January 12th, 2012, 10:36 PM | #1 |
?>ninja = i think not
Join Date: Jan 2012 Motorcycle(s): ninja 250 NINJA 650 Posts: 91
Why my 250r isn't faster than your 250r
I seafoamed it and it still wont go 100 mph.. only will go 95 maxed.... n i think it was down hill... im not sure it coulda been though: mad:
January 12th, 2012, 10:38 PM | #2 |
Jigglin' your Jiglets
MOTM - Apr '13
Try eating salads.
January 12th, 2012, 10:39 PM | #3 |
im not heavy at all... it might be my tires
January 13th, 2012, 07:48 AM | #4 |
Avid Kitteh Poster
Join Date: Sep 2011 Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT Posts: A lot.
youre probably just fat...
haha jk jk maybe your speedometer is actually semi accurate... hahaha
I powdercoat stuff Help me pay for my addiction I say funny stuff. http://twitter.com/JustinPWNSyou sometimes... I write like a 12 year old too, http://justinpwnsyou.wordpress.com/ |
January 13th, 2012, 09:55 AM | #5 |
Smoker
Not that I advise doing so on the street, but if you are going to try a max speed run, you have to top out every gear. And you have to do it on a flat plane. A downward grade is cheating.
January 13th, 2012, 12:18 PM | #6 |
Ok but top out up to which revolution?
January 13th, 2012, 03:09 PM | #7 |
Not necessarily, the engine starts falling off the powerband at 13,000 rpm, so as Racer X pointed out, it's actually quicker if you shift at 13,000 and don't waste time waiting for the engine to reach redline. The bike makes peak torque at a lower RPM than it makes peak power anyways, so there's really no need to rev much past peak hp rpm
January 13th, 2012, 03:41 PM | #8 |
MOTM - Sep '18, Feb '16
What I do is test the engine on the dyno. That tells me the max hp at what RPM. Then I use another formula to determin how much speed can be gotten from that amount of power . Then I select a gear ratio that will put the engine at that rpm. As for shifting you want to shift above the power band. But not to much .
January 13th, 2012, 09:24 PM | #9 |
tried it again...only 95(down a slight grade)
i just want to know that every has the same final speed...if not then I need to do something about that |
January 13th, 2012, 10:11 PM | #10 |
Milkshake Drinker
Join Date: Aug 2011 Motorcycle(s): 2007 Orange DRZ400-S, 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
Well, cycleworld...or maybe Motorcyclist...magazine tested the 2008 model when it first came out and got a top speed of 97mph. The same magazine had previously tested the pregen to top out at 101mph.
"What a sweetheart."- ninja_sleeper to me |
January 13th, 2012, 11:23 PM | #11 |
Join Date: Apr 2011 Motorcycle(s): 2001 Ninja 250 Posts: 65
I did 105mph indicated multiple times with my pregen, easier then I thought it would with more to go. 80 series sidewall pirellis(95mph rated, why I didn't push it further) and a 2-1 exhaust, that's it..
January 14th, 2012, 04:36 AM | #12 |
Right around 100 mph for the new Ninja. And a little faster for the older ones is how fast I have see them go at Maxton.
January 14th, 2012, 06:06 AM | #13 |
B-Town Ninja
Join Date: Feb 2011 Motorcycle(s): Black 2013 Ninja ZX6R ABS Posts: 609
Break in method could have an apparent effect on your top speed as well.
I don't think you should be concerned with getting around 100mph as a top speed. When I was bone stock, I think mine only hit around 95mph (gps) with me at around 200lbs with gear.
Downgraded to a 2013 636. Previous owner of a 2010 250r --------------------------------- My moto-vlog YouTube channel http://www.youtube.com/bloomingtonninja |
January 14th, 2012, 06:37 AM | #14 |
An easy way to increase apparent top speed is to install a smaller front tire.
January 14th, 2012, 07:40 AM | #15 |
Join Date: Aug 2011 Motorcycle(s): 2009 Ninja 250r (Sold), 2009 FZ6, 2015 Honda Grom Posts: 898
I can only hit about 100 indicated, and I'm only 135 lbs. Not really concerned though because that's about 20 mph faster than I need to go.
January 14th, 2012, 10:00 AM | #16 |
January 14th, 2012, 12:33 PM | #17 |
Super Noob
Join Date: Oct 2011 Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc Posts: A lot.
I've done 110 mph (indicated) on the highway ( I-10, sunday, 4 am) with the bike bone stock. I'm 150lbs (+ 20-10 lbs gear). I apply a pinch of seafoam with every fill up and during my top speed run I was shifting at around 11,000 to 13,000 rpms.
But all that probably means nothing since I didn't use a gps. Maybe it's time for another run... |
January 14th, 2012, 12:44 PM | #18 |
MOTM - Mar '13, Jun '14
Where are the speed limits 95 or over 100mph. I'd like to go that fast but don't want to get a ticket. I'm not a law breaker (although it sounds like fun) and I don't know what I would tell an officer of the law why I would ever be going to fast if I got pulled over. I think they confiscate your bike over a certain speed.
Now on the track is a different story. I would be too worried about about doing 95 or even 100 ( as long as there is ample space to slow after hitting those craze speeds). Don't you get blown off the bike at anything over 70 or 80? How do you hold on? How can you even see at those speeds?
January 14th, 2012, 12:47 PM | #19 |
I really want to believe its because of my tires... here in Ga even the semi trucks go 80 mph (on the slow lane) people out here are crazy, and I dont always try to top out, im fine crusing around 70-80 on the hwy, Honestly though on a daily basis, these people are riding more than 70 on any lane
January 14th, 2012, 12:50 PM | #20 |
Don't you get blown off the bike at anything over 70 or 80? How do you hold on? How can you even see at those speeds?[/QUOTE]
No I havent felt like I was going to get blown off, usually im tucked. Its really not much of a difference for me, and its easy to see at those speeds, especially because like I said, most people are traveling around those speeds anyway. |
January 14th, 2012, 01:11 PM | #21 |
Super Noob
Maintain full tuck while keeping your rear as far back as possible usually gives the best of results. The only problem I have with traveling in such a manner is shifting. Shifting can be a BIG pain in the you-know-where if you have stock rear sets, so I don't fully tuck in during 1-5th gear, but after getting on the 6th, it's tucked in, ass against the rear seat and watch that needle slowly creep past 100!
January 14th, 2012, 03:13 PM | #22 | |
Join Date: Dec 2010 Motorcycle(s): 2005 ninja 250 street fighter, 2008 street fighter ninja 500, 2001 nsr 125 Posts: 812
That's top speed for post-gens with pre-gens around 100. Actually phenomal condidering you're carrying over 30 lbs. extra weight. Without a speedo you wouldn't notice the difference anyway bro, plus it ain't no thing anyway. |
January 14th, 2012, 03:20 PM | #23 |
January 14th, 2012, 03:55 PM | #24 |
yeah but the bike still has stock with 9k plus miles
January 14th, 2012, 03:57 PM | #25 |
and that makes a difference on the top speed how?
Still might want to change them. You have an '09. It's 2012. Tires age. |
January 14th, 2012, 08:53 PM | #26 |
no grip, i just got this bike sept, so i tackling each thing at a time
January 15th, 2012, 01:13 AM | #27 | |
Milkshake Drinker
I opened it up going down that hill (about a mile and a half long straight, slight tailwind, full tuck) I hit 118mph indicated (108mph actual). Bike was a 2006 Ninja 250, bone stock.
January 15th, 2012, 07:48 AM | #28 | |
January 15th, 2012, 10:33 PM | #29 |
Join Date: Dec 2008 Motorcycle(s): 2008 Ninja 250r - Traded for 2009 ER-6N Posts: 424
I've done 105 on a naked bike. It's not that hard to hold on, and the helmet visor goes a long way towards helping you to see. I used to cruise on I-4 on my 250 keeping up with traffic (80MPH or so, 85MPH indicated) and the wind blast was easy to deal with, Just tuck and roll (faster.)
January 16th, 2012, 05:06 AM | #30 |
I hold the record for the fastest naked 250 ninja at 114 mph. The stock fairing is worth about six mph at best. I hope to make a better fairing for 2012.
January 16th, 2012, 05:11 AM | #31 |
Join Date: Jan 2011 Motorcycle(s): 10' Ninja 250R Posts: 164
My bike goes faster with better gas.
I'm using high octane gasoline because of that.
January 16th, 2012, 06:31 AM | #32 |
Using higher octane fuel is OK when it's pump gas. But over 105 with the the stock compression will hurt power
January 16th, 2012, 07:00 AM | #33 |
Just wondering...what rpms are you turning at that speed? Are you still running stock gearing? If so, try a 15t front sprocket.
January 16th, 2012, 10:27 AM | #35 | |
Smoker
January 16th, 2012, 12:13 PM | #36 |
Right, but even though it's still pulling, if you only shift a little past peak power, when you shift, your revs will drop right into or almost at peak power, and you'll get the most acceleration. So it would still be quicker to shift at 12,500 or 13,000 rpm instead of waiting till the rev limiter cuts in at 14,500 rpm.
January 16th, 2012, 12:51 PM | #37 |
At the drag strip you want to shift just past the point where the power curve starts to drop. Waiting past there is no good because it is time spent below max power. When you are timing a bike to 100 th of a second. The time between 12500 and 13500 could be half a second or more in the taller gears.
January 17th, 2012, 07:08 AM | #38 |
Is that sugar cane petrol?
January 17th, 2012, 09:24 AM | #39 |
Not excatly.
Here in Brazil all petrol needs to be 20% sugar cane alcohol. So, I use what they call premium gasoline. That have 80% petrol, 20% alcohol and octane additives. That rates 92 to 95 octanes, varies each brand.
January 20th, 2012, 09:52 PM | #40 |
Crashing is just practice
Join Date: Jun 2011 Motorcycle(s): 2009 Ninja ex250 (Tinkerbell); 2008 Ninja ex250 (Frankenstein) Posts: 101
I've found I also get my best speeds when in full tuck. I'm about 135lbs and managed about 115mph on a slight downgrade, but 110 on flat ground. 6th gear, pinned throttle, K&N filter, Yoshi slip-on, raised rear suspension, 91 octane.
Could be anything man. Maybe take some time to go through and make sure every part is functioning at peak performance? Clean hoses, carbs, fuel filter, piston o-rings, so on so forth....
SEMPER FI ~*UNSTOPPABLE*~ Kawasaki - Green means GO! |
[faster and faster] - Ducati Monster Diesel: Could have been cool, but isn’t | Ninjette Newsbot | Motorcycling News | 0 | March 16th, 2012 05:40 AM |
[faster and faster] - 2012 KTM 690 SMC R: ‘What isn't there doesn't weigh anything…’ | Ninjette Newsbot | Motorcycling News | 0 | March 13th, 2012 10:30 PM |
Why your 600 isn't faster than my 250r | joes280 | General Motorcycling Discussion | 216 | January 19th, 2012 01:15 PM |
Why my 250r isn't faster than your 600 | Jiggles | General Motorcycling Discussion | 60 | January 12th, 2012 08:17 PM |
[faster and faster] - Honda: The RC212V isn’t good enough! | Ninjette Newsbot | Motorcycling News | 0 | May 6th, 2009 09:20 PM |
