September 29th, 2016, 10:07 PM | #1 |
Join Date: Jun 2013 Motorcycle(s): 2010 Ninja 250 Posts: 596
A note on Arashi 310mm rotors (Chinese ebay rotors)
This is just some documentation/record keeping/note-taking.
I have taken the time to measure a used front brake rotor bought from subxero. It is a semi-floating style brake rotor with anti-rattle springs on the buttons. This rotor has been adapted to a 4-pot brembo that you would find on 2000s Ducatis. I measured the thickness of the rotor across 18 different points. 9 across from the buttons holding the rotor to the center carrier and the 9 points between them. Each measurement was between 0.192-0.193 in or 4.88ish-4.90ish mm. Pretty ballin'. The service limit given by the seller/manufacturer of Arashi rotors is 4.5mm down from 5.0mm new. This is comparable to the difference between the OEM service limit of 4.0mm and new thickness of 4.5mm. This amount of wear and consistency looks promising to say the least, and it has already been field tested for thousands of miles. I'm ready to scuff these up, clean them, and put them on the Ninja. Last futzed with by Flying; September 30th, 2016 at 10:18 AM. |
September 30th, 2016, 08:35 AM | #2 |
dirty boy
MOTM - Apr '14
How was your drive back to NJ?
But yeah, I was and am very impressed with that rotor. I don't know for certain how many miles I put on it?? Looks like I installed back in May 2014. That being said I have to have put around 5k on it. I put those pads and the rotor on the same time and those pads are completely gone. Keep us posted on what you think of the setup once you get it all back together.
September 30th, 2016, 10:13 AM | #3 | |
I intend to continue measuring the rotor to gauge wear. |
I bought some cheap ebay front brake rotors.. | corksil | General Motorcycling Discussion | 12 | February 4th, 2016 09:13 AM |
cheap chinese knockoff rotors? | subxero | General Motorcycling Discussion | 25 | September 22nd, 2015 08:51 PM |
floating rotors? | jbaum | 1986 - 2007 Ninja 250R Tech Talk | 3 | February 7th, 2015 08:01 AM |
How to know if rotors are warped? | 2fidyswag | 2008 - 2012 Ninja 250R Tech Talk | 16 | June 30th, 2013 11:07 AM |
Ridged Rotors and other Q's | indr | 2008 - 2012 Ninja 250R Tech Talk | 2 | February 21st, 2012 10:59 AM |
