Old May 28th, 2012, 03:15 PM   #1
Boomstick1491
Name: Carlos Spicy Wiener
Motorcycle(s): Too many
Exclamation Brake Light Issue
My brake light does not illuminate when I use the rear brake, but works fine when the front is engaged. Any ideas about what could be wrong? Or anything I can try to do to fix it?
Boomstick1491 is offline   Reply With Quote
Old May 28th, 2012, 03:29 PM   #2
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
check the spring
THE GOOD LIFE
cuz is offline   Reply With Quote
Old May 28th, 2012, 03:32 PM   #3
Carlos,
The lever of the rear brake acts on a micro-switch, which is independent from the front brake system.
Either switch (front or rear) that is actuated upon first, closes the circuit to light the brake light.
Your problem may be some simple lack of adjustment of the position at which the switch closes and opens (it is adjustable).
Old May 28th, 2012, 05:55 PM   #4
Boomstick1491
Originally Posted by Motofool View Post
Carlos,
Ha, you called me Carlos.
Anyway, how do I check this thing's adjustment? I'm marginally retarded, so try to dumb your answer down as much as possible. Thanks.
Old May 28th, 2012, 06:29 PM   #5
I am fully retarded explaining things; here you go:
Remove the right panel, follow the foot pedal, see what it moves (brake cylinder plunge and a switch via a spring), see if the position of the switch can be adjusted via some thread or nut (my bike is older than yours, so it may be different), try to move the switch away from the pedal stretching the spring until you can hear a click (that should turn the brake light on).
Old May 29th, 2012, 05:28 PM   #6
Boomstick1491
When you say panel, do you mean the fairing or some other part? I told you I was missing a chromosome...
Old May 30th, 2012, 05:51 AM   #7
Yes, that is the fairing that covers the rear brake reservoir (the one into which you put the brake fluid and allows you to check the level).
Old May 30th, 2012, 03:40 PM   #8
Boomstick1491
My rear brake reservoir is mounted in plain sight above the rear wheel. Are you thinking pre-gen or am I mistaking something else for the reservoir?
Also, I was doing a quick pre-ride inspection this morning and really pushed HARD on the rear pedal as I was checking the brake light and the thing came on. I suspect there is some kind of setting (perhaps in this mystical spring of which you guys have spoken) that completes the circuit with more/less pressure. Plausible or what?
Old May 30th, 2012, 05:56 PM   #9
Yes, mine is a pre-gen.
Go to pages 119 and 120 of the manual of your 2008 Ninja:
http://www.kawasaki-techinfo.net/sho...5&lang_code=EN
Old May 30th, 2012, 06:32 PM   #10
Boomstick1491
Dude, I <3 you. I cannot believe how easy that is and how stupid I am for not remembering there is an adjustment "screw" referenced in the manual. I will fix this tomorrow. Thanks SO much!!!
Old May 30th, 2012, 07:27 PM   #11
Cool!
It seems different form the pre-gen.
Hope you can solve that lack of brake light,.....safety first
Old June 1st, 2012, 03:16 PM   #12
Boomstick1491
Cool!
Fixed. Thanks for the help broseph!
Brake Light Issue/Front Master Rebuild? TDMX595 1986 - 2007 Ninja 250R Tech Talk 5 October 24th, 2014 05:23 PM
Ninja 250 2011 Brake light issue! srecordz 2008 - 2012 Ninja 250R Tech Talk 13 October 11th, 2013 11:01 AM
Rear Brake Doesn't activate Brake Light And DOT3/4 FRONT BRAKE OIL coelgrim 2008 - 2012 Ninja 250R Tech Talk 16 March 11th, 2013 05:10 PM
Brake Light Issue YMCMB 2008 - 2012 Ninja 250R Tech Talk 1 September 28th, 2012 02:51 PM
brake light issue Kitdog 2008 - 2012 Ninja 250R Tech Talk 20 July 26th, 2010 07:57 PM
