture of the plug
April 20th, 2014, 08:10 AM | #21 |
April 20th, 2014, 08:23 AM | #22 |
Yeah that's what I don't get, it looks like that with 110,108,104 main jets. I just came back from test ride with the filters off. Problem still persist now it starts lower in the rpm range, and you can hear it better too... I'm thinking maybe it's the CDI box..? I'm probably going to put my old one back on, and test it with the 104s and the 108 main jets... See what happens... Unless a 106 main jet will fix it? Which I don't have..
April 20th, 2014, 09:15 AM | #23 |
yikes! all this time consuming working messing with the carbs, and the only thing you recently changed was the CDI? Might be worth a shot , and easier, just to swap the OEM one back in and see if it corrects the problem
April 20th, 2014, 09:45 AM | #24 | |
"- Performance gets worse when the air filter is removed." is a typical lean condition Did you re-clean the air filter? CDI's can go bad without warning. Should be simple enough to switch back if you didn't hack up the harness too bad. |
April 20th, 2014, 10:32 AM | #26 | |
I have the #40s in it right now, the bike runs good with those.
April 20th, 2014, 12:09 PM | #28 |
Because its idling smoothly.. What would changing the pilots do for wot? Isn't that what the main jets are for? Here's a crappy video, you can't really hear well. But towards the end you can see the idle is spot on..
April 20th, 2014, 12:19 PM | #29 |
April 20th, 2014, 05:28 PM | #31 | |
Here's a picture of my art work that I did to the bike. Still don't know if I like it.. That plastic dip stuff sucks.. I also broke my rear blinker I shortened it and broke the epoxy..
April 21st, 2014, 10:27 AM | #32 |
April 21st, 2014, 10:33 AM | #33 | |
April 21st, 2014, 10:40 AM | #34 | |
Basically, the lowest octane you can get without ethanol is the best choice IMO. |
April 21st, 2014, 10:41 AM | #35 |
April 21st, 2014, 10:46 AM | #36 |
I did a test ride with no filters and the 104 mains, symptoms stayed the same, and were also more noticeable. I did not run the bike with the 108s and no filters. I did clean the pods and lightly oil them, still the same.
Bikes back together now, it's rideable but I wouldn't want to go WOT over 9,000 rpms.. It won't do over 85-90mph either. It runs like crap with 110s and it runs like crap with 104s.. With 108s, still runs like crap but less noticeable, so hopefully 106 is the lucky #s. On the plus side I can take the carbs out under 5 mnts! With no front fairings installed..
April 21st, 2014, 10:51 AM | #37 |
I found a gas station 5 mnts from my house that sells both. Once the bike is running well I'm going to test MPGs and the dyno butt to see if it runs better on 87 or 93 eth. free. It just really bugs me to put 87 in it after years of running fine with 91oct and 93oct. Its had 89 once cause that's the highest they had and I only pumped like a gallon. And now it has like 1 gallon of 87 eth. free for testing purposes..
April 21st, 2014, 01:37 PM | #38 | |
As far as octane goes - more octane doesn't mean more power. It only means more resistance to detonation - that's it. To make the most amount of power you want the least amount of octane that you can run without detonating - you make the most power right on the edge of where detonation occurs. For a stock engine, anything over 87 is not required and will give you less of everything - power, mileage, and economy. Again, that's comparing non-ethanol 87 to non-ethanol 89/91/93. I still think you are best with the lowest octane fuel that doesn't contain ethanol - sometimes that may be Premium. |
April 26th, 2014, 02:43 PM | #39 |
Update! Bikes Fixed!
So I left the carbs how they were originaly with the 108 mains, #40 pilots, I did however switch the CDI back to the OEM one. That helped a little bit. I rode the bike one cold morning it was in the mid 40s and the bike still had the symptoms. I was starting to suspect it might be the valves. They were due an adjustment in 1.3k miles so I figured might as well rule that out.
Just picked the bike up today they said one exhaust valve was loose, and they also swapped out my fairly fresh iridium plugs! I was like WTF, the service guy had said they do that with the valve adjustment. So I kindly requested my old ones. I was able to do a small very small power wheelie shifting into second!. It was confirmed by my son behind me in the truck. All my symtoms went away, and I can now do triple digit speeds. After I did my 100mph celebration test run, I pulled up to the light and my temp light came on momentarily, it is 80* outside right now. I might go back to the old CDI box because it tweeked the low end circuit on the carbs so it's a little rich not horrible though. I might still install the 106 mains. But maybe later, right now I'm just glad it runs like normal again.
April 27th, 2014, 05:38 AM | #40 |
[motogp.com] - Espargaro and Smith highly motivated for final third | Ninjette Newsbot | Motorcycling News | 0 | September 10th, 2014 03:25 AM |
Highly modded 250s | sixstring | Pictures | 51 | October 19th, 2013 03:50 AM |
I despise USPS | subxero | Off-Topic | 14 | July 14th, 2013 02:59 PM |
Driving, how I despise thee... | Apex | Off-Topic | 3 | November 13th, 2012 04:18 PM |
I highly recommend getting a motorcycle/atv jack | Apex | General Motorcycling Discussion | 5 | May 11th, 2009 04:40 AM |
