April 20th, 2011, 05:43 PM | #1 |
Join Date: Apr 2011 Motorcycle(s): CBR 600 F4i, 06 250R Posts: 28
Quick question, spark plug removal
Is the 08+ spark plug removal tool the same as the pre-gens? My 06 didn't come with a tool kit, and I can find more new gen tool kits for sale than pre gen.
April 21st, 2011, 10:18 AM | #2 |
Generally it is all the same. Most sparkplug sockets have built in plug retrievers. Hell you can use a piece of rubber hosing to remove it.
I usually stick the coil pack connector back in to retrieve the spark plug after i loosen it. |
April 21st, 2011, 10:30 AM | #3 |
Do you know what size socket I need for it? I'll probably just go buy one at autozone or someplace.
April 21st, 2011, 10:34 AM | #4 |
5/8 sparkplug socket. Look inside of it should have some sort of rubber bushing to secure a plug when loose.
April 21st, 2011, 08:11 PM | #5 |
Join Date: Feb 2011 Motorcycle(s): Ninja EX250R Posts: 80
As mentioned hose also works great to pull them out. On my WRX b/c the spark plugs go in the sides of the motor (flat IV), I can't even change my plugs without my handy 5/8" fuel hose to retrieve my spark plugs.
On the Ninja though the OEM tool is next to none in removing the plugs. With a little modification from a dremel it also worked on my friends ZX7, which a normal 5/8" socket wouldn't fit. I'm not sure off hand if the newgen tool is identical to the pregen or not, but I'm willing to be it is. |
Replacement Spark Plug Removal Tool | Roark | 1986 - 2007 Ninja 250R Tech Talk | 8 | January 27th, 2015 04:54 PM |
spark plug removal | eddiekay | 2008 - 2012 Ninja 250R Tech Talk | 3 | October 21st, 2011 10:56 AM |
spark plug cleaning before removal | wkiltz | 1986 - 2007 Ninja 250R Tech Talk | 5 | July 10th, 2011 06:15 PM |
Quick Airbox removal question | forevertwowheels | 2008 - 2012 Ninja 250R Tech Talk | 11 | June 14th, 2011 04:31 PM |
Spark Plug Replacement Question | paterick4o8 | 2008 - 2012 Ninja 250R Tech Talk | 4 | September 17th, 2009 09:16 PM |
